- Getting Started
User Guide
- Overview
- Resource Management
Application Management
- Creating an Application
- Modifying an Application
- Deleting an Application
- Creating a Component
- Modifying a Component
- Deleted a Component
- Creating a Group
- Modifying a Group
- Deleting a Group
- Transferring Resources
- Viewing Resource Details
- Viewing Capacity Rankings
- Multi-cloud Configurations
- Cross-Account Resources
- Resource O&M
- Automated O&M
- Faults
- Change Management
- Resilience Center
- Task Management
- Basic Configurations
- Viewing Logs
- Best Practices
- API Reference
- Product Consulting
- Resource Management FAQs
FAQs About Resource O&M
Patch Management FAQs
- Why Can't I Select a Node?
- Automation FAQs
- Batch Operation FAQs
- FAQs About Fault Management
- Resilience Center FAQs
- Change History
On this page
Show all
Patch Tickets
You can view and manage patch tickets.
If you use the patch management function, the system generates a patch ticket.
View patch tickets on the Cloud Operations Center page.
- Log in to COC.
- In the navigation pane on the left, choose Task Management > Execution Records and click the Patch Tickets tab.
- You can search for tickets by ID, region, ticket type, start time, and end time.
Figure 1 Patch ticket list
Ticket type: Scan and Repair
- You can click a ticket ID to view the ticket details.
- If a ticket is in the Paused state, you can click Continue to continue it.
- If a ticket is in the Executing state, you can click Pause to pause it.
- If a ticket is not completed, you can click Forcibly End to stop it.
Figure 2 Service ticket details
Parent topic: Execution Records
