Halaman ini belum tersedia dalam bahasa lokal Anda. Kami berusaha keras untuk menambahkan lebih banyak versi bahasa. Terima kasih atas dukungan Anda.
- Getting Started
User Guide
- Overview
- Resource Management
Application Management
- Creating an Application
- Modifying an Application
- Deleting an Application
- Creating a Component
- Modifying a Component
- Deleted a Component
- Creating a Group
- Modifying a Group
- Deleting a Group
- Transferring Resources
- Viewing Resource Details
- Viewing Capacity Rankings
- Multi-cloud Configurations
- Cross-Account Resources
- Resource O&M
- Automated O&M
- Faults
- Change Management
- Resilience Center
- Task Management
- Basic Configurations
- Viewing Logs
- Best Practices
- API Reference
- Product Consulting
- Resource Management FAQs
FAQs About Resource O&M
Patch Management FAQs
- Why Can't I Select a Node?
- Automation FAQs
- Batch Operation FAQs
- FAQs About Fault Management
- Resilience Center FAQs
- Change History
Show all
Creating an Account
You can create an account under a cloud vendor to synchronize resources of the account.
Create a cloud vendor account on COC.
Precautions
Currently, only Alibaba Cloud accounts can be created.
- Log in to COC.
- In the navigation pane, choose Resources > Application and Resource Management. On the displayed page, click Multi-cloud Configurations.
Figure 1 Multi-cloud Configurations
- On the Multi-cloud Configurations page, click the target cloud vendor.
Figure 2 Creating an account
- Enter required information and click OK. For details, see Table 1.
Table 1 Parameters for creating an account Parameter
Example Value
Account ID
(Mandatory) Basic information, which is the account ID.
Account
(Mandatory) Basic information, which is the account name.
Access Key ID
(Mandatory) Basic information, which is the access key ID.
Access Key Secret
(Mandatory) Basic information, which is the access key secret.
