- Getting Started
User Guide
- Overview
- Resource Management
Application Management
- Creating an Application
- Modifying an Application
- Deleting an Application
- Creating a Component
- Modifying a Component
- Deleted a Component
- Creating a Group
- Modifying a Group
- Deleting a Group
- Transferring Resources
- Viewing Resource Details
- Viewing Capacity Rankings
- Multi-cloud Configurations
- Cross-Account Resources
- Resource O&M
- Automated O&M
- Faults
- Change Management
- Resilience Center
- Task Management
- Basic Configurations
- Viewing Logs
- Best Practices
- API Reference
- Product Consulting
- Resource Management FAQs
FAQs About Resource O&M
Patch Management FAQs
- Why Can't I Select a Node?
- Automation FAQs
- Batch Operation FAQs
- FAQs About Fault Management
- Resilience Center FAQs
- Change History
On this page
Show all
Help Center/
Cloud Operations Center/
User Guide/
Task Management/
Execution Records/
Script Tickets
Script Tickets
You can view and manage script tickets.
If you deliver a script execution task, the system generates a script ticket.
View script tickets on the Cloud Operations Center page.
- Log in to COC.
- In the navigation pane on the left, choose Task Management > Execution Records and click the Script Tickets tab.
Figure 1 Script Tickets
- Select a script service ticket in the Abnormal status and click the script name. The Ticket Details page is displayed.
Figure 2 Selecting a script ticket in the Abnormal status
- Click Forcibly End to close the abnormal script ticket.
Figure 3 Closing an abnormal script ticket
- Locate a script service ticket in the Executing status and click the script name. The Ticket Details page is displayed.
Figure 4 Selecting a script ticket in the Executing status
- Click Pause or Forcibly End to pause or close the script ticket.
Figure 5 Pausing or closing a script ticket
- Locate a script service ticket in the Paused status and click the script name. The Ticket Details page is displayed.
Figure 6 Selecting a script ticket in the Paused status
- Click Continue or Forcibly End to continue or close the script ticket.
Figure 7 Continuing or closing a paused script ticket
Parent topic: Execution Records
