CCE Secrets Manager for DEW
Introduction
The CCE Secrets Manager for DEW add-on is used to interconnect with Data Encryption Workshop (DEW). This add-on allows you to mount secrets stored outside a cluster (DEW for storing sensitive information) to service pods. In this way, sensitive information can be decoupled from the cluster environment, which prevents information leakage caused by program hardcoding or plaintext configuration. With this add-on, you can enjoy the following capabilities:
- Mounting secrets: You can mount secrets in DEW to service pods, reducing information leakage risks.
- Scheduled rotation: After a pod runs normally, if the secret declared in the SecretProviderClass object and stored in CSMS is updated, the latest secret values can be updated to the pod through scheduled rotation. When using this capability, set the secret version to latest.
- Real-time detection of SecretProviderClass changes: After a pod runs normally, if a user modifies the secret declared in the SecretProviderClass object (for example, a secret is added or the version number is changed), the add-on can detect the change in real time and update the secret to the pod.
- DEW includes Key Management Service (KMS), Cloud Secret Management Service (CSMS), and Key Pair Service (KPS). Currently, the add-on can interconnect only with CSMS.
- The cluster version must be 1.28.8-r0, 1.31.4-r0 or later. If the cluster version does not meet the requirements, you need to upgrade the cluster.
- To install this add-on, you need to configure a VPC endpoint for accessing DEW in advance. For details, see Configuring a VPC Endpoint for Accessing DEW.
- A maximum of 500 SecretProviderClass objects are allowed by this add-on.
- When the add-on is uninstalled, related CRD resources are deleted accordingly. Even if the add-on is reinstalled, the original SecretProviderClass object is unavailable. If you want to use the original SecretProviderClass resources after the add-on is uninstalled and then reinstalled, manually create them again.
Billing
Operation |
Billed Item |
Billing Description |
Reference |
Installing the add-on |
N/A |
When the add-on is installed, pods for running it are not deployed. There are no expenditures for installing the add-on. |
Using the add-on |
Pod |
When a secret in DEW is mounted to a service pod, a DaemonSet is automatically created for deploying the pods that are used to run the add-on. Each service pod is configured with a group of add-on pods. For details about the pod specifications for the add-on, see Table 1. When a secret in DEW is no longer mounted to a service pod in the cluster, the pods for running the add-on are automatically deleted. The billing will stop when the service pod is stopped. If a secret in DEW is mounted again, the pods for running the add-on will be automatically redeployed. |
For details about pod price, see Billing Items of CCE Autopilot Clusters. |
Installing the Add-on
- In the navigation pane, choose Clusters > Add-ons. Locate the CCE Secrets Manager for DEW add-on and click Install.
- In the Install Add-on dialog box, set Secret Synchronization Period.
Field in YAML
rotation_poll_interval
Rotation interval, in minutes. The unit is m (not min).
This is the interval for sending a request to CSMS and obtaining the latest secret. The interval range is 1 to 1440. The default value is 2.
- Click Install in the lower right corner. If the status is Running, the add-on has been installed.
Components
Component |
Description |
Resource Type |
Resource specifications (single pod) |
dew-provider |
A component that obtains specified secrets from CSMS and mounts them to the pods |
DaemonSet |
csi-secrets-store |
A component that maintains two CRDs, SecretProviderClass and SecretProviderClassPodStatus (spcPodStatus). SecretProviderClass is used to describe the required secret (such as the secret version and name). It is created by users and will be referenced in pods. spcPodStatus is used to trace the binding relationships between pods and secrets. It is automatically created by csi-driver and requires no manual operation. One pod corresponds to one spcPodStatus. After a pod is started, a spcPodStatus is generated for the pod. When the pod lifecycle ends, the spcPodStatus is deleted accordingly. |
DaemonSet |
Mounting Secrets
To mount a secret in DEW to a container, you need to take the following steps: First, create a ServiceAccount object as the secret for the cluster to access DEW. Then, create a SecretProviderClass object to define and obtain the secret in DEW. Finally, mount the ServiceAccount and SecretProviderClass objects to the service pod to ensure that the pod can securely access the secret. Currently, there are two methods to mount a secret to a pod:
- Mounting a secret through a volume: Secrets are mounted to containers in the form of volumes. This method is suitable when there is a large amount of data.
- Mounting a secret created from a secret in DEW: Secrets are mounted to containers as environment variables. This method is suitable when there is only a small amount of sensitive data.
The following describes the processes of the two methods.
- Create a ServiceAccount object to declare the name of the secret that can be used by the service pod. Before you take this step, ensure that the corresponding secret exists in CSMS. If the secret does not exist, an error occurs when the secret is obtained from CSMS. As a result, the pod cannot run normally. For details about how to create secrets in CSMS, see Creating a Secret.
Figure 1 Secrets in DEW
- Create a YAML file for the ServiceAccount object.
vim serviceaccount.yamlThe following is the file content. You can declare the secret names that can be used by the service pod in the cce.io/dew-resource field. In this example, secret_1 and secret_2 can be referenced in the service pod. If you reference a secret that is not declared here, the mounting will fail. As a result, the pod cannot run normally.
apiVersion: v1 kind: ServiceAccount metadata: name: nginx-spc-sa annotations: cce.io/dew-resource: "[\"secret_1\",\"secret_2\"]" #secrets that allow pod to use - Create the ServiceAccount object.
kubectl apply -f serviceaccount.yaml
Information similar to the following is displayed:
serviceaccount/nginx-spc-sa created
- Check whether the ServiceAccount object has been created.
kubectl get sa
If the following information is displayed, the ServiceAccount object named nginx-spc-sa has been created and will be referenced in the service pods.
NAME SECRETS AGE default 1 18d # This is the default ServiceAccount object of the system. nginx-spc-sa 1 19s # This is the newly created ServiceAccount object.
- Create a SecretProviderClass object to define and manage secrets from DEW so that secrets can be securely mounted to pods in the CCE cluster.
- Create a YAML file for the SecretProviderClass object.
vim secretproviderclass.yamlThe following is the file content. The parameters.objects field specifies the secrets to be mounted, in array format.
apiVersion: secrets-store.csi.x-k8s.io/v1 kind: SecretProviderClass metadata: name: spc-test spec: provider: cce # The value is fixed at cce. parameters: objects: | - objectName: "secret_1" objectAlias: "secret_test" objectVersion: "v1" objectType: "csms"Table 2 Parameters in objects Parameter
Type
Mandatory
objectName
String
Yes
Secret name. Set this parameter to the secrets referenced in ServiceAccount. If there are multiple object names defined in the same SecretProviderClass, each value of the objectName parameter must be unique. Otherwise, the mounting fails.
objectAlias
String
No
File name of the secret written into the container.
- If this parameter is not specified, the name of the file that the secret is written to the container is objectName by default.
- If this parameter is specified, the value of objectAlias must be different from that of objectName and of objectAlias of other secrets and its own objectName. Otherwise, the mounting fails.
objectType
String
Yes
Type of the secret. Only csms is supported. Any value other than csms is invalid.
objectVersion
String
Yes
Version of the secret.
- Specify a version, for example, v1 or v2.
- Use the latest version, for example, latest. If objectVersion is set to latest and the corresponding secret in CSMS is updated, periodic polling is automatically enabled, and the secret will be updated to the pod after the interval specified by rotation_poll_interval.
- Create the SecretProviderClass object.
kubectl apply -f secretproviderclass.yaml
secretproviderclass/spc-test created
- Check whether the SecretProviderClass object has been created.
kubectl get spc
If the following information is displayed, a SecretProviderClass object named spc-test has been created and will be referenced in subsequent pods.
NAME AGE spc-test 20h
- Create a service pod. In this example, this pod is used to run an Nginx application.
- Define a workload, reference the created ServiceAccount object in serviceAccountName, and reference the created SecretProviderClass object in secretProviderClass, specify the mount path of the container in mountPath. (Do not specify special directories such as / and /var/run. Otherwise, the container may fail to be started.)
vim deployment.yamlExample file content:
apiVersion: apps/v1 kind: Deployment metadata: name: nginx-spc labels: app: nginx spec: replicas: 1 selector: matchLabels: app: nginx template: metadata: labels: app: nginx spec: serviceAccountName: nginx-spc-sa # Reference the created ServiceAccount for identity authentication of secrets. volumes: - name: secrets-store-inline csi: driver: secrets-store.csi.k8s.io # Specify the Secrets Store CSI driver. The value is fixed. readOnly: true # Set the volume to read-only to ensure that the secret is not modified. volumeAttributes: secretProviderClass: "spc-test" # Reference the created SecretProviderClass. containers: - name: nginx-spc image: nginx:alpine imagePullPolicy: IfNotPresent volumeMounts: # Mount the volume defined above to the container. - name: secrets-store-inline mountPath: "/mnt/secrets-store" # Define the mount path of secrets in the container. readOnly: true # Read-only imagePullSecrets: - name: default-secret
kubectl apply -f deployment.yaml
Information similar to the following is displayed:deployment/nginx-spc created
- Check whether the pod has been created.
kubectl get pod
NAME READY STATUS RESTARTS AGE nginx-spc-67c9d5b594-642np 1/1 Running 0 20s
- Check whether the specified secret can be written.
- Enter the container.
kubectl exec -ti nginx-spc-67c9d5b594-642np -- /bin/sh
- Search for the specified secret.
cd /mnt/secrets-store/ ls
If the following information is displayed, secret_test declared in the SecretProviderClass object has been written to the pod.
secret_test
- Obtain spcPodStatus to check whether the secret has been mounted to the pod.
Exit the container using Ctrl+d and obtain the spcps resource name.
kubectl get spcps
Information similar to the following is displayed:NAME AGE nginx-spc-67c9d5b594-642np-default-spc-test 103s
Check whether the secret has been mounted to the pod.
kubectl get spcps nginx-spc-67c9d5b594-642np-default-spc-test -o yaml
If the following information is displayed, the secret has been mounted to the pod.
...... status: mounted: true objects: # Mounted secret - id: secret_test version: v1 podName: nginx-spc-67c9d5b594-642np # Pod that references the SecretProviderClass object secretProviderClassName: spc-test # SecretProviderClass object targetPath: /mnt/paas/kubernetes/kubelet/pods/6dd29596-5b78-44fb-9d4c-a5027c420617/volumes/kubernetes.io~csi/secrets-store-inline/mount
Figure 2 Secrets in DEW
kubectl get sa
- Create a SecretProviderClass to define and manage the secret from DEW so that the secret can be securely mounted to the pods in the CCE cluster. In a SecretProviderClass object, you can define the required secret information, such as the secret name and version.
apiVersion: secrets-store.csi.x-k8s.io/v1 kind: SecretProviderClass metadata: name: nginx-deployment-spc-k8s-secrets spec: provider: cce parameters: # Reference a secret in CSMS. objects: | - objectName: "secret_1" objectType: "csms" objectVersion: "latest" jmesPath: - path: key1 objectAlias: dbusername01 - path: key2 objectAlias: dbusername02 # Create a CCE secret based on the CSMS secret and mount the secret to a pod. secretObjects: - secretName: my-secret-01 type: Opaque data: - objectName: dbusername01 # The value must be the same as that of objectAlias. key: db_username_01 - objectName: dbusername02 # The value must be the same as that of objectAlias. key: db_username_02
Table 3 Parameters in objects Parameter
Type
Mandatory
objectName
String
Yes
Secret name. Set this parameter to the secret referenced in ServiceAccount. If there are multiple object names defined in the same SecretProviderClass, each value of the objectName parameter must be unique. Otherwise, the mounting fails.
objectType
String
Yes
objectVersion
String
Yes
jmesPath
Array of Object
Yes
jmesPath is used to extract key-value pairs from objects in JSON format. The CCE Secrets Manager for DEW add-on uses this tool to mount secrets to pods. If a secret has multiple keys, you need to enter multiple paths and object aliases.
- path: Enter the key in DEW.
The key cannot contain backslashes (\). There are no restrictions on other special characters.
- objectAlias is name of the file mounted to a pod. The value must be the same as the value of objectName defined in secretObjects.
Table 4 Parameters in secretObjects Parameter
Type
Mandatory
secretName
String
Yes
Secret name.
type
String
Yes
Secret type.
data
Array of Object
Yes
- objectName: name of the file mounted to the pod. The value must be the same as the value of objectAlias specified in objects.
- key: key of the secret. You can specify the key value as needed. The key value can be used to reference the encrypted content in the pod.
secretproviderclass/nginx-deployment-spc-k8s-secrets created
kubectl get spc
If the following information is displayed, a SecretProviderClass object named nginx-deployment-spc-k8s-secrets has been created and will be referenced in subsequent pods.
NAME AGE nginx-deployment-spc-k8s-secrets 20h
apiVersion: apps/v1 kind: Deployment metadata: name: nginx-deployment-k8s-secrets labels: app: nginx-k8s-secrets spec: replicas: 1 selector: matchLabels: app: nginx-k8s-secrets template: metadata: labels: app: nginx-k8s-secrets spec: serviceAccountName: nginx-spc-sa # Reference the created ServiceAccount. containers: - name: nginx-deployment-k8s-secrets image: nginx volumeMounts: # Mount the SecretProviderClass to a container. - name: secrets-store-inline # Name of the volume to be mounted mountPath: "/mnt/secrets" # Path of the container where the secret is to be mounted readOnly: true env: # Set environment variables so that the container can reference the secret during running. - name: DB_USERNAME_01 # Name of the environment variable for the workload valueFrom: secretKeyRef: name: my-secret-01 # Secret name specified in the SecretProviderClass key: db_username_01 # The value of the key specified in the SecretProviderClass - name: DB_USERNAME_02 valueFrom: secretKeyRef: name: my-secret-01 key: db_username_02 imagePullSecrets: - name: default-secret volumes: # Use the secret specified in the SecretProviderClass to create a volume. - name: secrets-store-inline # Custom volume name csi: driver: secrets-store.csi.k8s.io readOnly: true volumeAttributes: secretProviderClass: nginx-deployment-spc-k8s-secrets # Name of the SecretProviderClass created in the previous step
Information similar to the following is displayed:deployment/nginx-deployment-k8s-secrets created - Check whether the pod has been created.
kubectl get pod
NAME READY STATUS RESTARTS AGE nginx-deployment-k8s-secrets-6c945565fb-s7smv 1/1 Running 0 20s
- Verify the result.
kubectl get secrets
The output shows that a secret named my-secret-01 has been created using secret_1 specified in the SecretProviderClass object.
NAME TYPE DATA AGE default-secret kubernetes.io/dockerconfigjson 1 33d my-secret-01 Opaque 2 1h
Scheduled Rotation
After a pod runs normally, if the secret declared in the SecretProviderClass object and stored in CSMS is updated, the latest secret values can be updated to the pod through scheduled rotation. To use this capability, you need to set the secret version to latest. The following is an example:
provider: cce
parameters:
objects: |
objectVersion: "latest" # change "v1"to "latest"
objectType: "csms"
After the SecretProviderClass object is updated, the add-on periodically sends a request to CSMS to obtain the value of secret_1 of the latest version and updates the value to the pod that references the SecretProviderClass object. The interval for the add-on to periodically send requests is specified by rotation_poll_interval set in Installing the Add-on.
Real-Time Detection of SecretProviderClass Changes
After a pod runs normally, if a user modifies the secret declared in the SPC object (for example, a secret is added or the version number is changed), the add-on can detect the change in real time and update the secret to the pod. For example, add the secret_2 secret to the SecretProviderClass object. After the SecretProviderClass object is updated, secret_2 is quickly mounted to the pod that references the SecretProviderClass object.
provider: cce
parameters:
objects: |
objectType: "csms"
- objectName: "secret_2"
objectVersion: "v1"
objectType: "csms"
Viewing Component Logs
You can use kubectl to view component logs.
- View the pods for running the add-on.
kubectl get pod -n kube-system
NAME READY STATUS RESTARTS AGE csi-secrets-store-76tj2 3/3 Running 0 11h dew-provider-hm5fq 1/1 Running 0 11h
- View the logs of the dew-provider component.
kubectl logs dew-provider-hm5fq -n kube-systemThe command output is the detailed log information.
... I0321 13:49:29.319708 1 dew_provider.go:43] object [secret_1]'s version [v1] doesn't change, read from local I0321 13:49:29.319735 1 server.go:108] Start writing into mount point I0321 13:49:29.319793 1 server.go:117] Write [secret_1/]'s value into file successfully I0321 13:49:29.319801 1 server.go:123] Write secret file finished I0321 13:49:29.320284 1 server.go:67] "Servicing mount request" Pod="nginx-deployment-k8s-secrets-6c945565fb-s7smv" Namespace="default" ServiceAccount="nginx-spc-sa" I0321 13:49:29.617666 1 dew_provider.go:107] "Get secret successfully" name="secret_1" version="v1" ...
- View the logs of the csi-secrets-store component. The pod of the csi-secrets-store component contains multiple containers. When viewing logs, run the -c command to specify a container. The secrets-store container is the major service container of the add-on and contains the majority of the logs.
kubectl logs csi-secrets-store-76tj2 -c secrets-store -n kube-systemThe command output is the detailed log information.
... I0321 10:17:29.314888 1 secrets-store.go:46] "Initializing Secrets Store CSI Driver" driver="secrets-store.csi.k8s.io" version="local-dev" buildTime="" I0321 10:17:29.314987 1 reconciler.go:143] "starting rotation reconciler" rotationPollInterval="2m0s" I0321 10:17:29.315141 1 server.go:126] "Listening for connections" address="//mnt/paas/kubernetes/kubelet/plugins/csi.sock" I0321 10:17:30.933328 1 nodeserver.go:359] "node: getting default node info\n" I0321 10:19:19.269337 1 nodeserver.go:353] "Using gRPC client" provider="cce" pod="nginx-spc-744b4c57dc-x74xq" I0321 10:19:19.543221 1 secretproviderclasspodstatus_controller.go:224] "reconcile started" spcps="default/nginx-spc-744b4c57dc-x74xq-default-spc-test" ...
- Log in to the VPC Endpoint console.
- On the displayed page, click Buy VPC Endpoint.
- Configure mandatory parameters as prompted. For details about more parameters, see Buying a VPC Endpoint.
Table 5 Parameters for creating a VPC endpoint Parameter
Region
Select the region where the VPC endpoint is located. The VPC endpoint must be in the same region as the CCE Autopilot cluster.
Billing Mode
Only pay-per-use billing is supported. Specifies the billing mode of the VPC endpoint.
Service Category
Select Find a service by name.
VPC Endpoint Service Name
Submit a service ticket to obtain the service name in the current region from DEW engineers.
Create a Private Domain Name
Select this parameter.
After the endpoint is created, you can access the endpoint using the private domain name.
VPC
Select the VPC where the CCE Autopilot cluster is running.
Subnet
Select a subnet.
IPv4 Address
Specifies the IPv4 address of the VPC endpoint. You can select Automatically assign IP address or Manually specify IP address.
- Click Next to confirm the configuration.
- If the configuration is correct, click Submit.
- If any parameter is incorrect, click Previous to modify it as needed and then click Submit.
- Go back to the VPC endpoint list. If the status of the VPC endpoint changes to Accepted, the VPC endpoint is connected to the VPC endpoint service.
Change History
Add-on Version |
Supported Cluster Version |
New Feature |
1.0.0 |
1.28.8-r0, 1.31.4-r0, or later |
CCE Autopilot clusters are supported. |
