Secure Runtime and Common Runtime
Compared with a common runtime, a secure runtime allows each container (pod) to run on its own micro-VM with a separate OS kernel. This ensures secure isolation at the virtualization layer. With a secure runtime, kernels, compute resources, and networks are isolated between containers to protect pod resources and data from being preempted and stolen by other pods.
CCE Turbo clusters allow you to create workloads using a common runtime or secure runtime as required. The differences between them are as follows.
Category
Secure Runtime
Common Runtime
Node type used to run containers
ECS (PM)
ECS (VM)
ECS (PM)
Container engine
containerd
Docker and containerd
Container runtime
Kata
runC
Container kernel
Exclusive kernel
Sharing the kernel with the host
Container isolation
Lightweight VMs
cgroups and namespaces
Container engine storage driver
Device Mapper
  • Docker container: OverlayFS2
  • containerd container: OverlayFS
Pod overhead
Memory: 100 MiB
CPU: 0.1 cores
Pod overhead is a feature for accounting for the resources consumed by the pod infrastructure on top of the container requests and limits. For example, if limits.cpu is set to 0.5 cores and limits.memory to 256 MiB for a pod, the pod will request 0.6 CPU cores and 356 MiB of memory.
None
Minimize flavor
Memory: 256 MiB
CPU: 0.25 cores
It is recommended that the ratio of CPU (unit: core) to memory (unit: GiB) be in the range of 1:1 to 1:8. For example, if CPU is 0.5 cores, the memory should range form 512 MiB to 4 GiB.
None
Container engine CLI
crictl
  • Docker container: docker
  • containerd container: crictl
Pod computing resources
The request and limit values must be the same for both CPU and memory.
The request and limit values can be different for both CPU and memory.
hostNetwork
Not supported
Supported
