PVC View
The PVC view displays the PV/PVC status and usage.
The following PVC types support usage monitoring:
- EVS PVCs (The value of volumeMode must be Filesystem.)
- Local PVCs (The Everest version installed in the cluster must be 2.4.41 or later.)
- SFS Turbo PVCs (Subdirectories generated dynamically by SFS Turbo also support usage monitoring. However, the PVC usage and capacity collected from the subdirectories are the same as those of the SFS Turbo instance).
- PVCs mounted to common containers (The usages and inodes usages can be collected for such PVCs, but not for the PVCs mounted to secure containers.)
Metric Description
You can view PVC metrics in the following table.
| Metric | Unit | Description |
| PV Status | N/A | PV status, which can be Available, Bound, Failed, Pending, or Released. |
| PVC Status | N/A | PVC status, which can be Bound, Lost, or Pending. |
| Used PVC | GiB | Used and available PVC space. |
| PVC Usage | % | Percentage of a PVC that is used. |
| Used Inodes in PVC | N/A | Used and available space of inodes in a PVC. |
| Inodes Usage in PVC | % | Percentage of inodes that are used in a PVC. |
Metric List
The following is the metric list of the PVC view.
| Metric | Type | Description |
| kubelet_volume_stats_inodes_used | Gauge | The number of used inodes in a volume. |
| kubelet_volume_stats_inodes | Gauge | Maximum number of inodes in a volume. |
| kubelet_volume_stats_capacity_bytes | Gauge | Capacity in bytes of a volume. |
| kubelet_volume_stats_available_bytes | Gauge | The number of available bytes in a volume. |
| kubelet_volume_stats_used_bytes | Gauge | The number of used bytes in a volume. |
| kube_persistentvolume_status_phase | Gauge | PV status. |
| kube_persistentvolumeclaim_status_phase | Gauge | PVC status. |
