- Getting Started
User Guide
- Overview
- Resource Management
Application Management
- Creating an Application
- Modifying an Application
- Deleting an Application
- Creating a Component
- Modifying a Component
- Deleted a Component
- Creating a Group
- Modifying a Group
- Deleting a Group
- Transferring Resources
- Viewing Resource Details
- Viewing Capacity Rankings
- Multi-cloud Configurations
- Cross-Account Resources
- Resource O&M
- Automated O&M
- Faults
- Change Management
- Resilience Center
- Task Management
- Basic Configurations
- Viewing Logs
- Best Practices
- API Reference
- Product Consulting
- Resource Management FAQs
FAQs About Resource O&M
Patch Management FAQs
- Why Can't I Select a Node?
- Automation FAQs
- Batch Operation FAQs
- FAQs About Fault Management
- Resilience Center FAQs
- Change History
Viewing Logs
COC Operations That Can Be Audited
With Cloud Trace Service (CTS), you can record operations associated with COC for later query, audit, and backtracking. Table 1 lists the key operations.
Action |
Resource |
Trace |
Creating a war room |
WarRoom |
createWarRoom |
Creating a war room initiation rule |
MeetingRule |
createMeetingRule |
Deleting a war room initiation rule |
MeetingRule |
deleteMeetingRule |
Modifying a war room initiation rule |
MeetingRule |
updateMeetingRule |
Modifying war room information |
WarRoom |
modifyWarRoomInfo |
Sending notifications using war room |
NotificationBriefing |
sendNotificationBriefing |
Adding war room members |
WarRoom |
addWarRoomMember |
Removing a war room member |
WarRoom |
deleteWarRoomMember |
Creating the war room affected applications |
ImpactApplication |
createImpactApplication |
Modifying the war room affected applications |
ImpactApplication |
updateImpactApplication |
Deleting the war room affected applications |
ImpactApplication |
deleteImpactApplication |
Executing actions |
Ticket |
actionTicket |
Creating a service ticket |
Ticket |
createTicket |
Modifying a service ticket |
Ticket |
updateTicket |
Deleting a service ticket |
Ticket |
deleteTicketInfo |
Uploading an attachment |
Attachment |
uploadFileTicket |
Downloading files |
Attachment |
downloadFileTicket |
Updating the integration configuration key |
IntegrationConfig |
updateIntegrationConfigKey |
Accessing integration |
IntegrationConfig |
accessIntegrationConfig |
Disabling Integration |
IntegrationConfig |
disableIntegrationConfig |
Enabling integration |
IntegrationConfig |
enableIntegrationConfig |
Canceling integration |
IntegrationConfig |
removeIntegrationConfig |
Creating a transferring rule |
TransferRule |
createTransferRules |
Modifying a transferring rule |
TransferRule |
updateTransferRules |
Deleting a transferring rule |
TransferRule |
deleteTransferRules |
Disabling a transferring rule |
TransferRule |
disableTransferRules |
Enabling a transferring rule |
TransferRule |
enableTransferRules |
Unsubscription |
NotificationRule |
disableNotificationRule |
Subscription |
NotificationRule |
enableNotificationRule |
Creating a subscription |
NotificationRule |
createNotificationRule |
Deleting a subscription |
NotificationRule |
deleteNotificationRule |
Modifying subscription information |
NotificationRule |
updateNotificationRule |
Creating a scheduling scenario |
ScheduleScene |
createSceneOncall |
Deleting a scheduling scenario |
ScheduleScene |
deleteSceneOncall |
Updating a scheduling scenario |
ScheduleScene |
updateSceneOncall |
Creating a shift role |
ScheduleRole |
createRoleOncall |
Updating a shift role |
ScheduleRole |
updateRoleOncall |
Deleting a shift role |
ScheduleRole |
deleteRoleOncall |
Deleting a fixed scheduled user |
ScheduleUser |
deleteGlobalFixed |
Adding a user to the global fixed shift |
ScheduleUser |
createGlobalFixed |
Updating fixed scheduled users |
ScheduleUser |
updatePersonnelsOncall |
Clearing shifts with one click |
ScheduleUser |
batchDeleteShift |
Creating shift agents in batches |
ScheduleUser |
batchCreateShift |
Updating the shift schedule personnel of a specific day |
ScheduleUser |
UpdateUserShift |
Creating scheduling scenarios and roles |
ScheduleRole |
createRoleOncall |
Creating a custom script |
Document |
createJobScript |
Deleting a custom script |
Document |
deleteJobScript |
Modifying a customized script |
Document |
editJobScript |
Approving a custom script |
Document |
approveJobScript |
Executing a custom script |
Document |
executeJobScript |
Operating the script service ticket |
Job |
jobScriptOrderOperation |
Creating a custom job |
Document |
CreateRunbook |
Deleting a custom job |
Document |
DeleteRunbook |
Modifying a custom job |
Document |
EditRunbook |
Approving a custom job |
Document |
ApproveRunbook |
Executing a custom job |
Job |
ExecuteRunbook |
Executing a public job |
Job |
ExecutePublicRunbook |
Operating the job service ticket |
Job |
OperateJobTicket |
Viewing Logs
- In the upper left corner, select a region and project.
- Click
in the upper left corner. Choose Management & Governance > Cloud Trace Service.
- Choose Trace List in the navigation pane on the left.
- Specify filter criteria as needed.
Figure 1 CTS events
- Select the trace to be viewed and click the trace name to expand the overview.
Figure 2 Trace overview
