Exporting Monitoring Data
If you want to analyze the bandwidth or traffic usage of EIPs to locate faults, you can export EIP monitoring data.
- Click
in the upper left corner and select the desired region and project.
- Hover on the upper left corner to display Service List and choose Management & Deployment > Cloud Eye.
- In the navigation pane on the left, choose Cloud Service Monitoring > Elastic IP and Bandwidth.
- On the Cloud Service Monitoring page, click Export Data.
- Configure the time range, period, resource type, dimension, monitored object, and metric.
- Click Export.
![](https://support.huaweicloud.com/intl/en-us/usermanual-eip/public_sys-resources/note_3.0-en-us.png)
You can export data for multiple metrics at a time to a CSV file.
- The first row in the exported CSV file displays the username, region, service, instance name, instance ID, metric name, metric data, time, and timestamp. You can view historical monitoring data.
- To convert the time using a Unix timestamp to the time of the target time zone, perform the following steps:
- Use Excel to open a .csv file.
- Use the following formula to convert the time:
Target time = [Unix timestamp/1000 + (Target time zone) x 3600]/86400 + 70 x 365 + 19
- Set cell format to Date.
To convert a Unix timestamp of 1475918112000 to Shanghai time (UTC+8), using the following formula:
Target time = [1475918112000/1000 + (+8) x 3600]/86400 + 70 x 365 + 19
Set the cell format to date and select a presentation format such as 2016/3/14 13:30. Then, the target time obtained will be presented as 2016/10/8 17:15.
