- What's New
- Function Overview
- Billing
- Getting Started
User Guide
- Granting LTS Permissions to IAM Users
- Purchasing LTS Resource Packages
- Log Management
Log Ingestion
- Overview
Using ICAgent to Collect Logs
- Overview
- Installing ICAgent (Intra-Region Hosts)
- Installing ICAgent (Extra-Region Hosts)
- Managing ICAgent
- Managing Host Groups
- Ingesting BMS Text Logs to LTS
- Ingesting CCE Application Logs to LTS
- Ingesting ECS Text Logs to LTS
- Ingesting ServiceStage Containerized Application Logs to LTS
- Ingesting ServiceStage Cloud Host Logs to LTS
- Ingesting Self-Built Kubernetes Application Logs to LTS
- Setting ICAgent Structuring Parsing Rules
Ingesting Cloud Service Logs to LTS
- Overview
- Ingesting AOM Logs to LTS
- Ingesting APIG Logs to LTS
- Ingesting CBH Logs to LTS
- Ingesting CFW Logs to LTS
- Ingesting CTS Logs to LTS
- Ingesting DDS Logs to LTS
- Ingesting DMS for Kafka Logs to LTS
- Ingesting DRS Logs to LTS
- Ingesting GaussDB(DWS) Logs to LTS
- Ingesting ELB Logs to LTS
- Ingesting Enterprise Router Logs to LTS
- Ingesting FunctionGraph Logs to LTS
- Ingesting GaussDB Logs to LTS
- Ingesting GES Logs to LTS
- Ingesting TaurusDB Logs to LTS
- Ingesting GeminiDB Logs to LTS
- Ingesting GeminiDB Mongo Logs to LTS
- Ingesting GeminiDB Cassandra Logs to LTS
- Ingesting IoTDA Logs to LTS
- Ingesting ModelArts Logs to LTS
- Ingesting MRS Logs to LTS
- Ingesting RDS for MySQL Logs to LTS
- Ingesting RDS for PostgreSQL Logs to LTS
- Ingesting RDS for SQL Server Logs to LTS
- Ingesting ROMA Connect Logs to LTS
- Ingesting SMN Logs to LTS
- Ingesting SecMaster Logs to LTS
- Ingesting OBS Files to LTS (Beta)
- Ingesting VPC Logs to LTS
- Ingesting WAF Logs to LTS
- Using APIs to Ingest Logs to LTS
- Ingesting Logs to LTS Across IAM Accounts
- Using Kafka to Report Logs to LTS
- Using Flume to Report Logs to LTS
- Log Search and Analysis
Log Visualization
- Overview
- Visualizing Logs in Statistical Charts
Visualizing Logs in Dashboards
- Creating a Dashboard
- Adding a Dashboard Filter
Dashboard Templates
- APIG Dashboard Templates
- CCE Dashboard Templates
- CDN Dashboard Templates
- CFW Dashboard Templates
- CSE Dashboard Templates
- DCS Dashboard Template
- DDS Dashboard Template
- DMS Dashboard Template
- DSL Dashboard Template
- ER Dashboard Template
- METRIC Dashboard Template
- Nginx Dashboard Templates
- VPC Dashboard Template
- WAF Dashboard Templates
- Log Alarms
- Log Transfer
- Log Processing
- Configuration Center
- Querying Real-Time LTS Traces
Best Practices
- Overview
Log Ingestion
- Collecting Logs from Third-Party Cloud Vendors, Internet Data Centers, and Other Huawei Cloud Regions to LTS
- Collecting Kubernetes Logs from Third-Party Clouds, IDCs, and Other Huawei Cloud Regions to LTS
- Collecting Syslog Aggregation Server Logs to LTS
- Importing Logs of Self-built ELK to LTS
- Collecting Zabbix Data Through ECS Log Ingestion
- Collecting Logs from Multiple Channels to LTS
- Log Transfer
- Billing
- Developer Guide
API Reference
- Before You Start
- API Overview
- Calling APIs
- API Calling Examples
- Examples
APIs
- Host Group Management
- Log Group Management
- Log Stream Management
- Log Management
- Log Ingestion
- Log Transfer
- Log Collection Beyond Free Quota
- Cloud Log Structuring
- Container Log Ingestion from AOM to LTS
- Alarm Topics
- Message Template Management
- SQL Alarm Rules
- Keyword Alarm Rules
- Alarm List
- Tag Management
- Dashboard Management
- Log Charts
- Quick Search
- Multi-Account Log Aggregation
- Appendix
- SDK Reference
- Overview
- Consultation
- Log Management
Host Management
- What Do I Do If ICAgent Installation Fails in Windows and the Message "SERVICE STOP" Is Displayed?
- What Do I Do If ICAgent Upgrade Fails on the LTS Console?
- What Do I Do If I Could Not Query New Logs on LTS?
- What Do I Do If ICAgent Restarts Repeatedly After Being Installed?
- What Do I Do If ICAgent Is Displayed as Offline on the LTS Console After Installation?
- What Do I Do If I Do Not See a Host with ICAgent Installed on the LTS Console?
- How Do I Create a VPC Endpoint on the VPCEP Console?
- How Do I Obtain an AK/SK Pair?
- How Do I Install ICAgent by Creating an Agency?
Log Ingestion
- What Do I Do If LTS Cannot Collect Logs After I Configure Host Log Ingestion?
- Will LTS Stop Collecting Logs After the Free Quota Is Used Up If I Disable "Continue to Collect Logs When the Free Quota Is Exceeded" in AOM?
- What Do I Do If the CPU Usage Is High When ICAgent Is Collecting Logs?
- What Kinds of Logs and Files Does LTS Collect?
- How Do I Disable the Function of Collecting CCE Standard Output Logs to AOM on the LTS Console?
- What Log Rotation Scheme Should I Use for ICAgent to Collect Logs?
- Does LTS Use the Log4j Plug-in to Report Logs?
- How Long Does It Take to Generate Logs After Configuring Log Ingestion?
- What Do I Do If LTS Cannot Collect Logs After I Configure Log Ingestion with ICAgent?
Log Transfer
- Does LTS Delete Logs That Have Been Transferred to OBS Buckets?
- What Are the Common Causes of LTS Log Transfer Abnormalities?
- How Do I Transfer CTS Logs to an OBS Bucket?
- What Do I Do If I Cannot View Historical Data in an OBS Bucket After Transferring Data from LTS to OBS?
- What Do I Do If I Cannot Find a New Partition in a DLI Table After Logs Are Transferred to DLI?
More Documents
- User Guide (ME-Abu Dhabi Region)
- API Reference (ME-Abu Dhabi Region)
- User Guide(Paris Regions)
- API Reference(Paris Regions)
- User Guide (Kuala Lumpur Region)
- API Reference (Kuala Lumpur Region)
- User Guide (Ankara Region)
API Reference (Ankara Region)
- Before You Start
- Calling APIs
- APIs
- Appendix
- Change History
- Videos
IP Functions
The relationships between IP addresses and regions provided by LTS are from third-party libraries. The data is updated periodically (about half a year) and may not reflect the correct relationships. LTS will be optimized to update the libraries more frequently to provide better experience.
A maximum of 5 million data records can be queried using the aggregate query of an IP function. Exceeding this limit will cause the query to time out.
IP functions identify the country, state/province, city, and network carrier to which a target IP address belongs.
Syntax
SELECT count(*) AS PV, ip_to_province(client_ip) AS province GROUP BY province
IP Function Statements
Statement |
Description |
Example |
ip_to_province |
Identifies the state/province where an IP address is located. |
ip_to_province(x) |
ip_to_country |
Identifies the country/region where an IP address is located. |
ip_to_country(x) |
ip_to_city |
Identifies the city where an IP address is located. |
ip_to_city(x) |
ip_to_provider |
Identifies the network carrier of an IP address. |
ip_to_provider(x) |
ip_to_geo |
Returns the longitude and latitude of an IP address. |
ip_to_geo(x) |
Examples
- ip_to_province
Obtains the top 3 states/provinces with the most requests.
- Query and analysis statement
SELECT count(*) AS PV, ip_to_province(client_ip) AS province GROUP BY province ORDER BY PV desc LIMIT 3
- Query and analysis result
Table 2 Query and analysis result PV
province
101
Guangdong
83
Shanghai
78
Shandong
- ip_to_country
Obtains the top 3 countries or regions with the most requests.
SELECT count(*) AS PV, ip_to_country(client_ip) AS county GROUP BY country ORDER BY PV desc LIMIT 3
Table 3 Query and analysis result PV
country
100
China
76
United States
55
Canada
- ip_to_city
Obtains the top 3 cities with the most requests.
SELECT count(*) AS PV, ip_to_city(client_ip) AS city GROUP BY city ORDER BY PV desc LIMIT 3
Table 4 Query and analysis result PV
city
109
Guangzhou
89
Shanghai
23
Xi'an
- ip_to_provider
Obtains the top 3 carriers with the most requests.
SELECT count(*) AS PV, ip_to_provider(client_ip) AS provider GROUP BY provider ORDER BY PV desc LIMIT 3
Table 5 Query and analysis result PV
provider
115
Telecom
65
att.com
44
Unicom
- ip_to_geo
SELECT count(*) AS PV, ip_to_geo (client_ip) AS geo GROUP BY province ORDER BY PV desc LIMIT 3
Table 6 PV
geo
101
83
47.369013, -68.326674
78
32.715891, -117.161588
