Halaman ini belum tersedia dalam bahasa lokal Anda. Kami berusaha keras untuk menambahkan lebih banyak versi bahasa. Terima kasih atas dukungan Anda.
- Getting Started
User Guide
- Overview
- Resource Management
Application Management
- Creating an Application
- Modifying an Application
- Deleting an Application
- Creating a Component
- Modifying a Component
- Deleted a Component
- Creating a Group
- Modifying a Group
- Deleting a Group
- Transferring Resources
- Viewing Resource Details
- Viewing Capacity Rankings
- Multi-cloud Configurations
- Cross-Account Resources
- Resource O&M
- Automated O&M
- Faults
- Change Management
- Resilience Center
- Task Management
- Basic Configurations
- Viewing Logs
- Best Practices
- API Reference
- Product Consulting
- Resource Management FAQs
FAQs About Resource O&M
Patch Management FAQs
- Why Can't I Select a Node?
- Automation FAQs
- Batch Operation FAQs
- FAQs About Fault Management
- Resilience Center FAQs
- Change History
On this page
Show all
Managing Custom Jobs
You can modify, clone, and delete recorded custom jobs.
Modify, clone, or delete a custom job on Cloud Operations Center.
Precautions
When modifying or cloning a job, determine and fill out the risk level of the job.
- Log in to COC.
- In the navigation pane on the left, choose Resource O&M > Automated O&M. In the Routine O&M area, click Jobs.
Figure 1 Job Management page
- Locate the target job, and click the operation to be performed on the job, including Execute, Modify, Clone, Delete.
- Modifying a job: Click Modify in the Operation column. For details, see section Creating a Custom Job. Click Cancel to cancel the modification, and click Submit to update the job information and the job version number.
- Cloning a job: Choose More > Clone in the Operation column. You can modify the cloned job based on the operations described in Creating a Custom Job. You can click Cancel to cancel the modification. You can click Submit to create a job.
- Deleting a job: Choose More > Delete to delete a job.
- Modifying a tag: You can modify job tags by following the instructions provided in Tag Management.
Figure 2 Performing operations on a job
Parent topic: Jobs
