- Getting Started
User Guide
- Overview
- Resource Management
Application Management
- Creating an Application
- Modifying an Application
- Deleting an Application
- Creating a Component
- Modifying a Component
- Deleted a Component
- Creating a Group
- Modifying a Group
- Deleting a Group
- Transferring Resources
- Viewing Resource Details
- Viewing Capacity Rankings
- Multi-cloud Configurations
- Cross-Account Resources
- Resource O&M
- Automated O&M
- Faults
- Change Management
- Resilience Center
- Task Management
- Basic Configurations
- Viewing Logs
- Best Practices
- API Reference
- Product Consulting
- Resource Management FAQs
FAQs About Resource O&M
Patch Management FAQs
- Why Can't I Select a Node?
- Automation FAQs
- Batch Operation FAQs
- FAQs About Fault Management
- Resilience Center FAQs
- Change History
On this page
Show all
Help Center/
Cloud Operations Center/
User Guide/
Automated O&M/
Patch Management/
Viewing the Patch Compliance Report Details
After the patch compliance scan or repair completed, you can view the details of the patch on the instance.
View the patch compliance scanning and patch repairing results on COC.
Precautions
The patch compliance report retains the latest scan or repair record.
- Log in to COC.
- In the navigation pane on the left, choose Resource O&M > Automated O&M. Click Patch management. On the displayed page, click Patch Scanning.
Figure 1 Patch management
- Locate the row containing the patch compliance report for which you want to check details and click Summary in the Operation column.
Status description:
- Installed: The patch complies with the patch baseline, has been installed on an ECS instance, and no update is available.
- Non-baseline patches have been installed: The patch is not compliant with the patch baseline but has been installed on an ECS instance.
- Installed-to be restarted: The patch has been repaired, and can take effect only after the ECS instance is restarted.
- InstalledRejected: The rejected patch defined in the exceptional patches of a patch baseline. This patch will not be repaired even if it is compliant with the patch baseline.
- To be repaired: The patch complies with the baseline, but the patch version is earlier than the baseline version.
- Repair failed: The patch repair fails.
Figure 2 Patch compliance report summary
Parent topic: Patch Management
