Help Center/ Cloud Operations Center/ User Guide/ Using IAM to Grant Access to COC/ Service-specific Condition Keys Supported by COC
Updated on 2025-09-11 GMT+08:00
Request conditions are useful in determining when a custom policy is in effect. A request condition consists of condition keys and operators. Condition keys are either global or service-specific and are used in the Condition element of a policy statement. Global condition keys (starting with g:) are available for operations of all services, while service-level condition keys (starting with a service name such as coc) are available only for operations of a specific service. An operator must be used together with a condition key to form a complete condition statement.
Table 1 Service-specific condition keys supported by COC
Type
Single-valued/Multivalued
coc:TicketLevel
String
Single-valued
Filters access based on the ticket level in the request parameter.
coc:TicketCurrentHandlers
String
Multivalued
Filters access based on the ticket operator in the request parameter.
coc:TicketStatus
String
Single-valued
Filters access based on the ticket status in the request parameter.
coc:TicketType
String
Single-valued
Filters access based on the ticket type in the request parameter.
coc:TicketBeginTime
date
Single-valued
Filters access based on the ticket start time in the request parameter.
coc:TicketEndTime
date
Single-valued
Filters access based on the ticket end time in the request parameter.
coc:OperatorName
String
Single-valued
Filters access based on the operator in the request parameter.
coc:RequestTarget
String
Single-valued
Filters access based on the privilege escalation application in the request parameter.
coc:TicketTarget
String
Multivalued
Filters access based on the ticket application in the request parameter.
coc:TicketScope
String
Multivalued
Filters access based on the ticket scope in the request parameter.
coc:RequestScope
String
Single-valued
Filters access based on the privilege escalation scope in the request.
coc:EscapeSwitchIsEnabled
boolean
Single-valued
Filters access based on the escape switch in the request parameter.
coc:Creator
String
Single-valued
Filters access based on the creator of resource in COC.
coc:Executor
String
Single-valued
Filters access based on the executor specified by the service ticket in COC.
coc:DocumentRiskLevel
String
Single-valued
Filters access based on the document risk level specified in the request parameter.
coc:JobType
String
Single-valued
Filters access based on the service ticket type specified in the request parameter.
coc:ApplicationCode
String
Multivalued
Filters access based on the application code specified in the request parameter.
coc:ApplicationGroupCode
String
Single-valued
Filters access based on the application group code specified in the request parameter.
coc:AttackTargetType
String
Single-valued
Filters access based on the attack target type specified in the request parameter.
coc:QuickSetupType
String
Single-valued
Filters access based on the request configuration type specified in the request parameter.
