Logging In to a Host Without Any Passwords
COC allows you to use the account management function to implement password-free login to hosts. This function applies only to ECSs that run the Linux OS. You can select the target account on the password-free login module to go to the command execution page. Note that the account must meet the following conditions:
- Corresponding parameters have been configured in the account baseline.
 - The current account can be found in the target host system.
Currently, password-free login is supported only in the CN North-Beijing4 region.
Precautions
Prerequisites for a successful remote login to a host:
- A UniAgent has been installed and is running on the target host. The UniAgent version must be later than 1.1.3.8.
 - The host is in the running state.
 - Accounts configured in the baseline or imported accounts can be found on the target host.
 - The account has a home directory. The default directory is /home/account name.
If an account does not have a home directory, run the following command to create a home directory so that the password-free login function can be used.
Assume that the username is user1.
- Create a directory. (-p ensures that the parent directory is available. If the /home directory cannot be found, it will be automatically created.)
sudo mkdir -p /home/user1
 - Copy all default configurations (including hidden files).
sudo cp -r /etc/skel/. /home/user1/
 - Use the recursive function to change the owner and group of the /home/user1 directory and all its subdirectories and files to user user1 and group user1.
sudo chown -R user1:user1 /home/user1
 - Set the permission to 700, that indicates only the owner has the permission.
sudo chmod 700 /home/user1
 - The -d option specifies the new home directory path.
sudo usermod -d /home/user1 user1
- Log in to COC.
 - In the navigation pane on the left, choose Resource O&M > Automated O&M.
 - In the Routine O&M area, and click Account Management.
 - Choose Accounts > By Resource or By Application.
- By Resource applies to all purchased host instances.
 - By Application applies to purchased hosts that have been bound to an application. If you select By Application, you need to select the target application or component.
 - Select a resource type.
By default, Elastic Cloud Server (ECS) is selected.
 - Choose Password-free Login in the Operation column.
 - Select the target account from the drop-down list and click OK.
The black screen command page is displayed.
