CCE.Pod
Element Description
The CCE.Pod element is used to create a pod in the Kubernetes cluster on the CCE.
Element Properties
Property |
Mandatory |
Descripiton |
k8sManifest |
Yes |
Native YAML file content of a Kubernetes object Type: dict Value Description: Customize the value. You are advised to use a public image, which is uploaded to the image repository and whose type is set to public, and not to change the name under the metadata during an update. Value Constraint: This field cannot be left blank. |
name |
No |
Pod name Type: string Value Description: Customize the value, for example, my-pod. Value Constraint: The value supports a maximum of 63 characters and must start with a letter. Only lowercase letters, digits, and hyphens (-) are allowed. |
clusterId |
No |
ID of the cluster to which the resource belongs Type: Cloud.CCE.Cluster.Id Value Description: ID of an existing or new container cluster. Value Constraint: The value must satisfy the UUID rule and contain a maximum of 64 characters. Suggestion: 1. Enter the cluster ID. Specifically, log in to the CCE console, and choose Resource Management > Clusters. Click the target cluster, and you can then obtain its cluster ID. 2. Connect to the cluster object and use the get_reference function to obtain the cluster ID. |
namespace |
No |
Namespace where the resource is located Type: string Value Description: It must be a valid namespace in the cluster, for example, default. Value Constraint: The value must start with a letter. Only lowercase letters, digits, and hyphens (-) are allowed. Suggestion: Log in to the CCE console, and choose Resource Management > Namespaces. View and select the target namespace. |
Relationships Between Elements
Description |
Target |
Dependency |
Dependency |
Dependency |
Dependency |
Dependency |
Dependency |
Dependency |
Inclusion |
Return Value
Property |
Type |
Description |
refName |
string |
Pod name |
Blueprint Example
tosca_definitions_version: cloud_tosca_version_1_0
node_templates:
ccepxbto:
type: Cloud.CCE.Pod
properties:
k8sManifest:
kind: Pod
containers:
- image:
get_input: ccepxbto_k8sManifest_spec_containers_0_image
imagePullSecrets:
- name: default-secret
restartPolicy: Always
imagePullPolicy: Always
apiVersion: v1
labels:
name:
get_input: ccepxbto_name
clusterId:
get_input: ccepxbto_clusterId
namespace:
get_input: ccepxbto_namespace
inputs:
ccepxbto_k8sManifest_spec_containers_0_image:
description: Container image
label: Pod
ccepxbto_name:
description: Pod name
label: Pod
ccepxbto_clusterId:
description: ID of the cluster where the resource is located
label: Pod
ccepxbto_namespace:
description: Namespace where the resource is located
label: Pod
outputs:
name:
value:
get_attribute:
- ccepxbto
- refName
description: pod name
