Help Center/
Cloud Container Engine/
User Guide/
User Guide for Standard and Turbo Clusters/
Clusters/
Upgrading a Cluster/
Troubleshooting for Pre-upgrade Check Exceptions/
Subnet Quota of Master Nodes
Updated on 2024-08-16 GMT+08:00
Check Items
Check whether the number of available IP addresses in the cluster subnet supports rolling upgrade.
Solution
If the number of IP addresses in the selected cluster subnet is insufficient, rolling upgrade is not supported. Contact O&M personnel for support.
