Creating a Custom Policy
Custom policies can be created to supplement the system-defined policies of BCS.
You can create custom policies in either of the following ways:
- Visual editor: Select cloud services, actions, resources, and request conditions. This does not require knowledge of policy syntax.
- JSON: Edit policies from scratch or based on an existing policy in JSON format.
For details, see Creating a Custom Policy. The following section contains examples of common BCS custom policies.
- On the management console homepage, click Identity and Access Management.
- In the navigation pane, choose Permissions > Policies/Roles and click Create Custom Policy.
- On the Create Custom Policy page, set the policy name, view, content, and description, then click OK.
- Policy Name: Enter a custom policy name, for example, "partial BCS permissions".
- Policy View: Select JSON.
- Policy Content: Enter the policy content based on the template. For example, use the following content to query instances and channels and create channels.
{ "Version": "1.1", "Statement": [ { "Effect": "Allow", "Action": [ "bcs:fabricInstance:getDetail", "bcs:fabricChannel:create", "bcs:fabricChannel:list" ] } ] }Table 1 Policy content parameters Parameter
Setting
Version
Policy version
Fixed to 1.1.
Statement
Effect
Whether the actions are allowed
- Allow
- Deny
Action
Operations to be performed on BCS
Each action name is in the format of Service name:Resource type:Operation and cannot be customized. Table 2 lists the fine-grained permissions supported by BCS. After you set any action, the permissions for the action will be granted to the IAM user.
Table 2 Action description Action
Action Description
bcs:fabricInstance:listQuota
Querying quotas
bcs:fabricInstance:getFlavor
Querying Flavors
bcs:fabricInstance:listRecord
Querying Asynchronous Operation Results
bcs:fabricInstance:createOnDemand
Creating a BCS Service
Querying the BCS Service List
bcs:fabricInstance:getStatus
Querying Creation Status of a BCS Service
Querying Service Information
bcs:fabricInstance:getNodes
Querying Peer Information
bcs:fabricInstance:update
Modifying a BCS Service
bcs:fabricInstance:delete
Deleting Service Instances
bcs:fabricInstance:downloadCert
Downloading Certificates
bcs:fabricInstance:downloadSdkCfg
Downloading the SDK Configuration
bcs:fabricInstance:createUserCert
Generating a User Certificate
bcs:fabricInstance:freezeUserCert
Freezing a User Certificate
bcs:fabricInstance:unfreezeUserCert
Unfreezing a User Certificate
bcs:fabricInstance:listInstanceMetric
Querying BCS Monitoring Data
bcs:fabricInstance:listOrgMetric
Listing Entity Monitoring Data of a BCS Service
bcs:fabricInstance:getOrgMetric
Querying the Number of Monitored BCS Organization Instances
Creating a Channel
Querying Channel Information
bcs:fabricChannel:addPeer
Adding Peers to a Channel
bcs:fabricChannel:removePeer
Removing a Peer from a Channel
bcs:fabricChannel:removeOrg
Removing Organizations from a Channel
bcs:fabricChannel:delete
Deleting a Channel
bcs:fabricMember:createInvitation
Inviting Tenants to Join a Consortium
bcs:fabricMember:deleteInvitation
Deleting Invitation Information
bcs:fabricMember:list
Listing Consortium Members
bcs:fabricMember:quit
Exiting a Consortium
bcs:fabricNotification:list
Querying All Notifications
bcs:fabricNotification:handle
Processing an Invitation
