Updated on 2025-09-26 GMT+08:00
Configuring an Alarm Rule
You can create alarm rules to monitor the status of your APIs.
  1. Go to the APIG console.
  2. Select a gateway at the top of the navigation pane.
  1. In the navigation pane, choose API Management > API Groups.
  1. Click a group name to go to the Group Information page.
  2. On the Monitoring area of the APIs tab, click More to access the Cloud Eye console. Then create an alarm rule. For details, see Creating an Alarm Rule.
