Prometheus Server View
Prometheus with local data storage enabled scrapes the metrics of all hosts and components. The metrics are then reported to and stored on AOM or a third-party monitoring platform. The Prometheus Server view displays some built-in metrics provided by Prometheus, which can be used to monitor and measure system performance and status.
Metric Description
You can view Prometheus Server metrics in the following table.
        Metric  |
        Unit  |
        Description  |
        Target Sync  |
        second  |
        Collection latency of the target.  |
        Targets  |
        N/A  |
        Total number of metrics collected by the target.  |
        Average Scrape Interval  |
        second  |
        Interval for collecting metrics.  |
        Scrape Failures  |
        N/A  |
        The number of collection failures.  |
        Appended Samples Rate  |
        N/A  |
        The rate at which samples are added to the head.  |
        Head Series  |
        N/A  |
        The number of series in the head.  |
        Head Chunks  |
        N/A  |
        The number of head blocks.  |
        Query Rate  |
        N/A  |
        The number of Prometheus queries per second.  |
        P90 Query Duration  |
        second  |
        Duration for querying 90% of operations on different shards.  |
        Remote Sample Lag Ratio  |
        second  |
        Percentage of the highest timestamp of samples stored in WAL.  |
        Remote Write Traffic  |
        byte/s  |
        Remote write rate.  |
        Current Shards  |
        N/A  |
        The number of shards used for parallel sending to the remote storage.  |
        Max Shards  |
        N/A  |
        Maximum number of shards that the queue is allowed to run.  |
        Min Shards  |
        N/A  |
        Minimum number of shards that the queue is allowed to run.  |
        Desired Shards  |
        N/A  |
        The number of shards that the queue wants to run based on the percentage of input samples to output samples.  |
        Shard Capacity  |
        N/A  |
        Capacity of each shard of the queue used for parallel sending to the remote storage.  |
        Pending Samples  |
        N/A  |
        Current TSDB Segment  |
        N/A  |
        WAL segment index that TSDB is currently writing to.  |
        Current Segment of Remote Write  |
        N/A  |
        Current segment from which the WAL watcher is reading records.  |
        Sample Discard Rate  |
        N/A  |
        The rate at which samples are discarded after being read from WAL before being sent via remote write.  |
        Sample Failure Rate  |
        N/A  |
        Rate of samples that failed to be sent to remote storage due to unrecoverable errors.  |
        Sample Retry Rate  |
        N/A  |
        Rate of samples that failed to be sent to remote storage due to recoverable errors and were resent.  |
        Retry Rate of Enqueuing  |
        N/A  |
        Retry rate of enqueuing failed due to full shard queue.  |
Metric List
The following is the metric list of the Prometheus Server view.
         Metric  |
         Type  |
         Description  |
         prometheus_target_sync_length_seconds_sum  |
         Summary  |
         Collection latencies of different targets.  |
         prometheus_sd_discovered_targets  |
         Gauge  |
         The number of metrics collected by different targets.  |
         prometheus_target_interval_length_seconds_sum  |
         Summary  |
         Collection interval.  |
         prometheus_target_scrapes_exceeded_body_size_limit_total  |
         Counter  |
         prometheus_tsdb_head_samples_appended_total  |
         Counter  |
         Total number of samples added to the head.  |
         prometheus_tsdb_head_series  |
         Gauge  |
         The number of series in the head block.  |
         prometheus_tsdb_head_chunks  |
         Gauge  |
         The number of chunks in the head block.  |
         prometheus_engine_query_duration_seconds_count  |
         Counter  |
         The number of queries.  |
         prometheus_engine_query_duration_seconds  |
         Counter  |
         Time taken by queries to complete, in seconds.  |
         prometheus_remote_storage_highest_timestamp_in_seconds  |
         Gauge  |
         Latest timestamp in the remote storage.  |
         prometheus_remote_storage_queue_highest_sent_timestamp_seconds  |
         Gauge  |
         Latest timestamp in the Prometheus shard.  |
         prometheus_remote_storage_bytes_total  |
         Counter  |
         Total number of bytes of data (non-metadata) sent by the queue after compression.  |
         prometheus_remote_storage_shards  |
         Gauge  |
         prometheus_remote_storage_shards_max  |
         Gauge  |
         prometheus_remote_storage_shards_min  |
         Gauge  |
         prometheus_remote_storage_shards_desired  |
         Gauge  |
         prometheus_remote_storage_shard_capacity  |
         Gauge  |
         prometheus_remote_storage_pending_samples  |
         Gauge  |
         The number of pending samples in queue shards to be sent to remote storage.  |
         prometheus_tsdb_wal_segment_current  |
         Gauge  |
         prometheus_wal_watcher_current_segment  |
         Gauge  |
         Current segment from which the WAL is reading records.  |
         prometheus_remote_storage_dropped_samples_total  |
         Gauge  |
         prometheus_remote_storage_failed_samples_total  |
         Gauge  |
         prometheus_remote_storage_retried_samples_total  |
         Gauge  |
         The number of samples that failed to be sent to remote storage due to recoverable errors and were resent.  |
         prometheus_remote_storage_enqueue_retries_total  |
         Gauge  |
         The number of retries upon enqueuing failed due to full shard queue.  |
