Resetting the AppSecret of an App
You can reset the AppSecret of an app. The AppKey is unique and cannot be reset. When you reset the AppSecret, it becomes invalid and APIs bound to the app cannot be called. To enable API calls for that app again, you will need to update the AppSecret of the app you use.
You have created an app.
- Click
in the upper left corner and choose API Gateway.
- In the navigation pane, choose Dedicated Gateways. Then click Access Console in the upper right corner of a dedicated gateway.
- In the navigation pane, choose API Calling > Apps.
- Click the name of the target app.
- In the upper right corner of the displayed app details page, click Reset AppSecret.
- Click Yes.
