Updated on 2026-06-23 GMT+08:00
Scanning Patch Compliance
You can scan the patch compliance of the target instance based on the selected patch baseline, instance, and batch execution policy. The scan result displays the compliance status of the instance patch.
Currently, multiple OSs, such as EulerOS and CentOS, are supported. COC matches the default patch baseline based on the OS of the selected instance for scanning and repair. Before using this function, ensure that the corresponding default patch baseline has been created.
  • Before performing a patch scan, you have created a patch baseline by referring to Creating a Patch Baseline and set it as the preset patch baseline.
  • Before performing a patch scan, you have bound the selected instance to an EIP or NAT gateway so that the instance can access the internet.
Precautions
If an instance cannot be selected, check whether:
  • The UniAgent status of the instance is normal.
  • The OS is supported by the COC patch management function.
  • The instance is in the stopped state.
Creating a Patch Scan Task
  1. Log in to COC.
  2. In the navigation pane, choose Resource O&M > Automated O&M.
  3. In the Routine O&M area, click Patch Management. The Patch Management page is displayed.
  4. On the displayed page, click the Patch Scanning tab and choose a resource type to create.
    By default, ECS is selected.
  5. Click Create Patch Scanning Task.
  6. Set parameters in the Execution Account & Region area.
    Execution Type: Select Single or Cross Account.
    • Single: Execute this job only under the current account.
    • Cross Account: Execute this job using multiple organization member accounts.
    • To use this function, you need to add the account to an organization, configure the agency permissions, and enter the agency name in advance. For details, see Enabling COC Cross-Account Management.
  7. Set a scheduled task. The Execution Mode can be Execute immediately or Scheduled execution.
    • Execute immediately: Execute the scanning task immediately after it is created.
    • Scheduled execution: Configure the scheduled task details.
      Table 1 Scheduled task parameters
      Time Zone
      Select the time zone where the scheduled task is executed from the drop-down list.
      Timing Type
      Select a scheduled type.
      • Single execution: A scheduled task is executed once at a specified time.
      • Periodic execution: A task is periodically executed based on the specified rule until the rule expires.
      Execution Time
      It is used together with the timing type.
      • For a one-time execution, set this parameter to the execution time.
      • For periodic execution, select either of the following options:
        • Simple: Select the execution time by week.
        • Cron: Set the execution time using a cron expression. For details, see Using Cron Expressions.
      Rule Expired
      This parameter needs to be set when Timing Type is set to Periodic execution.
      Enter the end time of the periodic execution rule.
      Notification Policy
      Policy for sending notifications. The options are Start execution, Execution failed, and Execution succeeded. You can select multiple options.
      • Start execution: When a scan job starts, a notification is sent to the specified recipient.
      • Execution failed: When a scan job fails to be executed, a notification is sent to the specified recipient.
      • Execution succeeded: When a scan job is successfully executed, a notification is sent to the specified recipient.
      Recipient
      Select Shift or Individual.
      • Shift: Select a shift scenario and a role from the drop-down lists based on the configured values. For details about how to configure a shift, see Shift Schedule Management.
      • Individual: Select a reviewer. For details about how to configure a reviewer, see Personnel Management.
      Notification Mode
      Select a notification channel from the drop-down list.
      • Default: The notification channel selected in the subscription notification settings of the reviewer is used by default. For details about how to set the default notification channel, see Selecting a Notification Method.
      • SMS, WeCom, DingTalk, Lark, and Email: Notifications are sent based on the information reserved by the reviewer. For details about how to set the reviewer information, see Modifying Personnel Information.
  8. Configure the basic information.
    • If Execution Mode is set to Execute immediately, set this parameter based on the information in Table 2.
      Table 2 Basic information for immediate execution
      Executed By
      The preset value is root and cannot be changed.
      Timeout Interval
      The maximum duration allowed for a scan.
    • If Execution Mode is set to Scheduled execution, set this parameter by referring to Table 3.
      Table 3 Basic information about scheduled task execution
      Task Name
      You are advised to name the task based on the application scenario.
      The value can contain 3 to 100 characters, including letters, digits, hyphens (-), and underscores (_).
      Enterprise Project
      Select an enterprise project from the drop-down list.
      Version
      Enter a version number. The preset version is 1.0.0.
      IAM Agency
      Select an agency from the drop-down list. If the selected agency does not have sufficient permissions, the task cannot be executed. Select another agency or create an agency.
  9. Click Add and select an instance.
    Table 4 Parameters for selecting an instance
    Selection Method
    Select an instance selection method.
    • Manual Selection: Manually select one or more instances based on settings of Enterprise Project, View Type, Resource Type, Region, and Target Instance.
    • Select All: The system automatically selects all instances based on settings of Enterprise Project, View Type, Resource Type, Region, and Target Instance.
    Enterprise Project
    Select an enterprise project from the drop-down list. You can choose All.
    View Type
    Select a view type.
    • CloudCMDB resources: Select an instance by resource type.
    • CloudCMDB application groups: Select an instance by application group.
    Resource Type
    The value can be ECS, CCE, or BMS.
    Note: When Execution Mode is set to Scheduled execution, Resource Type cannot be set to CCE.
    Region
    Select a region from the drop-down list.
    Target Instance
    Set filter criteria in the filter box and select the displayed instances manually or automatically.
  10. Configure Batch Policy and Suspension Policy.
    Table 5 Parameter description
    Batch Policy
    Select Automatic, Manual, or No Batch.
    • Automatic: The selected instances on which you want to perform operations are automatically divided into multiple batches based on the default rule.
    • Manual: You can manually create multiple batches and add instances to each batch as required.
    • No Batch: All instances on which you want to perform operations are in the same batch.
    Suspension Policy
    A preset rule for automatically stopping the asset patch compliance scan task.
    • You can set a target execution success rate. If the number of failed servers reaches the threshold derived from this success rate, the service ticket is flagged as abnormal and execution stops immediately.
    • The success rate ranges from 0 to 100 with precision to one decimal point.
  11. Click OK. In the displayed dialog box, confirm the information and click OK again to start the service ticket.
    The system automatically directs you to the service ticket details page. You can view the patch scan ticket execution records by referring to Viewing the Execution Records of a Patch Scan Service Ticket.
  1. Log in to COC.
  2. In the navigation pane on the left, choose Task Management > Execution Records. The task execution records page is displayed.
  3. Click Patch Tickets. The patch ticket record page is displayed.
  4. Click the patch ID of the patch service ticket whose Ticket Type is set to Scan. The service ticket details page is displayed.
    On the service ticket details page, you can view the service ticket execution status, such as the start time, end time, status, and execution duration.
  5. Perform the operations listed in the following table based on the service ticket status.
    Table 6 Operation description
    Service Ticket Status
    Operation
    Executing
    If you want to pause the next batch when the current batch is executed, click Pause in the upper right corner.
    Click Forcibly End in the upper right corner to stop the patch scan service ticket.
    Paused
    Click Continue in the upper right corner to continue the patch scan service ticket.
    Abnormal
    Click the Abnormal tab in the Execution Information area. Locate an abnormal batch and click Retry in the Operation column.
    Click the Abnormal tab in the Execution Information area. Locate an abnormal batch and click Cancel in the Operation column.
Checking Patch Scan Results
The patch scan and patch repair results are also called patch compliance reports. A patch compliance report will only retain the most recent scan or repair record.
To view details about a patch in the compliance report, perform the following operations:
  1. Log in to COC.
  4. On the Patch Scanning tab page, select the resource type of the instance whose patch needs to be viewed.
  5. Locate the instance whose patch needs to be viewed and click Summary in the Operation column.
    The patch summary page displays the patch name, category, severity, compliance status, patch baseline, installation time, and status.
    Table 7 Patch status description
    Patch Status
    Installed
    The patch complies with the patch baseline and has been installed on an ECS. No update is available.
    Non-baseline patches installed
    The patch is not included in the patch baseline but has been installed on the ECS.
    Installed-to be Restarted
    The patch has been repaired, and can take effect only after the ECS instance is restarted.
    Rejected
    The rejected patch defined in the abnormal patches of a patch baseline. This patch will not be repaired even if it is compliant with the patch baseline.
    Pending Repair
    The patch complies with the baseline, but the patch version is earlier than the baseline version.
    Patch Repair Failed
    A patch repair operation is performed, but the repair fails.
Helpful Links
