Updated on 2024-01-04 GMT+08:00
Management Nodes
- Managing Node Labels
You can add different labels to nodes and define different attributes for labels. By using these node labels, you can quickly understand the characteristics of each node. - Managing Node Taints
- Resetting a Node
- Removing a Node
- Synchronizing Data with Cloud Servers
- Draining a Node
- Deleting a Node
- Stopping a Node
- Performing Rolling Upgrade for Nodes
Parent topic: Nodes
