CCE.Storage.OBS
Element Description
The CCE.Storage.OBS element corresponds to object storage volumes in the CCE storage management function. This type of resources must be used together with CCE clusters.
Element Properties
Table 1 Property Description
Property
Mandatory
Descripiton
k8sManifest
No
K8s-native manifest object of the OBS, which can be used to replace other configuration items in OBS resource creation
Type: dict
Value Constraint: The value must meet the Kubernetes specifications.
Suggestion: For details, see the sample or CCE documentation.
name
No
PVC name
Type: string
Value Description: Customize the value.
Value Constraint: Each PVC name must be unique in a namespace. The value must contain 1 to 24 characters and meet regular expression (^$)|(^[a-z]([-a-z0-9]*[a-z0-9])?$).
Suggestion: Customize the value.
clusterId
No
ID of the cluster to which the resource belongs
Type: Cloud.CCE.Cluster.Id
Value Description: ID of an existing or new container cluster.
Value Constraint: The value must satisfy the UUID rule and contain a maximum of 64 characters.
Suggestion: 1. Enter the cluster ID. Specifically, log in to the CCE console, and choose Resource Management > Clusters. Click the target cluster, and you can then obtain its cluster ID. 2. Connect to the cluster object and use the get_reference function to obtain the cluster ID. 3. Leave it blank, and specify the ID on the AOS console when creating a stack.
namespace
No
Namespace to which the resource belongs
Type: string
Value Description: It must be a valid namespace in the cluster, for example, default.
Value Constraint: The value must start with a letter. Only lowercase letters, digits, and hyphens (-) are allowed.
Suggestion: Customize the value based on the existing cluster or the cluster to be created.
volumeId
No
Cloud storage volume ID when you import a volume
Type: string
Suggestion: None
deleteVolume
No
Whether to delete the cloud storage when you import a volume and delete a PVC
Type: boolean
Default: False
Value Constraint: The options are true and false.
Suggestion: None
Relationships Between Elements
Table 2 Relationship description
Target
Dependency
DCS.Redis
Dependency
RDS.MySQL
Dependency
OBS.Bucket
Dependency
CCE.Storage.SFS
Dependency
CCE.Storage.OBS
Dependency
CCE.NodePool
Dependency
CCE.Pod
Inclusion
CCE.Cluster
Return Value
Property
Type
clusterId
string
ID of the cluster which is associated with the OBS file system
refID
string
UID of the OBS file system
refName
string
Name of the OBS file system
Blueprint Example
Example 1:
tosca_definitions_version: cloud_tosca_version_1_0
inputs:
  storage-name:
    default: my-evc-storage
node_templates:
  my-storage:
    type: Cloud.CCE.Storage.OBS
    properties:
      name: {get_input: storage-name}
Example 2: Custom K8s Manifest for Orchestration
  • For clusters of version 1.13 or earlier, the example configuration of the YAML file is as follows:
    node_templates:
      my-storage:
        properties:
          apiVersion: v1
          kind: PersistentVolumeClaim
            annotations:
              volume.beta.kubernetes.io/storage-class: obs-standard
              volume.beta.kubernetes.io/storage-provisioner: flexvolume.com/obs
            namespace: default
            accessModes:
            - ReadWriteMany
            resources:
              requests:
                storage: 10Gi
