- Getting Started
User Guide
- Overview
- Resource Management
Application Management
- Creating an Application
- Modifying an Application
- Deleting an Application
- Creating a Component
- Modifying a Component
- Deleted a Component
- Creating a Group
- Modifying a Group
- Deleting a Group
- Transferring Resources
- Viewing Resource Details
- Viewing Capacity Rankings
- Multi-cloud Configurations
- Cross-Account Resources
- Resource O&M
- Automated O&M
- Faults
- Change Management
- Resilience Center
- Task Management
- Basic Configurations
- Viewing Logs
- Best Practices
- API Reference
- Product Consulting
- Resource Management FAQs
FAQs About Resource O&M
Patch Management FAQs
- Why Can't I Select a Node?
- Automation FAQs
- Batch Operation FAQs
- FAQs About Fault Management
- Resilience Center FAQs
- Change History
On this page
Show all
Help Center/
Cloud Operations Center/
User Guide/
Basic Configurations/
O&M Engineer Management/
O&M Engineer Management Overview
You can centrally O&M engineer personnel on COC using this feature. You can manage users of the current tenant on the O&M Engineer Management page. The basic user data in the O&M Engineer Management page is synchronized from IAM and is used by multiple basic functional modules, such as to-do task creation, scheduled O&M, notification management, and incident center.
- On the personnel management page, you can manually select users you want to edit, delete, and configure subscription information for.
- If you edit the information of an existing user, the system background creates a corresponding subscription mode after you specify a communication method, such as mobile number, email address, WeCom, DingTalk, or Lark.
- On the O&M Engineer Management page, the notification methods in gray indicates that the user does not subscribe to the notification methods or does not confirm the subscriptions. The notification methods in black indicates that the user has subscribed to the notification methods and has confirmed the subscriptions.
Parent topic: O&M Engineer Management
