Halaman ini belum tersedia dalam bahasa lokal Anda. Kami berusaha keras untuk menambahkan lebih banyak versi bahasa. Terima kasih atas dukungan Anda.
On this page
Batch Stopping Flexus L Instances
Updated on 2024-11-20 GMT+08:00
Stop Flexus L instances in batches on COC.
Precautions
Stopped instances cannot be selected.
  1. Log in to COC.
  2. In the navigation pane on the left, choose Resource O&M > Resource Batch Operations, and click Shut Down FlexusL in Batch FlexusL Operations.
  3. On the Shut Down FlexusL page, click Add.
    Figure 1 Selecting instances
  4. Select Batch Policy.
    • Automatic: The selected hosts are automatically divided into multiple batches based on the preset rule.
    • Manual: You can manually create multiple batches and add instances to each batch as required.
    • No batch: All target instances are in the same batch.
  5. Set Suspension Policy.
    • You can set the execution success rate. When the number of failed hosts reaches the pre-set suspension threshold figure, the service ticket status becomes abnormal and the service ticket stops being executed.
    • The value range is from 0 to 100 and can be set to one decimal place.
  6. Click Submit.
    Figure 2 Stopping instances
  7. In the Confirm Execution dialog box, click OK.
    Figure 3 Confirming the execution
  8. View the execution result.
    Figure 4 Viewing the result
  9. If the execution result is abnormal, you can click the Retry button in the Operation column or the Batch Retry button above the list to re-execute the failed one or more tasks. You can also click the Cancel button in the Operation column or Batch Cancel button above the list to skip one or more abnormal tasks.
    Figure 5 Canceling or retrying batch tasks
Kami menggunakan cookie untuk meningkatkan kualitas situs kami dan pengalaman Anda. Dengan melanjutkan penelusuran di situs kami berarti Anda menerima kebijakan cookie kami. Cari tahu selengkapnya
