Updated on 2024-10-29 GMT+08:00
Patch Management
Patch Management allows users to manage patches on ECS or Cloud Container Engine (CCE) instances by scanning and repairing patches.
Before managing patches, ensure that the operating systems (OSs) of execution machines are supported by the existing patch management feature, and the second-party package, on which the patch management feature is dependent on, is contained in the execution machine, and the package functions are normal. Otherwise, patches may fail to be managed.
  • Table 1 lists the OSs and versions supported by the patch management feature.
  • Table 2 lists the environment on which patch management depends.
Table 1 OSs and versions supported by the patch management feature
OS
Product
Huawei Cloud EulerOS 1.1
Huawei Cloud EulerOS 2.0
CentOS
CentOS 7.2
CentOS 7.3
CentOS 7.4
CentOS 7.5
CentOS 7.6
CentOS 7.7
CentOS 7.8
CentOS 7.9
CentOS 8.0
CentOS 8.1
CentOS 8.2
EulerOS
EulerOS 2.2
EulerOS 2.5
EulerOS 2.8
EulerOS 2.9
EulerOS 2.10
Table 2 Second-party packages on which the patch management feature depends
Type
Dependency Item
Python environment
Python (Python2 or Python3)
DNF software packages (depended by Huawei Cloud EulerOS 2.0, CentOS 8.0 or later, and EulerOS 2.9 or later)
YUM software packages (depended by Huawei Cloud EulerOS 1.1, versions earlier than CentOS 8.0 and EulerOS 2.9)
lsb-release software package
Software package management tool
RPM
