- Getting Started
User Guide
- Overview
- Resource Management
Application Management
- Creating an Application
- Modifying an Application
- Deleting an Application
- Creating a Component
- Modifying a Component
- Deleted a Component
- Creating a Group
- Modifying a Group
- Deleting a Group
- Transferring Resources
- Viewing Resource Details
- Viewing Capacity Rankings
- Multi-cloud Configurations
- Cross-Account Resources
- Resource O&M
- Automated O&M
- Faults
- Change Management
- Resilience Center
- Task Management
- Basic Configurations
- Viewing Logs
- Best Practices
- API Reference
- Product Consulting
- Resource Management FAQs
FAQs About Resource O&M
Patch Management FAQs
- Why Can't I Select a Node?
- Automation FAQs
- Batch Operation FAQs
- FAQs About Fault Management
- Resilience Center FAQs
- Change History
Configuring Approval Settings
Overview
Users can configure the change type, change level, review process, and reviewer.
Creating an Approval Configuration
- Log in to COC.
- In the navigation pane on the left, choose Change Ticket Management > Change Configuration. On the displayed page, click Create Approval Configuration.
Figure 1 Creating a review configuration
- Enter the approval configuration content and click Submit.
Figure 2 Setting the review configurations
1. Basic Information
One change type and multiple change classes can be selected at a time.
2. Approval Configuration
The approval name is automatically generated.
The approver is determined by the scheduling scenario and scheduling role.
Approval rule: one person through or fully approved
3. Adding Multiple Approval Levels
Note: A scheduling role takes effect only after the reviewer is configured. If the reviewer is not specified, the change request cannot be submitted.
Modifying the review configuration
- Log in to COC.
- In the navigation pane on the left, choose Change Management > Change Configurations. On the displayed page, locate the target record, click Modify in the Operation column to modify the review configuration information.
Figure 3 Modifying review configuration
Deleting review configuration
- Log in to COC.
- In the navigation pane on the left, choose Change Management > Change Configurations. On the displayed page, locate the target record, click Delete in the Operation column to delete the review configuration information.
Figure 4 Deleting review configuration
