pow
This function is used to calculate and return the pth power of a.
Syntax
pow(DOUBLE a, DOUBLE p), power(DOUBLE a, DOUBLE p)
Parameters
Parameter |
Mandatory |
Type |
Description |
a |
Yes |
DOUBLE, BIGINT, DECIMAL, or STRING |
The value can be a float, integer, or string. If the value is not of the DOUBLE type, the system will implicitly convert it to the DOUBLE type for calculation. |
p |
Yes |
Return Values
The return value is of the DOUBLE type.
If the value of a or p is NULL, NULL is returned.
Example Code
The value 16 returned.
select pow(2, 4);
The value NULL is returned.
select pow(2, null);
The value 17.429460393524256 is returned.
select pow(2, 4.123456);
