Updated on 2025-09-04 GMT+08:00
Node Specifications
This section describes the node flavors supported by CCE and typical node features.
Node flavors vary depending on regions, and some flavors may be unavailable due to insufficient resources. To obtain available node flavors, log in to the CCE console and switch to the page for creating nodes.
In CCE Turbo clusters, pods need to occupy network interfaces or supplementary network interfaces of nodes. The number of pods you can create on a node depends on how many network interfaces that node has. You need to evaluate the number of network interfaces that can be attached to each node. For details, see Maximum Number of Pods That Can Be Created on a Node.
Node Type
Flavors
ECS (VM)
ECS running on a KVM or QingTian hypervisor. Multiple flavors are offered to meet your compute and storage needs for various applications.
x86:
Arm (Kunpeng):
Heterogeneous:
ECS (PM)
ECS running on a QingTian-backed bare-metal hypervisor. PM resources and VM resources of such an ECS are in the same resource pool and can be dynamically scheduled.
General Computing-plus ECSs
BMS
BMS offering high-performance computing at low latency for containers.
Instance Family
General computing-plus ECSs use dedicated vCPUs and next-generation network acceleration engines to provide powerful compute and network performance.
Table 1 General computing-plus ECS features
ECS Type
Network
Supported Cluster Type
C9
  • vCPU-to-memory ratio: 1:2 or 1:4
  • The number of vCPUs: 2 to 192
  • Base/Turbo frequency: 3.1 GHz/3.6 GHz
  • IPv6 access
  • Ultra-high PPS throughput
  • Higher compute specifications for better network performance
  • Maximum PPS: 40,000,000
  • Maximum intranet bandwidth: 120 Gbit/s
  • Maximum number of network connections: 10,000,000
CCE standard clusters
CCE Turbo clusters
aC8
  • Base/Turbo frequency: 2.4 GHz/3.7 GHz
  • IPv6 access
  • Maximum PPS: 20,000,000
CCE Turbo clusters
aC7
  • The number of vCPUs: 2 to 232
  • Base/Turbo frequency: 2.45 GHz/3.5 GHz
  • IPv6 access
  • Maximum intranet bandwidth: 100 Gbit/s
CCE Turbo clusters
C7t
  • The number of vCPUs: 2 to 128
  • 3rd Gen Intel® Xeon® Scalable Processor
  • Base/Turbo frequency: 2.6 GHz/3.4 GHz and 2.8 GHz/3.5 GHz
  • IPv6 access
  • Maximum PPS: 30,000,000
  • Maximum intranet bandwidth: 90 Gbit/s
CCE Turbo clusters
C7
  • Base/Turbo frequency: 3.0 GHz/3.5 GHz and 2.8 GHz/3.5 GHz
  • IPv6 access
  • Maximum PPS: 12,000,000
  • Maximum intranet bandwidth: 42 Gbit/s
CCE Turbo clusters
C6ne
  • The number of vCPUs: 2 to 64
  • 2nd Gen Intel® Xeon® Scalable Processor
  • Base/Turbo frequency: 3.0 GHz/3.4 GHz
  • Maximum PPS: 10,000,000
  • Maximum intranet bandwidth: 40 Gbit/s
CCE Turbo clusters
C6s
  • Base/Turbo frequency: 2.6 GHz/3.5 GHz
  • IPv6 access
  • Maximum PPS: 8,500,000
  • Maximum intranet bandwidth: 30 Gbit/s
C6
  • The number of vCPUs: 2 to 88
  • IPv6 access
  • Maximum intranet bandwidth: 44 Gbit/s
C3
  • The number of vCPUs: 2 to 60
  • Intel® Xeon® Scalable Processor
  • IPv6 access
  • Maximum PPS: 5,000,000
  • Maximum intranet bandwidth: 16 Gbit/s
Table 2 C9 ECS specifications
Flavor
vCPUs
Memory
(GiB)
Max./Assured Network Bandwidth
(Gbit/s)
Max. Network PPS
(10,000)
Network Connections (10,000)
Max. NIC Queues
Max. NICs
Max. Supplementary NICs
Max. EVS Disk Bandwidth (Gbit/s)
Max. EVS Disk IOPS (10,000)
Virtualization
c9.large.2
2
4
20/3
100
75
2
2
16
11
11
QingTian
c9.xlarge.2
4
8
20/5
160
200
4
3
32
11
11
c9.2xlarge.2
8
16
20/8
200
300
8
8
64
11
11
c9.4xlarge.2
16
32
30/12
350
400
16
8
128
11
11
c9.8xlarge.2
32
64
40/25
700
600
32
8
256
11
11
c9.16xlarge.2
64
128
60/40
1,400
700
64
8
256
21
23
c9.32xlarge.2
128
256
100/80
2,000
1,000
64
10
256
43
46
c9.48xlarge.2
192
376
120/102
4,000
1,000
64
12
256
64
70
c9.large.4
2
8
20/3
100
75
2
2
16
11
11
c9.xlarge.4
4
16
20/5
160
200
4
3
32
11
11
c9.2xlarge.4
8
32
20/8
200
300
8
8
64
11
11
c9.4xlarge.4
16
64
30/12
350
400
16
8
128
11
11
c9.8xlarge.4
32
128
40/25
700
600
32
8
256
11
11
c9.16xlarge.4
64
256
60/40
1,400
700
64
8
256
21
23
c9.32xlarge.4
128
512
100/80
2,000
1,000
64
10
256
43
46
c9.48xlarge.4
192
752
120/102
4,000
1,000
64
12
256
64
70
Table 3 aC8 ECS specifications
Flavor
vCPUs
Memory
(GiB)
(Gbit/s)
Max. Network PPS
(10,000)
Max. NIC Queues
Max. NICs
Max./Assured EVS Disk Bandwidth (Gbit/s)
Virtualization
ac8.large.2
2
4
20/2
90
75
2
3
8
6/0.3
5
QingTian
ac8.xlarge.2
4
8
20/3
100
150
4
3
16
6/0.5
5
ac8.2xlarge.2
8
16
20/5
160
200
8
4
32
6/1.1
5
ac8.4xlarge.2
16
32
30/8
200
300
16
4
64
6/2.1
5
ac8.8xlarge.2
32
64
40/12
350
400
32
4
128
6/4.3
5
ac8.12xlarge.2
48
96
50/18
500
500
48
4
256
8/6.4
7
ac8.16xlarge.2
64
128
60/25
700
600
64
4
256
11/8.5
10
ac8.24xlarge.2
96
192
80/35
1,000
700
64
8
256
16/13
13
ac8.32xlarge.2
128
256
100/45
1,400
800
64
10
256
21/17
17
ac8.48xlarge.2
192
384
120/65
2,000
1,000
64
12
256
32/26
25
ac8.large.4
2
8
20/2
90
75
2
3
8
6/0.3
5
QingTian
ac8.xlarge.4
4
16
20/3
100
150
4
3
16
6/0.5
5
ac8.2xlarge.4
8
32
20/5
160
200
8
4
32
6/1.1
5
ac8.4xlarge.4
16
64
30/8
200
300
16
4
64
6/2.1
5
ac8.8xlarge.4
32
128
40/12
350
400
32
4
128
6/4.3
5
ac8.12xlarge.4
48
192
50/18
500
500
48
4
256
8/6.4
7
ac8.16xlarge.4
64
256
60/25
700
600
64
4
256
11/8.5
10
ac8.24xlarge.4
96
384
80/35
800
700
64
8
256
16/13
13
ac8.32xlarge.4
128
512
100/45
1,400
800
64
10
256
21/17
17
ac8.48xlarge.4
192
768
120/65
2,000
1,000
64
12
256
32/26
25
Table 4 aC7 ECS specifications
Flavor
vCPUs
Memory
(GiB)
(Gbit/s)
Max. Network PPS
(10,000)
Network Connections
(10,000)
Max. NIC Queues
Max. NICs
Virtualization
ac7.large.2
2
4
2/1
40
75
2
2
16
5/0.2
KVM
ac7.xlarge.2
4
8
3/1.5
60
150
2
3
32
5/0.5
1.5
ac7.2xlarge.2
8
16
4/2.5
100
200
4
4
64
5/1.0
2
ac7.4xlarge.2
16
32
8/5
200
300
8
8
128
5/2.0
3
ac7.8xlarge.2
32
64
15/8
300
400
16
8
256
5/4
5
ac7.12xlarge.2
48
96
22/12
400
500
16
8
256
7.5/6
7
ac7.16xlarge.2
64
128
28/16
550
800
24
12
256
10/8
10
ac7.24xlarge.2
96
192
40/25
800
1,000
24
12
256
15/12
13
ac7.29xlarge.2
116
216
50/30
950
1,200
32
16
256
18/14
14
ac7.32xlarge.2
128
256
55/35
1,000
1,300
32
16
256
20/16
17
ac7.48xlarge.2
192
384
100/80
1,600
1,800
32
16
256
30/24
25
ac7.58xlarge.2
232
432
120/100
2,000
2,000
32
16
256
None/36
30
ac7.large.4
2
8
2/1
40
75
2
2
16
5/0.2
ac7.xlarge.4
4
16
3/1.5
60
150
2
3
32
5/0.5
1.5
ac7.2xlarge.4
8
32
4/2.5
100
200
4
4
64
5/1.0
2
ac7.4xlarge.4
16
64
8/5
200
300
8
8
128
5/2.0
3
ac7.8xlarge.4
32
128
15/8
300
400
16
8
256
5/4
5
ac7.12xlarge.4
48
192
22/12
400
500
16
8
256
7.5/6
7
ac7.16xlarge.4
64
256
28/16
550
800
24
12
256
10/8
10
ac7.24xlarge.4
96
384
40/25
800
1,000
24
12
256
15/12
13
ac7.29xlarge.4
116
464
50/30
950
1,200
32
16
256
18/14
14
ac7.32xlarge.4
128
512
55/35
1,000
1,300
32
16
256
20/16
17
ac7.48xlarge.4
192
768
100/80
1,600
1,800
32
16
256
30/24
25
ac7.58xlarge.4
232
928
120/100
2,000
2,000
32
16
256
None/36
30
Table 5 C7t ECS specifications
Flavor
vCPUs
Memory
(GiB)
(Gbit/s)
Max. Network PPS
(10,000)
Network Connections
(10,000)
Max. NIC Queues
Max. NICs
(Gbit/s)
Virtualization
c7t.large.2
2
4
10/1.28
80
50
2
2
16
6/1.5
16
QingTian
c7t.xlarge.2
4
8
16/2.56
150
50
2
3
32
6/2
16
c7t.2xlarge.2
8
16
20/4
200
100
4
4
64
6/3
16
c7t.3xlarge.2
12
24
34/6.4
300
150
4
6
96
6/4
16
c7t.4xlarge.2
16
32
40/8
400
150
8
8
128
6/5
16
c7t.6xlarge.2
24
48
50/14.4
600
200
8
8
192
None/6
16
c7t.8xlarge.2
32
64
60/16
800
300
16
8
256
None/8
16
c7t.12xlarge.2
48
96
70/28.8
1,200
400
16
8
256
None/10
16
c7t.16xlarge.2
64
128
72/32
1,500
500
28
8
256
None/16
16
c7t.24xlarge.2
96
192
80/40
2,400
800
32
8
256
None/20
22.5
c7t.32xlarge.2
128
256
90/48
3,000
1,000
32
8
256
None/24
30
c7t.large.4
2
8
10/1.28
80
50
2
2
16
6/1.5
16
QingTian
c7t.xlarge.4
4
16
16/2.56
150
50
2
3
32
6/2
16
c7t.2xlarge.4
8
32
20/4
200
100
4
4
64
6/3
16
c7t.3xlarge.4
12
48
34/6.4
300
150
4
6
96
6/4
16
c7t.4xlarge.4
16
64
40/8
400
150
8
8
128
6/5
16
c7t.6xlarge.4
24
96
50/14.4
600
200
8
8
192
None/6
16
c7t.8xlarge.4
32
128
60/16
800
300
16
8
256
None/8
16
c7t.12xlarge.4
48
192
70/28.8
1,200
400
16
8
256
None/10
16
c7t.16xlarge.4
64
256
72/32
1,500
500
28
8
256
None/16
16
c7t.24xlarge.4
96
384
80/40
2,400
800
32
8
256
None/20
22.5
c7t.32xlarge.4
128
512
90/48
3,000
1,000
32
8
256
None/24
30
Table 6 C7 ECS specifications
Flavor
vCPUs
Memory
(GiB)
(Gbit/s)
Max. Network PPS
(10,000)
Network Connections
(10,000)
Max. NIC Queues
Max. NICs
(Gbit/s)
Virtualization
c7.large.2
2
4
4/0.64
40
50
2
2
16
6/1
16
QingTian
c7.xlarge.2
4
8
8/1.28
80
50
2
3
32
6/1.5
16
c7.2xlarge.2
8
16
15/2.4
150
100
4
4
64
6/2
16
c7.3xlarge.2
12
24
17/4
200
150
4
6
96
6/3
16
c7.4xlarge.2
16
32
20/4.8
280
150
8
8
128
6/4
16
c7.6xlarge.2
24
48
25/7.2
400
200
8
8
192
6/5
16
c7.8xlarge.2
32
64
30/9.6
550
300
16
8
256
None/6
16
c7.12xlarge.2
48
96
35/14.4
750
400
16
8
256
None/8
16
c7.16xlarge.2
64
128
36/19.2
1,000
500
28
8
256
None/12
16
c7.24xlarge.2
96
192
40/28.8
1,100
800
32
8
256
None/16
22.5
c7.32xlarge.2
128
256
42/32
1,200
1,000
32
8
256
None/24
30
c7.large.4
2
8
4/0.64
40
50
2
2
16
6/1
16
c7.xlarge.4
4
16
8/1.28
80
50
2
3
32
6/1.5
16
c7.2xlarge.4
8
32
15/2.4
150
100
4
4
64
6/2
16
c7.3xlarge.4
12
48
17/4
200
150
4
6
96
6/3
16
c7.4xlarge.4
16
64
20/4.8
280
150
8
8
128
6/4
16
c7.6xlarge.4
24
96
25/7.2
400
200
8
8
192
6/5
16
c7.8xlarge.4
32
128
30/9.6
550
300
16
8
256
None/6
16
c7.12xlarge.4
48
192
35/14.4
750
400
16
8
256
None/8
16
c7.16xlarge.4
64
256
36/19.2
1,000
500
28
8
256
None/12
16
c7.24xlarge.4
96
384
40/28.8
1,100
800
32
8
256
None/16
22.5
c7.32xlarge.4
128
512
42/32
1,200
1,000
32
8
256
None/24
30
Table 7 C6ne ECS specifications
Flavor
vCPUs
Memory
(GiB)
Max./Assured Bandwidth
(Gbit/s)
Max. PPS
(10,000)
Max. Network Interface Queues
Max. Network Interfaces
Max. Supplementary Network Interfaces
c6ne.large.2
2
4
4/1.2
40
2
2
16
c6ne.large.4
2
8
4/1.2
40
2
2
16
c6ne.xlarge.2
4
8
8/2.4
80
2
3
32
c6ne.xlarge.4
4
16
8/2.4
80
2
3
32
c6ne.2xlarge.2
8
16
15/4.5
150
4
4
64
c6ne.2xlarge.4
8
32
15/4.5
150
4
4
64
c6ne.3xlarge.2
12
24
17/7
200
4
6
96
c6ne.3xlarge.4
12
48
17/7
200
4
6
96
c6ne.4xlarge.2
16
32
20/9
280
8
8
128
c6ne.4xlarge.4
16
64
20/9
280
8
8
128
c6ne.6xlarge.2
24
48
25/14
400
8
8
192
c6ne.6xlarge.4
24
96
25/14
400
8
8
192
c6ne.8xlarge.2
32
64
30/18
550
16
8
256
c6ne.8xlarge.4
32
128
30/18
550
16
8
256
c6ne.12xlarge.2
48
96
35/27
750
16
8
256
c6ne.12xlarge.4
48
192
35/27
750
16
8
256
c6ne.16xlarge.2
64
128
40/36
1,000
32
8
256
c6ne.16xlarge.4
64
256
40/36
1,000
32
8
256
Table 8 C6s ECS specifications
Flavor
vCPUs
Memory
(GiB)
(Gbit/s)
Max. Network PPS
(10,000)
Network Connections
(10,000)
Max. NIC Queues
Max. NICs
Virtualization
c6s.large.2
2
4
1/1
30
50
2
2
1.5
KVM
c6s.xlarge.2
4
8
2/2
60
50
2
3
2
2
KVM
c6s.2xlarge.2
8
16
4/4
120
100
4
4
3
2.5
KVM
c6s.3xlarge.2
12
24
5.5/5.5
180
150
4
6
4
3
KVM
c6s.4xlarge.2
16
32
7.5/7.5
240
150
8
8
5
4
KVM
c6s.6xlarge.2
24
48
11/11
350
200
8
8
7.5
5
KVM
c6s.8xlarge.2
32
64
15/15
450
300
16
8
10
6
KVM
c6s.12xlarge.2
48
96
22/22
650
400
16
8
15
10
KVM
c6s.16xlarge.2
64
128
30/30
850
500
32
8
20
15
KVM
c6s.large.4
2
8
1/1
30
50
2
2
1.5
KVM
c6s.xlarge.4
4
16
2/2
60
50
2
3
2
2
KVM
c6s.2xlarge.4
8
32
4/4
120
100
4
4
3
2.5
KVM
c6s.3xlarge.4
12
48
5.5/5.5
180
150
4
6
4
3
KVM
c6s.4xlarge.4
16
64
7.5/7.5
240
150
8
8
5
4
KVM
c6s.6xlarge.4
24
96
11/11
350
200
8
8
7.5
5
KVM
c6s.8xlarge.4
32
128
15/15
450
300
16
8
10
6
KVM
c6s.12xlarge.4
48
192
22/22
650
400
16
8
15
10
KVM
c6s.16xlarge.4
64
256
30/30
850
500
32
8
20
15
KVM
Table 9 C3 ECS specifications
Flavor
vCPUs
Memory
(GiB)
(Gbit/s)
Max. Network PPS
(10,000)
Max. NIC Queues
Basic EVS Disk Bandwidth
(Gbit/s)
Virtualization
c3.large.2
2
4
1.5/0.6
30
2
KVM
c3.xlarge.2
4
8
3/1
50
2
1.5
KVM
c3.2xlarge.2
8
16
5/2
90
4
2
KVM
c3.3xlarge.2
12
24
7/3
110
4
2.5
KVM
c3.4xlarge.2
16
32
10/4
130
4
3
KVM
c3.6xlarge.2
24
48
12/6
200
8
3.5
KVM
c3.8xlarge.2
32
64
15/8
260
8
4
KVM
c3.15xlarge.2
60
128
16/16
500
16
8
KVM
c3.large.4
2
8
1.5/0.6
30
2
KVM
c3.xlarge.4
4
16
3/1
50
2
1.5
KVM
c3.2xlarge.4
8
32
5/2
90
4
2
KVM
c3.3xlarge.4
12
48
7/3
110
4
2.5
KVM
c3.4xlarge.4
16
64
10/4
130
4
3
KVM
c3.6xlarge.4
24
96
12/6
200
8
3.5
KVM
c3.8xlarge.4
32
128
15/8
260
8
4
KVM
c3.15xlarge.4
60
256
16/16
500
16
8
KVM
General Computing ECSs
General computing ECSs provide a balance of compute, memory, and networking resources and a baseline level of vCPU performance with the ability to burst above the baseline.
Table 10 General computing ECS features
ECS Type
Network
S7n
  • vCPU-to-memory ratio: 1:1, 1:2, or 1:4
  • The number of vCPUs: 1 to 8
  • IPv6 access
  • Maximum PPS: 500,000
  • Maximum intranet bandwidth: 3 Gbit/s
  • Maximum number of network connections: 300,000
CCE Turbo clusters
S7
  • Base/Turbo frequency: 2.8 GHz/3.5 GHz
  • IPv6 access
CCE Turbo clusters
S6
  • IPv6 access
Sn3
  • The number of vCPUs: 2 to 16
  • Base/Turbo frequency: 2.2 GHz/3.0 GHz
S3
  • Maximum PPS: 300,000
  • Maximum intranet bandwidth: 4 Gbit/s
S2
  • The number of vCPUs: 2 to 32
  • Intel® Xeon® Processor E5 v4 Family
  • Base/Turbo frequency: 2.4 GHz/3.3 GHz
  • Maximum intranet bandwidth: 6 Gbit/s
Table 11 S7n ECS specifications
Flavor
vCPUs
Memory
(GiB)
(Gbit/s)
Max. PPS
(10,000)
Network Connections
(10,000)
Virtualization
s7n.large.2
2
4
1.5/0.2
15
30
8
KVM
s7n.xlarge.2
4
8
2/0.35
25
30
16
KVM
s7n.2xlarge.2
8
16
3/0.75
50
30
2
2
32
KVM
s7n.large.4
2
8
1.5/0.2
15
30
8
KVM
s7n.xlarge.4
4
16
2/0.35
25
30
16
KVM
s7n.2xlarge.4
8
32
3/0.75
50
30
2
2
32
KVM
Table 12 S7 ECS specifications
Flavor
vCPUs
Memory
(GiB)
(Gbit/s)
Max. PPS
(10,000)
Virtualization
s7.large.2
2
4
1.5/0.2
15
8
KVM
s7.xlarge.2
4
8
2/0.35
25
16
KVM
s7.2xlarge.2
8
16
3/0.75
50
2
2
32
KVM
s7.large.4
2
8
1.5/0.2
15
8
KVM
s7.xlarge.4
4
16
2/0.35
25
16
KVM
s7.2xlarge.4
8
32
3/0.75
50
2
2
32
KVM
Table 13 S6 ECS specifications
Flavor
vCPUs
Memory
(GiB)
(Gbit/s)
Max. PPS
(10,000)
Virtualization
s6.large.2
2
4
1.5/0.2
15
KVM
s6.xlarge.2
4
8
2/0.35
25
KVM
s6.2xlarge.2
8
16
3/0.75
50
2
2
KVM
s6.large.4
2
8
1.5/0.2
15
KVM
s6.xlarge.4
4
16
2/0.35
25
KVM
s6.2xlarge.4
8
32
3/0.75
50
2
2
KVM
Table 14 Sn3 ECS specifications
Flavor
vCPUs
Memory
(GiB)
(Gbit/s)
Max. PPS
(10,000)
Virtualization
sn3.large.2
2
4
1.5/0.35
15
KVM
sn3.xlarge.2
4
8
2/0.7
25
KVM
sn3.2xlarge.2
8
16
3/1.3
50
2
2
KVM
sn3.4xlarge.2
16
32
6/2.5
100
4
2
KVM
sn3.large.4
2
8
1.5/0.35
15
KVM
sn3.xlarge.4
4
16
2/0.7
25
KVM
sn3.2xlarge.4
8
32
3/1.3
50
2
2
KVM
sn3.4xlarge.4
16
64
6/2.5
100
4
2
KVM
Table 15 S3 ECS specifications
Flavor
vCPUs
Memory
(GiB)
(Gbit/s)
Max. PPS
(10,000)
Virtualization
s3.large.2
2
4
0.8/0.2
10
KVM
s3.xlarge.2
4
8
1.5/0.4
15
KVM
s3.2xlarge.2
8
16
3/0.8
20
2
KVM
s3.4xlarge.2
16
32
4/1.5
30
4
KVM
s3.large.4
2
8
0.8/0.2
10
KVM
s3.xlarge.4
4
16
1.5/0.4
15
KVM
s3.2xlarge.4
8
32
3/0.8
20
2
KVM
s3.4xlarge.4
16
64
4/1.5
30
4
KVM
Table 16 S2 ECS specifications
Flavor
vCPUs
Memory
(GiB)
(Gbit/s)
Max. PPS
(10,000)
Virtualization
s2.large.2
2
4
0.8/0.2
10
KVM
s2.xlarge.2
4
8
1.5/0.4
15
KVM
s2.2xlarge.2
8
16
3/0.8
20
2
KVM
s2.4xlarge.2
16
32
4/1.5
30
4
KVM
s2.8xlarge.2
32
64
6/3
50
8
KVM
s2.large.4
2
8
0.8/0.2
10
KVM
s2.xlarge.4
4
16
1.5/0.4
15
KVM
s2.2xlarge.4
8
32
3/0.8
20
2
KVM
s2.4xlarge.4
16
64
4/1.5
30
4
KVM
s2.8xlarge.4
32
128
6/3
50
8
KVM
Memory-optimized ECSs
Memory-optimized ECSs have a large memory and provide high memory performance. They are designed for memory-intensive applications that process a large amount of data.
Table 17 Memory-optimized ECS features
ECS Type
Network
M7
  • vCPU-to-memory ratio: 1:8
  • IPv6 access
CCE Turbo clusters
M6ne
CCE Turbo clusters
M6
  • IPv6 access
M3
  • IPv6 access
  • Maximum intranet bandwidth: 17 Gbit/s
Table 18 M6ne ECS specifications
Flavor
vCPUs
Memory
(GiB)
(Gbit/s)
Max. PPS
(10,000)
m6ne.large.8
2
16
4/1.2
40
2
2
16
m6ne.xlarge.8
4
32
8/2.4
80
2
3
32
m6ne.2xlarge.8
8
64
15/4.5
150
4
4
64
m6ne.3xlarge.8
12
96
17/7
200
4
6
96
m6ne.4xlarge.8
16
128
20/9
280
8
8
128
m6ne.6xlarge.8
24
192
25/14
400
8
8
192
m6ne.8xlarge.8
32
256
30/18
550
16
8
256
m6ne.16xlarge.8
64
512
40/36
1000
32
8
256
Table 19 M6 ECS specifications
Flavor
vCPUs
Memory
(GiB)
(Gbit/s)
PPS
(10,000)
Network Connections
(10,000)
Max. NIC Queues
Max. NICs
(Gbit/s)
Virtualization
m6.large.8
2
16
4/1.2
40
50
2
2
5/1
KVM
m6.xlarge.8
4
32
8/2.4
80
50
2
3
5/1.5
2
KVM
m6.2xlarge.8
8
64
15/4.5
150
100
4
4
5/2
2.5
KVM
m6.3xlarge.8
12
96
17/7
200
150
4
6
5/2.5
3
KVM
m6.4xlarge.8
16
128
20/9
280
150
8
8
5/3.5
4
KVM
m6.6xlarge.8
24
192
25/14
400
200
8
8
5/4
5
KVM
m6.8xlarge.8
32
256
30/18
550
300
16
8
10/7
6
KVM
m6.12xlarge.8
48
384
35/27
750
400
16
8
15/10
10
KVM
m6.16xlarge.8
64
512
40/36
1,000
500
32
8
None/20
15
KVM
m6.22xlarge.8.physical
88
768
40/40
1,000
1,000
16
33
None/20
20
Bare metal
Table 20 M3 ECS specifications
Flavor
vCPUs
Memory
(GiB)
(Gbit/s)
(Gbit/s)
PPS
(10,000)
Max. NIC Queues
(Gbit/s)
Virtualization
m3.large.8
2
16
1.5/0.6
2
KVM
m3.xlarge.8
4
32
3/1.1
1.5
50
2
1.5
KVM
m3.2xlarge.8
8
64
5/2
2
90
4
2
KVM
m3.3xlarge.8
12
96
8/3.5
2.5
110
4
2.5
KVM
m3.4xlarge.8
16
128
10/4.5
3
130
4
3
KVM
m3.6xlarge.8
24
192
12/6.5
3.5
200
8
3.5
KVM
m3.8xlarge.8
32
256
15/9
4
260
8
4
KVM
m3.15xlarge.8
60
512
17/17
8
500
16
8
KVM
General Computing-Basic ECSs
General computing-basic ECSs are suitable for scenarios that require moderate CPU performance generally but burstable high performance occasionally while keeping costs low. The performance of such ECSs is constrained by the baseline performance and CPU credits. There are no additional charges for using CPU credits. For details, see CPU Credits.
Table 21 General computing-basic ECS features
ECS Type
Network
T6
  • Maximum PPS: 600,000
Table 22 T6 ECS specifications
Flavor
vCPUs
Memory
(GiB)
CPU Baseline (%)
Average CPU Baseline (%)
(Gbit/s)
Max. PPS
(10,000)
Virtualization
t6.xlarge.1
4
4
80
20
1/0.2
20
2
KVM
t6.2xlarge.1
8
8
120
15
2/0.4
40
2
KVM
t6.4xlarge.1
16
16
240
15
3/0.8
60
2
KVM
t6.large.2
2
4
40
20
0.5/0.1
10
KVM
t6.xlarge.2
4
8
80
20
1/0.2
20
2
KVM
t6.2xlarge.2
8
16
120
15
2/0.4
40
2
KVM
t6.4xlarge.2
16
32
240
15
3/0.8
60
2
KVM
t6.large.4
2
8
40
20
0.5/0.1
10
KVM
t6.xlarge.4
4
16
80
20
1/0.2
20
2
KVM
t6.2xlarge.4
8
32
120
15
2/0.4
40
2
KVM
GPU-accelerated ECSs
GPU-accelerated ECSs provide outstanding floating-point computing capabilities. They are suitable for applications that require real-time, highly concurrent massive computing.
GPU-accelerated ECSs are classified as G series and P series ECSs.
  • G series: Graphics-accelerated ECSs, which are suitable for 3D animation rendering and CAD
  • P series: Computing-accelerated or inference-accelerated ECSs, which are suitable for deep learning, scientific computing, and CAE
Table 23 GPU-accelerated ECSs
Classification
ECS Type
GPU
CUDA Cores per GPU
Single-GPU Performance
Application
G6ne
NVIDIA T4 (GPU passthrough)
2560
  • 8.1 TFLOPS of single-precision floating-point computing
  • 130 INT8 TOPS
  • 260 INT4 TOPS
Cloud desktop, image rendering, 3D visualization, and heavy-load graphics design
CCE Turbo clusters
G6
2560
  • 130 INT8 TOPS
  • 260 INT4 TOPS
G5
NVIDIA V100 (GPU passthrough)
5120
  • 14 TFLOPS of single-precision floating-point computing
  • 7 TFLOPS of double-precision floating-point computing
  • 112 TFLOPS Tensor Cores for deep learning acceleration
P2s
NVIDIA V100
5120
AI deep learning training, scientific computing, computational fluid dynamics, computational finance, seismic analysis, molecular modeling, and genomics
P2v
NVIDIA V100 NVLink (GPU passthrough)
5120
  • 15.7 TFLOPS of single-precision floating-point computing
  • 7.8 TFLOPS of double-precision floating-point computing
  • 125 TFLOPS Tensor Cores for deep learning acceleration
  • 300 GiB/s NVLink
Machine learning, deep learning, inference training, scientific computing, seismic analysis, computational finance, rendering, multimedia encoding and decoding
Inference-accelerated
Pi2ne
2560
  • 130 INT8 TOPS
  • 260 INT4 TOPS
CCE Turbo clusters
Pi2
2560
  • 130 INT8 TOPS
  • 260 INT4 TOPS
Pi1
NVIDIA P4 (GPU passthrough)
2560
5.5 TFLOPS of single-precision floating-point computing
Table 24 P2v ECS specifications
Flavor
vCPUs
Memory
(GiB)
Max./Assured Network Bandwidth (Gbit/s)
Max. Network PPS (10,000)
Max. NIC Queues
Max. NICs
GPUs
GPU Connection
GPU Memory
(GiB)
Virtualization
p2v.2xlarge.8
8
64
10/4
50
4
4
1 × V100
N/A
1 × 16 GiB
KVM
p2v.4xlarge.8
16
128
15/8
100
8
8
2 × V100
NVLink
2 × 16 GiB
KVM
p2v.8xlarge.8
32
256
25/15
200
16
8
4 × V100
NVLink
4 × 16 GiB
KVM
p2v.16xlarge.8
64
512
30/30
400
32
8
8 × V100
NVLink
8 × 16 GiB
KVM
Disk-intensive ECSs
Disk-intensive ECSs are delivered with local disks for high storage bandwidth and IOPS. Local disks are more cost-effective in massive data storage scenarios.
Table 25 Disk-intensive ECS features
ECS Type
Network
D7
  • vCPU-to-memory ratio: 1:4
  • The number of vCPUs: 4 to 72
CCE Turbo clusters
D6
  • Maximum PPS: 9,000,000
CCE Turbo clusters
D3
  • vCPU-to-memory ratio: 1:8 or 1:10
  • The number of vCPUs: 4 to 56
CCE Turbo clusters
Table 26 D7 ECS specifications
Flavor
vCPUs
Memory
(GiB)
(Gbit/s)
Max. Network PPS
(10,000)
Network Connections
(10,000)
Max. NIC Queues
Max. NICs
Local Disks
(GiB)
Virtualization
d7.xlarge.4
4
16
5/1.7
60
50
2
3
32
2 × 3,600
KVM
d7.2xlarge.4
8
32
10/3.5
120
100
4
4
64
4 × 3,600
KVM
d7.4xlarge.4
16
64
20/6.7
240
150
4
6
96
8 × 3,600
KVM
d7.6xlarge.4
24
96
25/10
350
200
8
8
128
12 × 3,600
KVM
d7.8xlarge.4
32
128
30/13.5
450
300
8
8
192
16 × 3,600
KVM
d7.12xlarge.4
48
192
40/20
650
400
16
8
256
24 × 3,600
KVM
d7.16xlarge.4
64
256
42/27
850
500
16
8
256
32 × 3,600
KVM
Table 27 D6 ECS specifications
Flavor
vCPUs
Memory
(GiB)
(Gbit/s)
Max. Network PPS
(10,000)
Network Connections
(10,000)
Max. NIC Queues
Max. NICs
Local Disks
(GiB)
Virtualization
d6.xlarge.4
4
16
5/2
60
50
2
3
2 × 3,600
KVM
d6.2xlarge.4
8
32
10/4
120
100
4
4
4 × 3,600
KVM
d6.4xlarge.4
16
64
20/7.5
240
150
8
8
8 × 3,600
KVM
d6.6xlarge.4
24
96
25/11
350
200
8
8
12 × 3,600
KVM
d6.8xlarge.4
32
128
30/15
450
300
16
8
16 × 3,600
KVM
d6.12xlarge.4
48
192
40/22
650
400
16
8
24 × 3,600
KVM
d6.16xlarge.4
64
256
42/30
850
500
32
8
32 × 3,600
KVM
d6.18xlarge.4
72
288
44/34
900
700
32
8
36 × 3,600
KVM
Table 28 D3 ECS specifications
Flavor
vCPUs
Memory
(GiB)
(Gbit/s)
Max. Network PPS
(10,000)
Max. NIC Queues
Max. NICs
Local Disks
(GiB)
Virtualization
d3.xlarge.8
4
32
2.5/2.5
50
2
3
2 × 1,675
KVM
d3.2xlarge.8
8
64
5/5
100
2
4
4 × 1,675
KVM
d3.4xlarge.8
16
128
10/10
120
4
8
8 × 1,675
KVM
d3.6xlarge.8
24
192
15/15
160
6
8
12 × 1,675
KVM
d3.8xlarge.8
32
256
20/20
200
8
8
16 × 1,675
KVM
d3.12xlarge.8
48
384
32/32
220
16
8
24 × 1,675
KVM
d3.14xlarge.10
56
560
40/40
500
16
8
28 × 1,675
KVM
Kunpeng General Computing-plus ECSs
Kunpeng general computing-plus ECSs use Kunpeng processors to provide powerful compute and high-performance network, meeting enterprise requirements for cost-effective, secure, reliable cloud services.
Table 29 Kunpeng general computing-plus ECS features
ECS Type
Network
kC2
  • The number of vCPUs: 1 to 160
  • New Kunpeng 920 processor
  • Base frequency: 2.9 GHz
  • Maximum intranet bandwidth: 102 Gbit/s
CCE Turbo clusters
kC1
  • Kunpeng 920 processor
  • Base frequency: 2.6 GHz
  • Maximum PPS: 4,000,000
kC1n
  • The number of vCPUs: 8 to 48
  • IPv6 access
  • Maximum PPS: 3,500,000
  • Maximum intranet bandwidth: 25 Gbit/s
CCE Turbo clusters
Table 30 kC2 ECS specifications
Flavor
vCPUs
Memory
(GiB)
(Gbit/s)
Max. PPS
(10,000)
Virtualization
kc2.large.2
2
4
10/2
90
2
3
16
QingTian-backed simplified, proprietary virtualization
kc2.xlarge.2
4
8
10/4
100
4
3
32
kc2.2xlarge.2
8
16
15/8
200
8
4
64
kc2.3xlarge.2
12
24
20/10
300
12
4
96
kc2.4xlarge.2
16
32
30/15
400
16
6
128
kc2.6xlarge.2
24
48
40/20
600
24
6
192
kc2.8xlarge.2
32
64
50/25
800
32
6
256
kc2.10xlarge.2
40
80
60/30
1,000
40
6
256
kc2.12xlarge.2
48
96
80/40
1,200
48
6
256
kc2.16xlarge.2
64
128
90/50
1,600
64
6
256
kc2.20xlarge.2
80
160
102/60
2,000
64
8
256
kc2.24xlarge.2
96
192
102/80
2,400
64
8
256
kc2.32xlarge.2
128
256
102/90
3,200
64
8
256
kc2.40xlarge.2
160
320
102/102
4,000
64
15
256
kc2.large.4
2
8
10/2
90
2
3
16
kc2.xlarge.4
4
16
10/4
100
4
3
32
kc2.2xlarge.4
8
32
15/8
200
8
4
64
kc2.3xlarge.4
12
48
20/10
300
12
4
96
kc2.4xlarge.4
16
64
30/15
400
16
6
128
kc2.6xlarge.4
24
96
40/20
600
24
6
192
kc2.8xlarge.4
32
128
50/25
800
32
6
256
kc2.10xlarge.4
40
160
60/30
1,000
40
6
256
kc2.12xlarge.4
48
192
80/40
1,200
48
6
256
kc2.16xlarge.4
64
256
90/50
1,600
64
6
256
kc2.20xlarge.4
80
320
102/60
2,000
64
8
256
kc2.24xlarge.4
96
384
102/80
2,400
64
8
256
kc2.32xlarge.4
128
512
102/90
3,200
64
8
256
kc2.40xlarge.4
160
640
102/102
4,000
64
15
256
Kunpeng Memory-optimized ECSs
Kunpeng memory-optimized ECSs use Kunpeng 920 processors and 25GE high-speed intelligent network interfaces to provide up to 480-GiB DDR4 memory with high network performance for large in-memory datasets.
Table 31 Kunpeng memory-optimized ECS features
ECS Type
Network
kM2
  • The number of vCPUs: 2 to 96
  • Maximum PPS: 24,000,000
CCE Turbo clusters
kM1
Table 32 kM1 ECS specifications
Flavor
vCPUs
Memory
(GiB)
(Gbit/s)
Max. Network PPS
(10,000)
Max. NIC Queues
Max. NICs
Virtualization
km1.large.8
2
16
3/0.8
30
2
2
KVM
km1.xlarge.8
4
32
5/1.5
50
2
3
KVM
km1.2xlarge.8
8
64
7/3
80
4
4
KVM
km1.3xlarge.8
12
96
9/4.5
110
4
5
KVM
km1.4xlarge.8
16
128
12/6
140
4
6
KVM
km1.6xlarge.8
24
192
15/8
200
8
6
KVM
km1.8xlarge.8
32
256
18/10
260
8
6
KVM
km1.12xlarge.8
48
384
25/16
350
16
8
KVM
km1.15xlarge.8
60
480
30/20
400
16
8
KVM
Kunpeng Ultra-high I/O ECSs
Kunpeng ultra-high I/O ECSs use Kunpeng 920 processors and 25GE high-speed intelligent NICs to provide up to 480 GiB DDR4-based memory with high network performance for large in-memory datasets.
Table 33 Kunpeng ultra-high I/O ECS features
ECS Type
Network
kI1
  • The number of vCPUs: 8 to 64
Table 34 kI1 ECS specifications
Flavor
vCPUs
Memory
(GiB)
(Gbit/s)
Max. Network PPS
(10,000)
Max. NICs
Max. NIC Queues
Local Disks
Virtualization
ki1.2xlarge.4
8
32
7/3
80
4
4
1 × 3,200 GiB
KVM
ki1.4xlarge.4
16
64
12/6
140
6
4
2 × 3,200 GiB
KVM
ki1.6xlarge.4
24
96
15/8.5
200
6
8
3 × 3,200 GiB
KVM
ki1.8xlarge.4
32
128
18/10
260
6
8
4 × 3,200 GiB
KVM
ki1.12xlarge.4
48
192
25/16
350
6
16
6 × 3,200 GiB
KVM
ki1.16xlarge.4
64
228
30/20
400
6
16
8 × 3,200 GiB
KVM
Ultra-high I/O ECSs
Ultra-high I/O ECSs use high-performance local NVMe SSDs to provide high storage IOPS and low read/write latency.
Table 35 Ultra-high I/O ECS features
ECS Type
Network
Ir7
  • 3rd Gen Intel® Xeon® Platinum Scalable Processor
  • Maximum PPS: 6,000,000
CCE Turbo clusters
I7
  • The number of vCPUs: 8 to 96
  • Maximum PPS: 8,000,000
CCE Turbo clusters
Ir3
  • Maximum PPS: 5,500,000
I3
Table 36 I7 ECS specifications
Flavor
vCPUs
Memory
(GiB)
(Gbit/s)
Max. Network PPS
(10,000)
Network Connections
(10,000)
Max. NIC Queues
Max. NICs
Local Disks
(GiB)
Virtualization
i7.2xlarge.4
8
32
10/3
120
100
4
4
64
1 × 1,600 GiB NVMe
KVM
i7.4xlarge.4
16
64
15/6
200
150
4
6
96
2 × 1,600 GiB NVMe
KVM
i7.8xlarge.4
32
128
25/12
400
300
8
8
192
4 × 1,600 GiB NVMe
KVM
i7.12xlarge.4
48
192
30/18
500
400
16
8
256
6 × 1,600 GiB NVMe
KVM
i7.16xlarge.4
64
256
35/24
600
500
16
8
256
8 × 1,600 GiB NVMe
KVM
i7.24xlarge.4
96
384
44/36
800
800
32
8
256
12 × 1,600 GiB NVMe
KVM
i7.2xlarge.8
8
64
10/3
120
100
4
4
64
1 × 1,600 GiB NVMe
KVM
i7.4xlarge.8
16
128
15/6
200
150
4
6
96
2 × 1,600 GiB NVMe
KVM
i7.8xlarge.8
32
256
25/12
400
300
8
8
192
4 × 1,600 GiB NVMe
KVM
i7.12xlarge.8
48
384
30/18
500
400
16
8
256
6 × 1,600 GiB NVMe
KVM
i7.16xlarge.8
64
512
35/24
600
500
16
8
256
8 × 1,600 GiB NVMe
KVM
i7.24xlarge.8
96
768
44/36
800
800
32
8
256
12 × 1,600 GiB NVMe
KVM
FlexusX Instances
FlexusX instances are next-generation cloud servers that offer flexible computing for small and medium-sized enterprises and developers. They allow for flexible configuration of vCPU-to-memory ratios, so you can choose the appropriate flavors based on your service resource needs to minimize resource overhead.
Table 37 FlexusX instance features
Flavor
FlexusX1
  • vCPU-to-memory ratio: FlexusX instances allow you to flexibly configure vCPU-to-memory ratios, so you can choose the appropriate flavors based on your service resource needs to minimize resource overhead.
  • Maximum vCPUs or memory: 1 to 16 for vCPUs, and 1 GiB to 128 GiB for memory
CCE Turbo clusters
FlexusX1e
  • Maximum vCPUs or memory: 2 to 32 for vCPUs, and 2 GiB to 256 GiB for memory
CCE Turbo clusters
Table 38 FlexusX1 instance specifications
vCPUs
Assured/Max. Bandwidth (Gbit/s)
Max. PPS (10,000)
2
0.2/2
30
2
2
8
4
0.4/3
50
2
2
16
6
0.6/4
60
2
2
24
8
0.8/6
80
2
2
32
12
1.2/8
90
4
3
48
16
1.6/12
100
4
3
64
Table 39 FlexusX1e instance specifications
vCPUs
Max. PPS (10,000)
2
1/2
40
2
2
16
4
1.5/3
60
2
3
32
8
2.5/6
100
4
4
64
12
4/8
150
4
6
96
16
5/12
200
8
8
128
20
5/13
220
8
8
128
24
6/14
250
8
8
192
28
6/15
280
8
8
192
32
8/16
300
16
8
256
AI-accelerated ECSs
AI-accelerated ECSs are dedicated for accelerating AI applications. These ECSs use Ascend processors that feature low power consumption, high compute capabilities, and significantly improved energy efficiency for AI inference and video encoding and decoding.
AI-accelerated ECSs are classified as kAi series and Ai series ECSs.
  • kAi series: Arm ECSs, which use Kunpeng 920 processors
  • AI series: x86 ECSs, which use Intel Xeon processors
Table 40 AI-accelerated ECS features
ECS Type
Network
kAi1s
  • vCPU-to-memory ratio: 1:1 or 1:2
  • The number of vCPUs: 4 to 48
  • Maximum intranet bandwidth: 20 Gbit/s
Ai1s
  • Maximum PPS: 2,000,000
Ai2
  • The number of vCPUs: 4 to 96
CCE Turbo clusters
Ai1
Table 41 kAi1s ECS specifications
Flavor
vCPUs
Memory
(GiB)
Max. PPS
(10,000)
Ascend 310
Virtualization
kai1s.xlarge.1
4
4
3/0.8
20
2
2
KVM
kai1s.2xlarge.1
8
8
4/1.5
40
2
3
2
KVM
kai1s.4xlarge.1
16
16
6/3
80
4
4
4
KVM
kai1s.3xlarge.2
12
24
8/4
100
4
4
4
KVM
kai1s.4xlarge.2
16
32
10/6
140
4
5
6
KVM
kai1s.6xlarge.2
24
48
12/8
200
8
6
8
KVM
kai1s.9xlarge.2
36
72
16/12
280
8
6
12
KVM
kai1s.12xlarge.2
48
96
20/16
400
16
6
12
KVM
Table 42 Ai1s ECS specifications
Flavor
vCPUs
Memory
(GiB)
Max. Network PPS
(10,000)
Ascend 310 Processors
Ascend RAM
(GiB)
Max. NIC Queues
Max. NICs
Virtualization
ai1s.large.4
2
8
4/1.3
20
2
2
KVM
ai1s.xlarge.4
4
16
6/2
35
2
16
2
3
KVM
ai1s.2xlarge.4
8
32
10/4
50
4
32
4
4
KVM
ai1s.4xlarge.4
16
64
15/8
100
8
64
8
8
KVM
ai1s.8xlarge.4
32
128
25/15
200
16
128
8
8
KVM
Table 43 Ai2 ECS specifications
Flavor
vCPUs
Memory
(GiB)
Max. PPS
(10,000)
Ascend Chip
Ascend RAM
(GiB)
Virtualization
ai2.xlarge.4
4
16
8/1.6
80
3
3
KVM
ai2.2xlarge.4
8
32
15/3
150
4
4
KVM
ai2.4xlarge.4
16
64
20/6
280
8
8
KVM
ai2.8xlarge.4
32
128
30/12
550
2
48
8
8
KVM
ai2.16xlarge.4
64
256
36/24
800
4
96
16
8
KVM
ai2.24xlarge.4
96
384
40/36
850
6
144
32
8
KVM
Table 44 Ai1 ECS specifications
Flavor
vCPUs
Memory
(GiB)
Max. Network PPS
(10,000)
Ascend RAM
(GiB)
Max. NIC Queues
Max. NICs
Virtualization
ai1.large.4
2
8
4/1.3
20
2
2
KVM
ai1.xlarge.4
4
16
6/2
35
2
16
2
3
KVM
ai1.2xlarge.4
8
32
10/4
50
4
32
4
4
KVM
ai1.4xlarge.4
16
64
15/8
100
8
64
8
8
KVM
ai1.8xlarge.4
32
128
25/15
200
16
128
8
8
KVM
