Pod View
The pod view displays information about resources, networks, and disks, so you can better monitor a pod.
Metric Description
Pod metrics include resource metrics, network metrics, and disk metrics. You can view these metrics in the following tables.
| Metric | Unit | Description |
| Total Containers | N/A | Total number of containers in a pod. |
| Running Containers | N/A | The number of running containers in a pod. |
| Pod Status | N/A | The number of pods in different states. |
| Container Restarts | N/A | The number of container restarts. |
| Used CPU | core | CPU used by the pod. |
| CPU Efficiency & Usage | % | - Efficiency: Used CPU/CPU request - Usage: Used CPU/Total CPU |
| Used Memory | byte | Memory used by a pod. |
| Memory Efficiency & Usage | % | - Efficiency: Used memory/Memory request - Usage: Used memory/Total memory |
| CPU Throttling | % | The percentage of the CPU time that is in throttling status. |
| Receive Bandwidth | byte/s | The number of bytes received by a container per second. |
| Transmit Bandwidth | byte/s | The number of bytes sent by a container per second. |
| Rate of Received Packets | N/A | The number of packets received by a container per second. |
| Rate of Transmitted Packets | N/A | The number of packets sent by a container per second. |
| Packet Loss (Receive) | N/A | The number of packets not received by a container per second. |
| Packet Loss (Transmit) | N/A | The number of packets sent from a container but not received by the receiver per second. |
| Pod Disk I/O Rate (Read + Write) | N/A | The number of read and write operations on the disk by a pod per second. |
| Pod Disk Throughput (Read + Write) | byte/s | Total number of bytes read to or written from the disk by a pod per second. |
| Container Disk I/O Rate (Read + Write) | N/A | The number of read and write operations on the disk by a pod per second. |
| Container Disk Throughput (Read + Write) | byte/s | Total number of bytes read to and written from the disk by the pod per second. |
| File System Usage | % | The space usage of the file system. |
| File System Used | byte | The number of bytes used by the file system. |
Metric List
The following is the metric list of the pod view.
| Metric | Type | Description |
| kube_pod_container_status_running | Gauge | Whether the container is currently in the running state. |
| kube_pod_container_info | Gauge | Information about a container in a pod. |
| kube_pod_status_phase | Gauge | The current phase of a pod. |
| kube_pod_container_status_restarts_total | Counter | The number of container restarts. |
| container_cpu_usage_seconds_total | Counter | Cumulative CPU time consumed by a container, in seconds. |
| kube_pod_container_resource_requests | Gauge | The number of request resources requested by a container. |
| container_spec_cpu_quota | Gauge | CPU quota of a container. |
| container_memory_working_set_bytes | Gauge | Memory used by a container. |
| container_spec_memory_limit_bytes | Gauge | Memory limit for a container. |
| container_cpu_cfs_throttled_periods_total | Counter | The number of throttled periods. |
| container_cpu_cfs_periods_total | Counter | The number of elapsed enforcement periods. |
| container_network_receive_bytes_total | Counter | Cumulative count of bytes received by a container. |
| container_network_transmit_bytes_total | Counter | Cumulative count of bytes sent by a container. |
| container_network_receive_packets_total | Counter | Cumulative count of packets received by a container. |
| container_network_transmit_packets_total | Counter | Cumulative count of packets sent by a container. |
| container_network_receive_packets_dropped_total | Counter | Cumulative count of packets not received by a container. |
| container_network_transmit_packets_dropped_total | Counter | Cumulative count of packets sent from a container but not received by the receiver. |
| container_fs_reads_total | Counter | Cumulative count of reads completed by a container. |
| container_fs_writes_total | Counter | Cumulative count of writes completed by a container. |
| container_fs_reads_bytes_total | Counter | Cumulative count of bytes read by a container. |
| container_fs_writes_bytes_total | Counter | Cumulative count of bytes written by a container. |
| container_fs_usage_bytes | Gauge | The number of bytes that are consumed by a container on the file system. |
| container_fs_limit_bytes | Gauge | The number of bytes that can be consumed by a container on the file system. |
