Halaman ini belum tersedia dalam bahasa lokal Anda. Kami berusaha keras untuk menambahkan lebih banyak versi bahasa. Terima kasih atas dukungan Anda.
- Getting Started
User Guide
- Overview
- Resource Management
Application Management
- Creating an Application
- Modifying an Application
- Deleting an Application
- Creating a Component
- Modifying a Component
- Deleted a Component
- Creating a Group
- Modifying a Group
- Deleting a Group
- Transferring Resources
- Viewing Resource Details
- Viewing Capacity Rankings
- Multi-cloud Configurations
- Cross-Account Resources
- Resource O&M
- Automated O&M
- Faults
- Change Management
- Resilience Center
- Task Management
- Basic Configurations
- Viewing Logs
- Best Practices
- API Reference
- Product Consulting
- Resource Management FAQs
FAQs About Resource O&M
Patch Management FAQs
- Why Can't I Select a Node?
- Automation FAQs
- Batch Operation FAQs
- FAQs About Fault Management
- Resilience Center FAQs
- Change History
Editing an Account
You can update existing accounts.
Update a cloud vendor account on COC.
- Log in to COC.
- On the Multi-cloud Configurations page, locate the target cloud service provider account, and click Modify in the Operation column.
Figure 1 Editing an account
- Enter required information and click OK. For details, see Table 1.
Table 1 Parameters for editing an account Parameter
Example Value
Account
(Mandatory) Basic information, which is the account name.
Access Key ID
(Mandatory) Basic information, which is the AK ID.
Reuse Access Key Secret
(Mandatory) Whether to reuse the access key secret
If this parameter is set to Yes, the latest access key secret is reused.
If this parameter is set to No, you need to enter a new access key secret.
Yes
Access Key Secret
Basic information, which is the access key secret.
