Customizing a Fault
Create a drill task with a custom fault as the attack scenario on COC.
Precautions
A custom fault is determined by the script you compiled. Therefore, when scripts are used to attack ECSs, exceptions such as high resource usage and network faults may occur. As a result, the status of the UniAgent installed on the ECSs may change to offline or abnormal. Exercise caution when performing this operation.
Creating a Custom Fault
Create a drill task for a custom fault attack scenario on COC.
- Log in to COC.
- In the navigation pane on the left, choose Resilience Center > Chaos Drill. On the displayed page, click the Drill Tasks tab and create an attack task by referring to Step 2 to Step 6.
- Enter the attack task name, select Elastic Cloud Server (ECS) as Source of Attack Target, and click Next.
Figure 1 Selecting ECS as the attack target source
- On the Select Attack Scenario procedure, click Custom fault, and then Custom Scripts. If a custom fault script exists, you can select it. If no custom fault script available, you need to create a script.
Figure 2 Selecting the custom fault
1. Timeout Interval (s): used to limit the maximum time allowed for script execution. The timeout interval must be longer than the script execution time. You are advised to set the timeout interval to at least 30 seconds.
- To create a custom fault script, click Scripts. The Automated O&M > Scripts page is displayed. Click Create Script. For details about how to create a script, see section Creating a Custom Script. For details about the script specifications, see the following code:
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49
#!/bin/bash set +x function usage() { echo "Usage: {inject_fault|check_fault_status|rollback|clean}" exit 2 } function inject_fault() { echo "inject fault" } function check_fault_status() { echo "check fault status" } function rollback() { echo "rollback" } function clean() { echo "clean" } case "$ACTION" in inject_fault) inject_fault ;; check_fault_status) check_fault_status ;; rollback) if [[ X"${CAN_ROLLBACK}" == X"true" ]]; then rollback else echo "not support to rollback" fi ;; clean) clean ;; *) usage ;; esac
You are advised to define a custom fault script based on the preceding script specifications. In the preceding specifications, you can define the fault injection function, fault check function, fault rollback function, and environment clearing function by compiling customized content in the inject_fault(), check_fault_status(), rollback() and clean() functions.
According to the preceding specifications, there are two mandatory script parameters: Whether other script parameters are included depends on your script content.
Table 1 Mandatory parameters for customizing a fault script Parameter
Value
ACTION
inject_fault
Drill operation action. The value is automatically changed by the system background in different drill phases. The value can be:
- inject_fault: The drill is in the fault injection phase.
- check_fault_status: The drill is in the fault query phase.
- rollback: The drill is in the phase of canceling the fault injection.
- clean: The drill is in the environment clearing phase.
CAN_ROLLBACK
false
Whether rollback is supported. The options are as follows:
- true: When the drill is in the phase of canceling the fault injection, the rollback() function is executed.
- false: When the drill is in the phase of canceling the fault injection, the rollback() function is not executed.
1. In the inject_fault function, add a flag indicating that the fault injection is successful, and check whether the flag exists in the check_fault_status function. If yes, the check_fault_status function can return normally (for example, exit 0). If no, the check_fault_status function can return abnormally (for example, exit 1).
- If you already have a custom script, you can select the script based on the script name. The script content and parameters are displayed. Enter a proper timeout interval and click Next.
Figure 3 Selecting a custom script
- Create a drill task with the custom fault by referring to Step 9 to Step 17.
Custom Script Example
The following is an example of a customized script.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 |
#!/bin/bash set +x PATH=/bin:/sbin:/usr/bin:/usr/sbin:/usr/local/bin:/usr/local/sbin:~/bin export PATH function usage() { echo "Usage: {inject_fault|check_fault_status|rollback|clean}" exit 2 } function inject_fault() { echo "============start inject fault============" if [ ! -d "${SCRIPT_PATH}/${DIR_NAME}" ]; then mkdir -p "${SCRIPT_PATH}/${DIR_NAME}" echo "mkdir ${SCRIPT_PATH}/${DIR_NAME} successfully" fi cd "${SCRIPT_PATH}/${DIR_NAME}" if [ ! -f ${FILE} ]; then touch "${FILE}" echo "create tmp file ${FILE}" touch inject.log chmod u+x "${FILE}" chmod u+x inject.log else echo "append content">${FILE} fi echo "successfully inject">${FILE} echo "============end inject fault============" } function check_fault_status() { echo "============start check fault status============" if [ ! -d "${SCRIPT_PATH}/${DIR_NAME}" ]; then echo "inject has been finished" exit 0 fi cd "${SCRIPT_PATH}/${DIR_NAME}" SUCCESS_FLAG="successfully inject" if [ -f ${FILE} ]; then if [[ "$(sed -n '1p' ${FILE})" = "${SUCCESS_FLAG}" ]]; then echo "fault inject successfully" else echo "fault inject failed" exit 1 fi else echo "inject finished" exit 0 fi sleep ${DURATION} echo "============end check fault status============" } function rollback() { echo "============start rollback============" cd "${SCRIPT_PATH}" if [ -d $DIR_NAME ]; then rm -rf "${SCRIPT_PATH}/${DIR_NAME}" fi echo "============end rollback============" } function clean() { echo "============start clean============" cd "${SCRIPT_PATH}" if [ -d $DIR_NAME ]; then rm -rf "${SCRIPT_PATH}/${DIR_NAME}" fi echo "============end clean============" } case "$ACTION" in inject_fault) inject_fault ;; check_fault_status) check_fault_status ;; rollback) if [[ X"${CAN_ROLLBACK}" == X"true" ]]; then rollback else echo "not support to rollback" fi ;; clean) clean ;; *) usage ;; esac |
The input parameters of the script are as follows:
Parameter |
Value |
Description |
ACTION |
inject_fault |
Drill operation action |
CAN_ROLLBACK |
false |
Rollback is not supported. |
SCRIPT_PATH |
/tmp |
Root directory of the custom fault log |
DIR_NAME |
test_script |
Parent directory of the custom fault log |
FILE |
test.log |
Custom fault log name |
DURATION |
10 |
Duration of a simulated custom fault, in seconds. (This parameter does not take effect when it is placed in the inject_fault function.) |
1. In the sample inject_fault function, the injected fault is to create a {FILE} file and add content to the {FILE} file. If successfully inject is entered in the {FILE} file, the fault injection is successful.
2. In the example, the check_fault_status function checks whether the {FILE} file exists. If no, the fault may have been cleared. In this case, exit 1 is returned. If yes, check whether the flag indicating that the fault injection is successful exists. If the flag exists, the fault injection is successful. Here, sleep {DURATION} is used to simulate the fault duration. If the flag does not exist, the fault injection fails.
