Halaman ini belum tersedia dalam bahasa lokal Anda. Kami berusaha keras untuk menambahkan lebih banyak versi bahasa. Terima kasih atas dukungan Anda.
- Getting Started
User Guide
- Overview
- Resource Management
Application Management
- Creating an Application
- Modifying an Application
- Deleting an Application
- Creating a Component
- Modifying a Component
- Deleted a Component
- Creating a Group
- Modifying a Group
- Deleting a Group
- Transferring Resources
- Viewing Resource Details
- Viewing Capacity Rankings
- Multi-cloud Configurations
- Cross-Account Resources
- Resource O&M
- Automated O&M
- Faults
- Change Management
- Resilience Center
- Task Management
- Basic Configurations
- Viewing Logs
- Best Practices
- API Reference
- Product Consulting
- Resource Management FAQs
FAQs About Resource O&M
Patch Management FAQs
- Why Can't I Select a Node?
- Automation FAQs
- Batch Operation FAQs
- FAQs About Fault Management
- Resilience Center FAQs
- Change History
On this page
Show all
Help Center/
Cloud Operations Center/
User Guide/
Basic Configurations/
SLO Management/
Viewing an SLO
Viewing an SLO
Viewing an SLO
- Log in to COC.
- In the navigation pane on the left, choose Basic Configurations > SLO Management.
Figure 1 SLOs
- Click the search box. The search criteria list is displayed. Select search criteria, enter values, and press Enter to search for data. You can click the refresh icon next to the search box to refresh the data and set the fields to be displayed in the list.
Figure 2 Filtering SLOs
- Click
in the list to view details.
Figure 3 SLO details - Click Create SLO in the upper right corner, and select the corresponding application and SLO target value to create an SLO.
Figure 4 Creating an SLO
- In the SLO management list, locate an SLO metric, click More > Modify in the Operation column to modify the SLO metric.
- In the SLO management list, locate an SLO metric, click More > Delete in the Operation column to delete the SLO metric.
Parent topic: SLO Management
