VPC Peering Connection Usage Guidelines
| VPC and Subnet CIDR Block | VPC Peering Connection Description | Configuration Example |
| You can create VPC peering connections to connect entire CIDR blocks of VPCs. Then, all resources in the VPCs can communicate with each other. | |
| You can create VPC peering connections to connect specific subnets or ECSs from different VPCs.
| VPC peering connections are not usable. You need to replan the VPC CIDR blocks. |
