Viewing Patch Scan and Repair Details
The results of patch scan and patch repair are also called patch compliance reports. To view details about a patch in the compliance report, perform operations in this section.
Precautions
The patch compliance report will only retain the most recent scan or repair record.
- Log in to COC.
- In the navigation pane on the left, choose Resource O&M > Automated O&M.
- In the Routine O&M area, click Patch Management.
- On the Patch Scanning tab page, select the resource type of the instance whose patch needs to be viewed.
By default, ECS is selected.
- Locate the target instance and click Summary in the Operation column.
Status description:
- Installed: The patch complies with the patch baseline, has been installed on an ECS, and no update is available.
- Non-baseline Patches Installed: The patch is not compliant with the patch baseline but has been installed on an ECS.
- Installed-to be Restarted: The patch has been repaired, and can take effect only after the ECS is restarted.
- Installed Rejected: The rejected patch defined in the abnormal patches of a patch baseline. This patch will not be repaired even if it is compliant with the patch baseline.
- Pending Repair: The patch complies with the baseline, but the patch version is earlier than the baseline version.
- Patch Repair Failed: The patch repair fails.
