- Getting Started
User Guide
- Overview
- Resource Management
Application Management
- Creating an Application
- Modifying an Application
- Deleting an Application
- Creating a Component
- Modifying a Component
- Deleted a Component
- Creating a Group
- Modifying a Group
- Deleting a Group
- Transferring Resources
- Viewing Resource Details
- Viewing Capacity Rankings
- Multi-cloud Configurations
- Cross-Account Resources
- Resource O&M
- Automated O&M
- Faults
- Change Management
- Resilience Center
- Task Management
- Basic Configurations
- Viewing Logs
- Best Practices
- API Reference
- Product Consulting
- Resource Management FAQs
FAQs About Resource O&M
Patch Management FAQs
- Why Can't I Select a Node?
- Automation FAQs
- Batch Operation FAQs
- FAQs About Fault Management
- Resilience Center FAQs
- Change History
On this page
Show all
Diagnosing OS Faults
- Log in to COC.
- In the navigation pane, choose Fault Management > Diagnostic Tools. On the displayed page, in the OS Performance Diagnosis area, click Diagnose Now. The Create OS Performance Diagnosis Task page is displayed.
Figure 1 OS diagnosis entry
- On the Create OS Performance Diagnosis Task page, click Add. Ensure that you have installed a UniAgent in advance, and the image and specifications must meet the OS diagnosis requirements.
Figure 2 Selecting instances
- On the Create OS Performance Diagnosis page, select I agree to install the plug-in and collect data based on the Guest OS Diagnosis Service Frontend Data Collection License, and click Submit.
Figure 3 Agreeing to the authorization agreement and submitting for diagnosis
- Check the diagnosis step by step. progress bar.
Figure 4 Diagnosis in progress
- After the diagnosis is complete, view the diagnosis report.
Figure 5 Viewing the fiagnosis report
Parent topic: Diagnosis Tools
