Help Center>
API Gateway>
User Guide (Kuala Lumpur Region)>
API Calling>
App Management>
Deleting an App
Updated on 2022-08-12 GMT+08:00
Deleting an App
You can delete apps you no longer require.
You have created an app.
- Click
in the upper left corner and choose API Gateway.
- In the navigation pane, choose Dedicated Gateways. Then click Access Console in the upper right corner of a dedicated gateway.
- In the navigation pane, choose API Calling > Apps.
- Delete an app. You can use one of the following methods:
- In the Operation column of the app you want to delete, click Delete.
- Click the name of the target app, and click Delete App in the upper right corner of the displayed app details page.
If the app has been bound to any APIs, you must unbind the app and then delete it.
- Click Yes.
Parent topic: App Management
