Updated on 2026-09-08 GMT+08:00
Datasource Authentication Permission Management
Grant permissions on a datasource authentication to users so multiple user jobs can use the datasource authentication without affecting each other.
Notes
  • The administrator and the datasource authentication owner have all permissions. You do not need to set permissions for them, and their datasource authentication permissions cannot be modified by other users.
  • When setting datasource authentication permissions for a new user, ensure that the user group to which the user belongs has the Tenant Guest permission.
    For details about the Tenant Guest permission and how to apply for the permission, see System Permissions and Creating a User Group in Identity and Access Management User Guide.
Granting Permissions on Datasource Connections
  1. Log in to the DLI management console.
  2. Choose Datasource Connections. On the page displayed, click Datasource Authentication.
  3. Locate the row containing the datasource authentication to be authorized and click Manage Permission in the Operation column. The User Permissions page is displayed.
  4. Click Grant Permission in the upper right corner of the page. On the Grant Permission dialog box displayed, grant permissions on this datasource authentication to other users.
    Figure 1 Granting permissions on datasource connections
    Table 1 Permission granting parameters
    Username
    Name of the IAM user to whom permissions on the datasource connection are to be granted.
    The username is the name of an existing IAM user.
    Select the permissions to be granted to the user
    • Access: This permission allows you to access the datasource connection.
    • Update: This permission allows you to update the datasource connection.
    • Delete: This permission allows you to delete the datasource connection.
    • Grant Permission: This permission allows you to grant the datasource connection permission to other users.
    • Grant Permission: This permission allows you to revoke the datasource connection permission to other users. However, you cannot revoke the permissions of the datasource connection owner.
    • View Other User's Permissions: This permission allows you to view the datasource connection permissions of other users.
Modifying the Permissions of Current User
  4. Click Set Permission in the Operation column to modify the permissions of the current user. Table 1 lists the detailed permission descriptions.
    • If all options under Set Permission are gray, you are not allowed to change permissions on this datasource connection. You can apply to the administrator, group owner, or other users who have the permission to grant permissions for the permissions to grant and revoke the datasource authentication permissions.
    • To revoke all permissions of the current user, click Revoke Permission in the Operation column. The IAM user will no longer have any permission on the datasource authentication.
