- Getting Started
User Guide
- Overview
- Resource Management
Application Management
- Creating an Application
- Modifying an Application
- Deleting an Application
- Creating a Component
- Modifying a Component
- Deleted a Component
- Creating a Group
- Modifying a Group
- Deleting a Group
- Transferring Resources
- Viewing Resource Details
- Viewing Capacity Rankings
- Multi-cloud Configurations
- Cross-Account Resources
- Resource O&M
- Automated O&M
- Faults
- Change Management
- Resilience Center
- Task Management
- Basic Configurations
- Viewing Logs
- Best Practices
- API Reference
- Product Consulting
- Resource Management FAQs
FAQs About Resource O&M
Patch Management FAQs
- Why Can't I Select a Node?
- Automation FAQs
- Batch Operation FAQs
- FAQs About Fault Management
- Resilience Center FAQs
- Change History
On this page
Show all
Key Management
Configuring a Key
- Log in to COC.
- In the navigation pane on the left, choose Resource O&M > Automated O&M. In the Routine O&M area, click Account Management.
- Click Keys in the upper right corner of the page, or click Configure in Configure Keys under Account Management Flowchart.
Figure 1 Configuring keys
- On the Keys page, click Bind Key. On the displayed Bind Key page, select the key to be bound. If no key is available, click Create Key to go to the DEW service to create a key. After creating a key, refresh the list and select it. Click OK.
Figure 2 Binding a key
- In the Bind Key confirmation dialog box, a message is displayed, indicating that the bound key cannot be updated once it is used. Click OK.
Figure 3 Confirming the binding
- If you need to update the key, click Update.
Figure 4 Key binding succeeded
Parent topic: Account Management
