Kubernetes
Typical native configuration items are provided. You can configure native community management components such as kube-apiserver and kube-controller for the best cloud native experience.
API Server Settings (kube-apiserver)
Container Eviction
By default, the default tolerance time applies to all containers in a cluster. You can also configure different tolerance times for pods. In this case, your custom settings take effect.
It is recommended that you properly configure the tolerance times for pods, or certain problems may occur.
- If the parameter is set to a low value, containers may be moved frequently during brief fault scenarios like network jitter, which can impact services.
- If the parameter is set to a high value, containers may not be moved for a long period of time in the event of a node failure, which can impact services.
| Item | Parameter | Description | Value |
| Toleration Time for Unready Nodes | default-not-ready-toleration-seconds | Tolerance time when a node is not ready. If a node becomes unavailable, pods running on the node are evicted automatically after the tolerance time elapses. The default value is 300s. | Default: 300 |
| Toleration Time for Inaccessible Nodes | default-unreachable-toleration-seconds | Tolerance time when a node is unreachable. If the environment is abnormal, for example, a node cannot be accessed (due to reasons such as abnormal node network), pods running on the node are evicted automatically after the tolerance time elapses. The default value is 300s. | Default: 300 |
Admission Controller Add-on Configurations
With Kubernetes, you can enable admission controller add-ons to limit and manage Kubernetes API objects (like pods, Services, and Deployments) prior to modifying them within a cluster.
This parameter is available only in clusters of v1.23.14-r0, v1.25.9-r0, v1.27.6-r0, v1.28.4-r0, or later versions.
| Node Restriction Add-on | enable-admission-plugin-node-restriction | This add-on allows the kubelet of a node to operate only the objects of the current node for enhanced isolation in multi-tenant scenarios or the scenarios with high security requirements. For details, see the official documentation. | Enable/Disable |
| Pod Node Selector Add-on | enable-admission-plugin-pod-node-selector | This add-on allows cluster administrators to configure the default node selector through namespace annotations. In this way, pods run only on specific nodes and configurations are simplified. | Enable/Disable |
| Pod Toleration Limit Add-on | enable-admission-plugin-pod-toleration-restriction | This add-on allows cluster administrators to configure the default value and limits of pod tolerations through namespaces for fine-grained control over pod scheduling and key resource protection. | Enable/Disable |
Service Account Token Volume Projection
This parameter is available only in clusters of v1.23.16-r0, v1.25.11-r0, v1.27.8-r0, v1.28.6-r0, v1.29.2-r0, or later versions.
| API Audience Settings | api-audiences | Specify the token audiences that the API server will accept. The API server verifies the aud (audience) claim in JWTs to ensure that tokens are issued for accessing this API server. Configuration suggestion: Accurately configure audiences according to the communication needs among cluster services. By doing so, the service account token is used for authentication only between authorized services, which enhances security. NOTE: An incorrect configuration may lead to an authentication communication failure between services or an error during token verification. | Default value: "https://kubernetes.default.svc.cluster.local" Enter one or more values. |
| Service Account Issuer | service-account-issuer | Specify the identity that Kubernetes uses as the issuer of ServiceAccount tokens. This value directly determines the iss (issuer) claim in JWTs. External systems use this value to verify that a token was issued by this cluster. Configuration suggestion: Ensure the configured issuer URL can be accessed in the cluster and trusted by the authentication system in the cluster. NOTE: If your specified issuer URL is untrusted or inaccessible, the authentication process based on the service account may fail. | Default value: "https://kubernetes.default.svc.cluster.local" Enter one or more values. |
Controller Manager Settings (kube-controller-manager)
Common Controller Settings
- Controller Performance: used to configure performance parameters for the controller to access kube-apiserver.
It is recommended that you properly configure the controller performance settings, or certain problems may occur.
- If a parameter is set to a small value, client traffic limiting may be triggered, affecting controller performance.
- If a parameter is set to a large value, kube-apiserver may be overloaded.
Table 4 Parameters Item
Value
QPS for Communicating with kube-apiserver
kube-api-qps
QPS for communication with kube-apiserver
- If the number of nodes in a cluster is less than 1,000, the default value is 100.
- If the number of nodes in a cluster is 1,000 or more, the default value is 200.
Burst for Communicating with kube-apiserver
kube-api-burst
Burst for communication with kube-apiserver
- Resource Object Concurrency Configuration: specifies the number of resource objects that are allowed to synchronize simultaneously. A larger value indicates a quicker response and higher CPU (and network) load.
It is recommended that you properly configure the controller concurrency, or certain problems may occur.
- If a parameter is set to a small value, the controller may respond slowly.
- If a parameter is set to a large value, the cluster management plane will be overloaded.
Table 5 Parameters Item
Value
Deployment
concurrent-deployment-syncs
Number of Deployment objects that can be synchronized concurrently. A larger value indicates a quicker response to Deployments and higher CPU (and network bandwidth) pressure.
Default: 5
Endpoint
concurrent-endpoint-syncs
Number of endpoints that can be concurrently synchronized. A larger value indicates faster update of endpoints and higher CPU (and network) pressure.
Default: 5
Garbage Collection
concurrent-gc-syncs
Number of garbage collector workers that are allowed to synchronize concurrently.
Default: 20
Job
concurrent-job-syncs
Number of job objects that can be synchronized concurrently. A larger value indicates a quicker response to jobs and higher CPU (and network) usage.
Default: 5
CronJob
concurrent-cron-job-syncs
Number of CronJob objects that can be synchronized concurrently. A larger value indicates a quicker response to CronJobs and higher CPU (and network) usage.
Default: 5
Namespace
concurrent-namespace-syncs
Number of namespace objects that can be synchronized concurrently. A larger value indicates a quicker response to namespaces and higher CPU (and network) usage.
Default: 10
ReplicaSet
concurrent-replicaset-syncs
Number of ReplicaSet objects that can be synchronized concurrently. A larger value indicates a quicker response to ReplicaSet management and higher CPU (and network) usage.
Default: 5
Resource Quota
concurrent-resource-quota-syncs
Number of ResourceQuota objects that can be synchronized concurrently. A larger value indicates a faster response to quota management and higher CPU (and network) usage.
Default: 5
Service
concurrent-service-syncs
Number of Service objects that can be synchronized concurrently. A larger value indicates a faster response to Service management and higher CPU (and network) usage.
Default: 10
ServiceAccount Tokens
concurrent-serviceaccount-token-syncs
Number of service account token objects that can be synchronized concurrently. A larger value indicates faster token generation and higher CPU (and network) usage.
Default: 5
TTL-after-finished Controller
concurrent-ttl-after-finished-syncs
Number of ttl-after-finished-controller workers that can be synchronized concurrently.
Default: 5
RC
concurrent_rc_syncs
Number of replication controllers that can be synchronized concurrently. A larger value indicates faster replica management operations and higher CPU (and network) usage.
NOTE:This parameter is used only in clusters of v1.19 or earlier.
Default: 5
RC
concurrent-rc-syncs
NOTE:This parameter is used only in clusters of v1.21 to v1.23. In clusters of v1.25 and later, this parameter is deprecated (officially deprecated from v1.25.3-r0 on).
Default: 5
HPA
concurrent-horizontal-pod-autoscaler-syncs
Maximum number of HPA auto scaling requests that can be processed concurrently. A larger value indicates a faster HPA auto scaling and higher CPU (and network) usage.
This parameter is available only in clusters of v1.27 or later.
Default: 5
Value range: 1 to 50
Node Lifecycle Controller Settings
| Unhealthy AZ Threshold | unhealthy-zone-threshold | When more than a certain proportion of pods in an AZ are unhealthy, the AZ itself will be considered unhealthy, and scheduling pods to nodes in that AZ will be restricted to limit the impacts of the unhealthy AZ. NOTE: If the parameter is set to a large value, pods in unhealthy AZs will be migrated in a large scale, which may lead to risks such as overloaded clusters. | Default: 0.55 |
| Node Eviction Rate | node-eviction-rate | This parameter specifies the number of nodes that pods are deleted from per second in a cluster when the AZ is healthy. The default value is 0.1, indicating that pods can be evicted from at most one node every 10 seconds. NOTE: Configure this parameter based on the size of the cluster. The number of pods to be evicted in each batch should not exceed 300. If the parameter is set to a large value, the cluster may be overloaded. Additionally, if too many pods are evicted, they cannot be rescheduled, which will slow down fault recovery. | Default: 0.1 |
| Secondary Node Eviction Rate | secondary-node-eviction-rate | This parameter specifies the number of nodes that pods are deleted from per second in a cluster when the AZ is unhealthy. The default value is 0.01, indicating that pods can be evicted from at most one node every 100 seconds. NOTE: Configure this parameter with node-eviction-rate and set it to one-tenth of node-eviction-rate. There is no need to set the parameter to a large value for nodes in an unhealthy AZ, and this configuration may result in overloaded clusters. | Default: 0.01 |
| Large Cluster Threshold | large-cluster-size-threshold | If the number of nodes in a cluster is greater than the value of this parameter, this is a large cluster. Configuration suggestion: For the clusters with a large number of nodes, configure a relatively larger value than the default one for higher performance and faster responses of controllers. Retain the default value for small clusters. Before adjusting the value of this parameter in a production environment, check the impact of the change on cluster performance in a test environment. NOTE: kube-controller-manager automatically adjusts configurations for large clusters to optimize the cluster performance. Therefore, an excessively small threshold for small clusters will deteriorate the cluster performance. | Default: 50 |
Horizontal Pod Autoscaler Controller Settings
| HPA Period | horizontal-pod-autoscaler-sync-period | The period of horizontal pod autoscaler for syncing the number of pods. A smaller value will result in a faster auto scaling response and higher CPU load. Configuration suggestion: Retain the default setting. Potential risks: If the period is too long, HPA will respond slowly. If it exceeds the upper limit (153,722,867 minutes), system components may malfunction. If the period is too short, the cluster management plane will be overloaded. | Default: 15 seconds |
| Horizontal Pod Scaling Tolerance | horizontal-pod-autoscaler-tolerance | The configuration determines how quickly HPA will act on auto scaling policies. If the parameter is set to 0, auto scaling will be triggered immediately when the related metrics are met. Configuration suggestion: Configure this parameter based on service resource usage. If the service resource usage increases sharply over time, configure a tolerance to prevent unexpected auto scaling in short-term high-resource usage scenarios. | Default: 0.1 |
| HPA CPU Initialization Period | horizontal-pod-autoscaler-cpu-initialization-period | During this period, HPA can only utilize the metrics of a pod if the pod is ready and its latest metric collection is finished. You can use this parameter to filter out unstable CPU usage data during the early stage of pod startup. This helps prevent incorrect scaling decisions based on momentary peak values. Configuration suggestion: If HPA makes an incorrect scaling decision due to fluctuating CPU usage during pod startup, increase the value of this parameter. Potential risks: A small parameter value may trigger unnecessary scaling based on peak CPU usage, while a large value may cause delayed scaling. Applicable cluster version: This parameter is available only in clusters v1.23.16-r0, v1.25.11-r0, v1.27.8-r0, v1.28.6-r0, v1.29.2-r0, or later. | Default: 5 minutes 0 seconds |
| HPA Initial Readiness Delay | horizontal-pod-autoscaler-initial-readiness-delay | Following HPA CPU initialization, this period enables HPA to get CPU metrics with a less strict criterion. During this period, HPA will gather data on the CPU usage of the pods for scaling, regardless of any changes in the pods readiness status. This parameter ensures continuous tracking of CPU usage, even when the pod statuses change frequently. Configuration suggestion: To prevent HPA misjudgment caused by pod readiness fluctuations after startup, increase the value of this parameter. Potential risks: If this parameter is set to a small value, an unnecessary scale-out may occur due to CPU data fluctuations when the pod is just ready. If it is set to a large value, the HPA may not respond quickly enough in situations requiring rapid scaling. Applicable cluster version: This parameter is available only in clusters v1.23.16-r0, v1.25.11-r0, v1.27.8-r0, v1.28.6-r0, v1.29.2-r0, or later. | Default: 30 seconds |
| HPA Scale-in Stabilization Window | horizontal-pod-autoscaler-downscale-stabilization | Within the stabilization window, the HPA controller continuously observes the recommended scale-in values and selects the maximum recommended replica count. This parameter dampens short-lived load dips, eliminating needless pod churn. Configuration suggestion: Raise the window to stop rapid scale-in/scale-out caused by transient dips. This improves system stability. Potential risks: If the stabilization window is too short, HPA will over-react to brief load dips and repeatedly create and delete pods. If it is too long, HPA will keep unneeded pods alive after real demand has dropped, wasting resources. If it exceeds the maximum length supported (153,722,867 minutes), HPA may fail to start. When HPA restarts, the scale-in stabilization timer resets. Cluster versions: v1.28.15-r60, v1.29.15-r20, v1.30.14-r20, v1.31.10-r20, v1.32.6-r20, v1.33.5-r10, or later | Default: 5 minutes 0 seconds |
Pod Garbage Collector Settings
| Terminated Pods to Be Reclaimed | terminated-pod-gc-threshold | Number of terminated pods that can exist before the terminated pod garbage collector starts deleting terminated pods NOTE: It is recommended that you properly configure this parameter. If the value is too large, there may be a large number of terminated pods in the cluster, which will further affect the performance of list queries and result in an overloaded cluster. | Default: 1000 Value range: 0 to 100000 |
Resource Quota Controller Settings
In high-concurrency scenarios (for example, creating pods in batches), the resource quota management may cause some requests to fail due to conflicts. Do not enable this function unless necessary. To enable this function, ensure that there is a retry mechanism in the request client.
| Resource Quota Management | enable-resource-quota | With resource quota management, you are allowed to control the number of workloads (such as Deployments and pods) and the upper limits of resources (such as CPUs and memory) in namespaces or related dimensions. Namespaces control quotas through the ResourceQuota objects.
| Default: false |
