Container Image Signature Verification
Introduction
The Container Image Signature Verification add-on (formerly swr-cosign) is used to sign image files and verify their integrity and authenticity. This prevents image files from being tampered with or implanted with malicious code.
Notes and Constraints
- An SWR Enterprise instance has been created before you use the image signature verification function.
Installing the Add-on
- In the navigation pane, choose Add-ons. Locate Container Image Signature Verification on the right and click Install.
- On the Install Add-on page, configure the specifications as needed.
- If you selected Preset, you can choose between Small or Large based on the cluster scale. The system will automatically set the number of add-on pods and resource quotas according to the preset specifications. You can see the configurations on the console.
The small specification specifies that the add-on runs in one pod, which is ideal for clusters with fewer than 50 concurrent image downloads. The large specification specifies that the add-on runs in two pods, which are more appropriate for clusters with fewer than 300 concurrent image downloads.
- If you selected Custom, you can adjust the number of pods and resource quotas as needed. High availability is not possible with a single pod. If an error occurs on the node where the add-on instance runs, the add-on will fail.
- Configure the add-on parameters.
Table 1 Add-on parameters Parameter
KMS key
Select a key. Only EC_P256, EC_P384, and SM2 are supported.
You can add a key using KMS.
Signature Verification Image
Enter a regular expression for the path to a signature verification image. For example, if you enter docker.io/**, the signature of the image in the docker.io image repository will be verified. To verify the signatures of all images, enter **.
- Click Install.
After the add-on is installed, select the cluster and choose Add-ons in the navigation pane. On the displayed page, view the add-on in the Add-ons Installed area.
Components
Component |
Description |
Resource Type |
swr-cosign |
swr-cosign verifies digital signatures of image files to ensure that the image files are not tampered with. |
Deployment |
How to Use
- Install the add-on and configure the KMS key and image address as instructed in Installing the Add-on.
- Add the policy.sigstore.dev/include:true label to the namespace that requires signature verification.
- In the navigation pane of the cluster console, click Namespaces.
- Locate the namespace to be verified. In the Operation column, choose More > Manage Label.
- Add a label.
- Key: policy.sigstore.dev/include
- Value: true
- Click OK.
- Check whether image signature verification is enabled.
- In the navigation pane of the cluster console, click Workloads.
- Click Create Workload in the upper right corner.
- Select the namespace where the label was added, enter the unsigned image path, and set other parameters as instructed in Creating a Deployment.
- Click Create Workload.
Unsigned images will be blocked. The following information is displayed:
admission webhook "policy.sigstore.dev" denied the request: validation failed: failed policy: cip-key-secret-match: spec.template.spec.containers[0].image ...
- Sign an image.
- Log in to the SWR enterprise repository and access an existing repository.
- In the navigation pane, choose Security > Image Signature and create a signature rule.
- Name: Name the signature rule.
- Organization: Select a container image organization.
- Application Scope:
- Image: Select the image to be signed. You can also use a regular expression to match multiple images.
- Version: Select an image version. If this parameter is left blank or set to **, all versions of the image are matched.
- Signing Method: Select KMS.
- Signature Key: Select a KMS key. The key must be the same as that used during add-on installation.
- Trigger Mode:
- Manual: After a signature rule is created, manually execute the rule to sign the image.
- Event + manual: The image can be signed by events or manually.
- Description: Enter the description of the rule.
- After the signature rule is created, click Execute to sign the selected image.
- After the image is signed, in the navigation pane, choose Artifact Repositories > Image Repositories and click the image name to view the image details. The image already has a signature attachment.
- Go back to the CCE console and check whether the signed image can be used to create a workload.
Release History
Add-on Version |
Supported Cluster Version |
New Feature |
1.0.34 |
v1.23 v1.25 v1.27 v1.28 v1.29 v1.30 v1.31 v1.32 |
Clusters v1.32 are supported. |
1.0.26 |
v1.23 v1.25 v1.27 v1.28 v1.29 v1.30 v1.31 |
Clusters v1.31 are supported. |
1.0.2 |
v1.23 v1.25 v1.27 |
Clusters v1.27 are supported. |
1.0.1 |
v1.23 v1.25 |
Supported verification of container image signatures. |
