Updated on 2025-08-15 GMT+08:00
Creating a Password Datasource Authentication
Create a password datasource authentication on the DLI console to store passwords of the GaussDB(DWS), RDS, DCS, and DDS data sources to DLI. This will allow you to access to the data sources without having to configure a username and password in SQL jobs.
Data Sources Supported by Password Datasource Authentication
Table 1 lists the data sources supported by password datasource authentication.
Table 1 Data sources supported by password datasource authentication
Job Type
Table Type
Data Source
Spark SQL
GaussDB(DWS), RDS, DDS, and Redis
Flink OpenSource SQL
Source table
GaussDB(DWS), RDS, and Redis
Result table
GaussDB(DWS), RDS, CSS, and Redis
Dimension table
  1. Create a datasource authentication.
    1. Log in to the DLI management console.
    2. Choose Datasource Connections. On the page displayed, click Datasource Authentication.
    3. Click Create.
      Configure authentication parameters according to Table 2.
      Table 2 Parameter descriptions
      Type
      Select Password.
      Authentication Certificate
      Name of the datasource authentication to be created.
      • The name can contain only digits, letters, and underscores (_), but cannot contain only digits or start with an underscore (_).
      • The name can contain a maximum of 128 characters.
      Username
      Username for accessing the data source.
      Password
      Password for accessing the data source.
      Figure 1 Creating a datasource authentication – Password
  2. Access the data source.
    When creating a data source, associate the data source with the created datasource authentication to access the data source.
    Table 3 lists the fields used to associate with the datasource authentication during table creation.
    Table 3 Fields that are used to associate with password datasource authentication during table creation
    Job Type
    Mandatory
    Data Type
    Spark SQL
    passwdauth
    No
    String
    Name of datasource authentication. It is applicable to GaussDB(DWS), RDS, DDS, and Redis data sources.
    pwd_auth_name
    No
    String
    This field is used to associate datasource authentications when source, result, and dimension tables are created.
    Set pwd_auth_name to the name of the password datasource authentication. If this parameter is set, you do not need to configure a username and a password of the data source in SQL jobs.
    For details about how to create a table, see Data Lake Insight Syntax Reference.
