Updated on 2026-09-28 GMT+08:00
AgentCube
With the rapid development of generative AI and large language model (LLM) applications, AI agent workloads are becoming important in cloud native environments. These workloads have unique characteristics: continuous interaction, state persistence, and intermittent long sessions. However, the existing workload management modes cannot meet the special requirements of AI agents.
  • High cold start latency: Agent interactions typically require responses within milliseconds. However, the native Kubernetes pod startup process (scheduling, IP address assignment, image pull, and container startup) usually takes seconds or even minutes. In scenarios where the code interpreter or a temporary sub-agent needs to be frequently started, the latency of cold start is unacceptable to users.
  • Low resource utilization: Agents are typically I/O-intensive workloads. In a session, the agent may spend 90% of the time waiting for the LLM to generate tokens or waiting for external tools to respond. If each agent exclusively occupies a pod on Kubernetes, a large number of CPU and memory resources will be idle during the waiting period and cannot be used by other tasks.
  • Lack of status management: Kubernetes is naturally friendly to stateless workloads, but agents highly depend on context/memory. In native Kubernetes, pod restart means loss of memory data. Developers are forced to rebuild the context at the application layer by using external storage, which results in great complexity and network overhead.
  • Security isolation: Advanced agents (such as Data Analyst) need to run untrusted code generated by LLMs. However, running rm -rf / in a common runC container is highly risky. Enterprise-class agent platforms urgently need a sandbox environment (such as MicroVM) that can be quickly started and provide strong isolation.
To address these challenges, CCE Autopilot clusters offer the AgentCube add-on based on AgentCube. AgentCube is a high-performance AI agent orchestration tool that natively supports and manages AI agent workloads on Kubernetes. It provides innovative capabilities such as fast startup, fast scheduling, native session management, and serverless auto scaling.
  • AgentCube is an open-source project currently in the Alpha phase. CCE does not guarantee the applicability, reliability, or performance of the software. Users are responsible for any risks (including but not limited to data security, system stability, and resource consumption) during the use of AgentCube.
  • This feature is in the initial rollout stage. To view the regions where this feature is available, see the console.
Function Introduction
AgentCube introduces two core CRDs to define agent workloads:
  1. AgentRuntime: defines the lifecycle, resource quotas, and persistence policies for long-session and complex conversational agents.
  2. CodeInterpreter: defines a short-task and high-frequency code execution environment that emphasizes "destruction after use" and ultimate security isolation.
Core functions:
  • Fast startup
    To eliminate the challenges of cold start, AgentCube implements the warm pool mechanism. The system pre-starts and suspends a group of MicroVM sandboxes with the basic environment. When an agent request arrives, AgentCube can allocate a pre-warmed sandbox to the session in milliseconds in "Claim-and-Go" mode, achieving near-zero startup latency.
  • Native session management
    AgentCube introduces session IDs as core routing identifiers to ensure the continuity of service contexts.
    • Request routing: AgentCube Router can identify x-agentcube-session-id in a request and automatically route it to the corresponding active sandbox.
    • Automatic sandbox activation: When the sandbox corresponding to the current session is in the hibernation state, AgentCube Router can automatically activate the sandbox.
  • Session-based end-to-end isolation
    AgentCube automatically allocates an independent sandbox environment for each session to ensure complete isolation of compute, memory, and file systems, preventing cross-tenant data leakage.
For more information about AgentCube, see AgentCube.
  • A CCE Autopilot cluster of v1.31 or later has been created.
  • Redis has been deployed and AgentCube can access Redis.
Installing the Add-on
  2. In the navigation pane, choose Add-ons. Locate AgentCube on the right and click Install.
  3. On the Install Add-on page, configure the add-on.
    Table 1 Parameters
    Example Value
    redis.addr
    Redis address, which is mandatory
    <IP-address>:<port-number>
    redis.password
    Redis password, which is mandatory
    agentSandbox.install
    Whether to automatically install agent-sandbox. AgentCube depends on agent-sandbox when it is running. If this parameter is set to true, agent-sandbox will be automatically installed. If agent-sandbox has been manually installed in your cluster, you can set this parameter to false to skip the installation.
    true
    agentSandbox.extensions
    Whether to enable the extension controller of agent-sandbox
    true
    router.service.type
    Service access type of the agentcube-router component
    ClusterIP
    workloadmanager.service.type
    Service access type of the workloadmanager component
    ClusterIP
  4. Click Install. If the add-on is in the Running state, the add-on has been installed.
Components
Table 2 AgentCube components
Component
Resource Type
workloadmanager
Lifecycle management for sandboxes and code interpreters
Deployment
agentcube-router
API gateway for request forwarding to sandbox pods
Deployment
agent-sandbox-controller
Agent sandbox management
Deployment
The workloadmanager, agentcube-router, and agent-sandbox-controller components are deployed in the agentcube namespace.
If the add-on is uninstalled after being installed, the components and Services created in the agentcube namespace will be deleted, but the CRDs created by the add-on will not be deleted.
How to Use the Add-on
After the add-on is installed, you can use it by referring to the following examples.
Example 1: Using CodeInterpreter
  1. Create the code-interpreter-demo.yaml file.
    apiVersion: runtime.agentcube.volcano.sh/v1alpha1
    kind: CodeInterpreter
      namespace: default
      template:
        # Use the PicoD image.
        image: ghcr.io/volcano-sh/picod:latest
        # Resources
        resources:
          requests:
            cpu: "100m"
            memory: "128Mi"
          limits:
            cpu: "500m"
            memory: "512Mi"
      # Session configuration
      sessionTimeout: "15m"      # The session times out after it is idle for 15 minutes.
      maxSessionDuration: "8h"   # Maximum session duration: 8 hours
      # Key function: warm pool
      warmPoolSize: 5    # 5 pods will be warmed up (near-zero latency).
  2. Deploy CodeInterpreter.
    kubectl apply -f code-interpreter-demo.yaml
    After the creation is complete, run the following command to check the status:
    kubectl get codeinterpreter my-codeinterpreter -o yaml
  3. Verify the creation of the warm pool.
    # View the created SandboxWarmPool.
    kubectl get sandboxwarmpool -n default
    # View the pods in the warm pool.
    kubectl get pods |grep my-codeinterpreter
  4. Create a test script (Python 3.11 or later must be installed locally).
    1. Create the test_codeinterpreter folder.
    2. Go to the test_codeinterpreter folder and run the following command to create a Python virtual environment:
      python -m venv venv
    3. Activate the virtual environment (on Windows, run the .\venv\Scripts\activate command in PowerShell).
      source venv/bin/activate
    4. Install the dependency.
      pip install -r requirements.txt
  5. Run the test script.
    1. Set environment variables. (If you want to access the workload from outside the cluster, configure a LoadBalancer ingress for the Services of workloadmanager and agentcube-router. You can access the workload using the EIP of the load balancer.)
      • Linux:
        export WORKLOAD_MANAGER_URL="http://addr:workloadmanager-port"
        export ROUTER_URL="http://addr:agentcube-router-port"
      • Windows (in PowerShell):
        $env:ROUTER_URL = "http://addr:agentcube-router-port"
        $env:WORKLOAD_MANAGER_URL = "http://addr:workloadmanager-port"
      addr indicates the EIP, agentcube-router-port indicates the ingress port configured for the Service of agentcube-router, and workloadmanager-port indicates the ingress port configured for the Service of workloadmanager.
    2. Run the test.
      python test_codeinterpreter.py
      Output
Example 2: Using AgentRuntime
  1. Create the test_agentruntime folder.
  2. Build an example agent image and push it to the image repository.
    docker build  -t my-agent-app:latest .
  3. Deploy AgentRuntime.
    agent-runtime-demo.yaml:
    kind: AgentRuntime
      namespace: default
      targetPort:
        - pathPrefix: "/"
          port: 8080
          protocol: "HTTP"
      podTemplate:
        labels:
          app: my-agent-app
          containers:
            - name: my-agent-app
              image: {{agent image}}    # Example agent image
              env:
                - name: WORKLOAD_MANAGER_URL
                  value: http://workloadmanager.agentcube.svc.cluster.local:8080
                - name: ROUTER_URL
                  value: http://agentcube-router.agentcube.svc.cluster.local:8080
                - name: CODEINTERPRETER_NAME         # Name of the code interpreter
                  value: my-codeinterpreter
                - name: CODEINTERPRETER_NAMESPACE
                  value: default
              readinessProbe:
                httpGet:
                  path: /health
                  port: 8080
                periodSeconds: 5
    status: {}
  4. Deploy AgentRuntime and check its status.
    kubectl apply -f agent-runtime-demo.yaml
    # Check the status.
    kubectl get agentruntime my-agent-app -oyaml
  5. Create a test script (Python 3.11 or later must be installed locally).
      Create the test_agentruntime.py and requirements.txt files in the folder. The file content is as follows:
      • test_agentruntime.py:
        from agentcube.agent_runtime import AgentRuntimeClient
        import os
        import time
        # Configure environment variables.
        ROUTER_URL = os.getenv('ROUTER_URL', 'http://agentcube-router.agentcube.svc.cluster.local:8080')
        AGENT_NAME = os.getenv('AGENT_NAME', 'my-agent-app')
        AGENT_NAMESPACE = os.getenv('AGENT_NAMESPACE', 'default')
        saved_session_id = ""
        def test_basic_invoke():
            """Test the basic invocation function."""
            print("=== test basic invoke ===\n")
            # Create a client.
            agent_client = AgentRuntimeClient(
                agent_name=AGENT_NAME,
                namespace=AGENT_NAMESPACE,
                router_url=ROUTER_URL,
                verbose=True,
                timeout=500,
                connect_timeout=120.0
            print(f"Session ID: {agent_client.session_id}\n")
            # Invocation for the first time (creating a pod)
            print("first invoke (create new Pod): ")
            result = agent_client.invoke(
                payload={"prompt": "hello world!"},
            print(f"response: {result}\n")
            # # Save the session ID.
            global saved_session_id
            saved_session_id = agent_client.session_id
        def test_session_reuse():
            """Test session reuse."""
            print(f"=== test session reuse ===\n")
            # Use the original session ID.
                session_id=saved_session_id,  # Session reused
                verbose=True,
                timeout=500,
            print(f"reuse session ID: {agent_client.session_id}\n")
            # Invocation for the second time (reusing the existing pod)
            print("second invoke(reuse Pod):")
                payload={"prompt": "How's the weather today?"},
        def test_conversation():
            """Test continuous conversation."""
            print("=== test conversation ===\n")
                verbose=True,
                timeout=500,
            messages = [
                "Introduce yourself",
                "What can you do?",
                "Write a Python function for me",
            for i, msg in enumerate(messages, 1):
                print(f"message {i}: {msg}")
                    payload={"prompt": msg},
                print(f"response {i}: {result}\n")
                time.sleep(1)
        if __name__ == "__main__":
            test_basic_invoke()
            test_conversation()
      • requirements.txt:
        agentcube_sdk
    2. Go to the test_agentruntime folder and run the following command to create a Python virtual environment:
      python -m venv venv
  6. Run the test script.
    1. Set environment variables. (If you want to access the workload from outside the cluster, configure a LoadBalancer ingress for the Service of agentcube-router. You can access the workload using the EIP of the load balancer.)
      • Linux:
      addr indicates the EIP and agentcube-router-port indicates the ingress port configured for the Service of agentcube-router.
    2. Run the test.
      python test_agentruntime.py
      Output
Release History
Table 3 AgentCube updates
Add-on Version
Supported Cluster Version
New Feature
1.0.5
  • v1.36
  • v1.35
  • v1.34
  • v1.32
  • v1.31
Supported CCE Autopilot clusters v1.36.
1.0.3
  • v1.35
  • v1.34
  • v1.32
  • v1.31
  • Supported CCE Autopilot clusters v1.35.
  • Supported CCE Autopilot clusters v1.34.
1.0.2
  • v1.31
  • v1.32
The AgentCube add-on is now available.
