Help Center/ Cloud Operations Center/ User Guide/ Application Management/ Disassociating Resources from an Application Group
Updated on 2025-09-23 GMT+08:00
After a group is associated with resources, if you need to disassociate the resources from the group, perform the operations in this section.
  1. Log in to COC.
  2. In the navigation pane, choose Resources > Application and Resource Management.
  3. Click Applications in the upper left corner.
  4. In the application list on the left, expand the application, select a group, select the resources to be disassociated, and click Disassociate.
    Figure 1 Disassociating a resource from a group
  5. Click OK.
    The resource disassociation is complete.
