Updated on 2026-09-21 GMT+08:00
Viewing Resource Types Supported by COC
A resource is an object that is contained in a service. Table 1 lists the resources supported by COC. You can specify resource paths to select specific resources when creating a custom policy.
Table 1 COC resources and their paths
Resource Type
Resource Name
Path
instance
ECS
Format:
ecs:*:*:instance:ECS instance ID
[Description]
For ECS resources, IAM automatically generates the prefix ecs:*:*:instance: of the resource path.
You can use ECS ID to specify a resource path. Wildcards (*) are supported. The following is an example:
ecs:*:*:instance:* indicates any ECS ID.
BMSs
Format:
bms:*:*:instance:BMS ID
[Description]
For BMS resources, IAM automatically generates the prefix bms:*:*:instance: of the resource path.
You can use a BMS instance ID to specify the resource path. The wildcard (*) is supported. The following is an example:
bms:*:*:instance:* indicates any BMS ID.
GaussDB instance
Format:
GaussDB:*:*:instance:GaussDB instance ID
[Description]
For GaussDB instance resources, IAM automatically generates the prefix (gaussdb:*:*:instance:) of the resource path.
You can use a GaussDB instance ID to specify a resource path. The wildcard (*) is supported. The following is an example:
gaussdb:*:*:instance:* indicates any GaussDB instance ID.
RDS instance
Format:
rds:*:*:instance:RDS instance ID
[Description]
For RDS instance resources, IAM automatically generates the prefix (rds:*:*:instance:) of the resource path.
You can use an RDS DB instance ID to specify the resource path. The wildcard (*) is supported. The following is an example:
rds:*:*:instance:* indicates any RDS DB instance ID.
document
Document
Format:
coc:*:*:document:document name
[Description]
For document resources, IAM automatically generates the resource path prefix coc:*:*:document:.
You can use a document name to specify the resource path. The wildcard (*) is supported. The following is an example:
coc:*:*:document:* indicates any document.
application
Application
Format:
coc:*:*:application:application code
[Description]
For application resources, IAM automatically generates the resource path prefix coc:*:*:application:.
You can use an application code to specify the resource path. The wildcard (*) is supported. The following is an example:
coc:*:*:application:* indicates any application.
resourceView
Resource views
Format:
coc:*:*:resourceView:application code
[Description]
For resource view resources, IAM automatically generates the resource path prefix coc:*:*:resourceView:.
You can use a resource view ID to specify the resource path. The wildcard (*) is supported. The following is an example:
coc:*:*:resourceView:* indicates any resource view.
schedule
Scheduled O&M
Format:
coc:*:*:schedule:scheduled task ID
[Description]
For scheduled O&M resources, IAM automatically generates the resource path prefix coc:*:*:schedule.
You can use a scheduled task ID to specify the resource path. The wildcard (*) is supported. The following is an example:
coc:*:*:schedule:* indicates any scheduled O&M.
job
Task
Format:
coc:*:*:job:task ID
[Description]
For task resources, IAM automatically generates the resource path prefix coc:*:*:job:.
You can use a task ID to specify the resource path. The wildcard (*) is supported. The following is an example:
coc:*:*:job:* indicates any task.
faultMode
Failure modes
Format:
coc:*:*:faultMode:failure mode ID
[Description]
For failure mode resources, IAM automatically generates the resource path prefix coc:*:*:faultMode:.
You can use a failure mode ID to specify the resource path. The wildcard (*) is supported. The following is an example:
coc:*:*:faultMode:* indicates any failure mode.
contingencyPlan
Contingency plans
Format:
coc:*:*:contingencyPlan:contingency plan ID
[Description]
For contingency plan resources, IAM automatically generates the resource path prefix coc:*:*:contingencyPlan:.
You can use a contingency plan ID to specify the resource path. The wildcard (*) is supported. The following is an example:
coc:*:*:contingencyPlan:* indicates any contingency plan.
attackTask
Attack task
Format:
coc:*:*:attackTask:attack task name
[Description]
For attack task resources, IAM automatically generates the resource path prefix coc:*:*:attackTask:.
You can use an attack task name to specify the resource path. The wildcard (*) is supported. The following is an example:
coc:*:*:attackTask:* indicates any attack task.
attackRecord
Attack record
Format:
coc:*:*:attackRecord:attack record ID
[Description]
For attack record resources, IAM automatically generates the resource path prefix coc:*:*:attackRecord:.
You can use an attack record ID to specify the resource path. The wildcard (*) is supported. The following is an example:
coc:*:*:attackRecord:* indicates any attack record.
drillTask
Drill task
Format:
coc:*:*:drillTask:drill task ID
[Description]
For drill task resources, IAM automatically generates the resource path prefix coc:*:*:drillTask:.
You can use a drill task ID to specify the resource path. The wildcard (*) is supported. The following is an example:
coc:*:*:drillTask:* indicates any drill task.
attackTargetRecord
Attack target record of an attack task
Format:
coc:*:*:attackTargetRecord: attack target record ID of an attack task
[Description]
For the attack target record resource of an attack task, IAM automatically generates the resource path prefix coc:*:*:attackTargetRecord:.
You can use an attack target record ID of an attack task to specify a resource path. The wildcard (*) is supported. The following is an example:
coc:*:*:attackTargetRecord:* indicates the attack target record of any attack task.
drillRecord
Drill record
Format:
coc:*:*:drillRecord:drill record ID
[Description]
For drill record resources, IAM automatically generates the resource path prefix coc:*:*:drillRecord:.
You can use a drill record ID to specify a resource path. The wildcard (*) is supported. The following is an example:
coc:*:*:drillRecord:* indicates any drill record.
drillPlan
Drill plans
Format:
coc:*:*:drillPlan: drill plan ID
[Description]
For drill plan resources, IAM automatically generates the resource path prefix coc:*:*:drillPlan:.
You can use a drill plan ID to specify a resource path. The wildcard (*) is supported. The following is an example:
coc:*:*:drillPlan:* indicates any drill plan.
slaTemplate
SLA templates
Format:
coc:*:*:slaTemplate:SLA template ID
[Description]
For SLA template resources, IAM automatically generates the resource path prefix coc:*:*:slaTemplate:.
You can use an SLA template ID to specify the resource path. The wildcard (*) is supported. The following is an example:
In the preceding command, coc:*:*:slaTemplate:* indicates any SLA template.
parameter
Configuration item
Format:
coc:*:*:parameter:configuration item name.
[Description]
For configuration item resources, IAM automatically generates the resource path prefix coc:*:*:parameter:.
You can use a configuration item name to specify the resource path. The wildcard (*) is supported. The following is an example:
coc:*:*:parameter:* indicates any configuration item.
accountBaseline
Account baselines
Format:
coc:*:*:accountBaseline:account baseline ID
[Description]
For account baseline resources, IAM automatically generates the resource path prefix coc:*:*:accountBaseline:.
You can use an account baseline ID to specify a resource path. The wildcard (*) is supported. The following is an example:
coc:*:*:accountBaseline:* indicates any account baseline.
provisionedProduct
Product instances
Format:
coc:*:*:provisionedProduct:product instance ID
[Description]
For product instance resources, IAM automatically generates the resource path prefix coc:*:*:provisionedProduct:.
You can use a product instance ID to specify the resource path. The wildcard (*) is supported. The following is an example:
coc:*:*:provisionedProduct:* indicates any product instance.
product
Product
Format:
coc:*:*:product:product ID
[Description]
For product resources, IAM automatically generates the prefix coc:*:*:product: of the resource path.
You can use a product ID to specify the resource path. The wildcard (*) is supported. The following is an example:
coc:*:*:product:* indicates any product.
portfolio
Product portfolio
Format:
coc:*:*:portfolio:product portfolio ID
[Description]
For product portfolio resources, IAM automatically generates the resource path prefix coc:*:*:portfolio:.
You can use a product portfolio ID to specify the resource path. The wildcard (*) is supported. The following is an example:
coc:*:*:portfolio:* indicates any product combination.
sloDiagram
SLO architecture design diagram
Format:
coc:*:*:sloDiagram:SLO architecture design diagram ID
[Description]
For SLO architecture design diagram resources, IAM automatically generates the resource path prefix coc:*:*:sloDiagram:.
You can use an SLO architecture design diagram ID to specify the resource path. The wildcard (*) is supported. The following is an example:
coc:*:*:sloDiagram:* indicates any SLO architecture design diagram.
template
Template
Format:
coc:*:*:template:template ID
[Description]
For template resources, IAM automatically generates the resource path prefix coc:*:*:template:.
You can use a template ID to specify the resource path. The wildcard (*) is supported. The following is an example:
coc:*:*:template:* indicates any template.
templateInstance
Template instance
Format:
coc:*:*:templateInstance:template instance ID
[Description]
For template instance resources, IAM automatically generates the prefix coc:*:*:templateInstance: of the resource path.
You can use a template instance ID to specify the resource path. The wildcard (*) is supported. The following is an example:
coc:*:*:templateInstance:* indicates any template instance.
vm
VMs
Format:
coc:*:*:vm: VM ID
[Description]
For VM resources, IAM automatically generates the resource path prefix coc:*:*:vm:.
You can use a VM ID to specify a resource path. The wildcard (*) is supported. The following is an example:
coc:*:*:vm:* indicates any VM.
