Managing Flink Job Templates
Flink templates include sample templates and custom templates. You can modify an existing sample template to meet the actual job logic requirements and save time for editing SQL statements. You can also customize a job template based on your habits and methods so that you can directly invoke or modify the template in later jobs.
Flink template management provides the following functions:
- Flink SQL Sample Template
- Flink OpenSource SQL Sample Template
- Custom Templates
- Creating a Template
- Creating a Job Based on a Template
- Modifying a Template
- Deleting a Template
The template list displays existing sample templates for Flink SQL jobs. Table 1 describes the parameters in the template list.
The scenarios of sample templates can be different, which are subject to the console.
| Parameter | Description |
| Name | Template name. The value can contain up to 64 characters. Only letters, digits, hyphens (-), and underscores (_) are allowed. |
| Description | Description of a template. It can contain 0 to 512 characters. |
| Operation | Create Job: Create a job directly by using the template. After a job is created, the system switches to the Edit page under . |
The template list displays existing sample templates for Flink SQL OpenSource jobs. Table 1 describes the parameters in the template list.
- Create a wide table of order information from the dimension table of address information.
- Generate statistics on indicators such as the daily transaction amount, number of orders, and number of paid users in real time.
- Generate statistics on offerings with the highest real-time click-through rate.
Custom Templates
The custom template list displays all Jar job templates. Table 1 describes parameters in the custom template list.
| Created | Time when a template is created. |
| Updated | Latest time when a template is modified. |
| Operation |
Creating a Template
You can create a template using any of the following methods:
- Creating a template on the page
- In the navigation pane of the DLI management console, choose Job Templates > Flink Templates.
- Click Create Template in the upper right corner of the page. The dialog box is displayed.
- Specify Name and Description. Figure 1 Creating a Flink template
Table 4 Template parameters Parameter
Type
Template type
- Flink SQL job template
- Flink OpenSource SQL job template
Name
NOTE:The template name must be unique.
Tags
Tags used to identify cloud resources. A tag includes the tag key and tag value. If you want to use the same tag to identify multiple cloud resources, that is, to select the same tag from the drop-down list box for all services, you are advised to create predefined tags on the Tag Management Service (TMS).
If your organization has configured tag policies for DLI, add tags to resources based on the policies. If a tag does not comply with the tag policies, resource creation may fail. Contact your organization administrator to learn more about tag policies.
For details, see Tag Management Service User Guide.
NOTE:- A maximum of 20 tags can be added.
- Only one tag value can be added to a tag key.
- The key name in each resource must be unique.
- Tag key: Enter a tag key name in the text box. NOTE:
A tag key can contain a maximum of 128 characters. Only letters, digits, spaces, and special characters (_.:+-@) are allowed, but the value cannot start or end with a space or start with _sys_.
- Tag value: Enter a tag value in the text box. NOTE:
A tag value can contain a maximum of 255 characters. Only letters, digits, spaces, and special characters (_.:+-@) are allowed.
- Click OK to enter the editing page. The Table 5 describes the parameters on the template editing page.
Table 5 Template parameters Parameter
Name
You can modify the template name.
You can modify the template description.
Saving Mode
- Save Here: Save the modification to the current template.
- Save as New: Save the modification as a new template.
SQL statement editing area
In the area, you can enter detailed SQL statements to implement business logic. For details about how to compile SQL statements, see Data Lake Insight SQL Syntax Reference.
Save
Save the modifications.
Create Job
Use the current template to create a job.
Format
Format SQL statements. After SQL statements are formatted, you need to compile SQL statements again.
Theme Settings
Change the font size, word wrap, and page style (black or white background).
- In the SQL statement editing area, enter SQL statements to implement service logic. For details about how to compile SQL statements, see Data Lake Insight SQL Syntax Reference.
- After the SQL statement is edited, click Save in the upper right corner to complete the template creation.
- (Optional) If you do not need to modify the template, click Create Job in the upper right corner to create a job based on the current template. For details about how to create a job, see Creating a Flink Jar Job.
- Creating a template based on an existing job template
- In the navigation pane of the DLI management console, choose Job Templates > Flink Templates. Click the Custom Templates tab.
- In the row where the desired template is located in the custom template list, click Edit under Operation to enter the page.
- After the modification is complete, set Saving Mode to Save as New.
- Click Save in the upper right corner to save the template as a new one.
- Creating a template using a created job
- In the navigation pane of the DLI management console, choose Job Management > Flink Jobs.
- Click Create Job in the upper right corner. The Create Job page is displayed.
- Specify parameters as required.
- After the SQL statement is compiled, click Set as Template.
- In the Set as Template dialog box that is displayed, specify Name and Description and click OK.
- Creating a template based on the existing job
- In the job list, locate the row where the job that you want to set as a template resides, and click Edit in the Operation column.
- After the SQL statement is compiled, click .
You can create jobs based on sample templates or custom templates.
- In the sample template list, click Create Job in the Operation column of the target template. For details about how to create a job, see Creating a Flink OpenSource SQL Job and Creating a Flink Jar Job.
After creating a custom template, you can modify it as required. The sample template cannot be modified, but you can view the template details.
- In the row where the template you want to modify is located in the custom template list, click Edit in the Operation column to enter the page.
- In the SQL statement editing area, modify the SQL statements as required.
- Set Saving Mode to Save Here.
- Click Save in the upper right corner to save the modification.
Deleting a Template
You can delete a custom template as required. The sample templates cannot be deleted. Deleted templates cannot be restored. Exercise caution when performing this operation.
- In the custom template list, select the templates you want to delete and click Delete in the upper left of the custom template list.
Alternatively, you can delete a template by performing the following operations: In the custom template list, locate the row where the template you want to delete resides, and click More > Delete in the Operation column.
- In the displayed dialog box, click Yes.
