positive
This function is used to return the value of a.
Syntax
positive(INT a)
Parameters
| Parameter | Mandatory | Type | Description |
| a | Yes | DOUBLE, BIGINT, DECIMAL, or STRING | The value can be a float, integer, or string. |
Return Values
The return value is of the DECIMAL, DOUBLE, or INT type.
If the value of a is NULL, NULL is returned.
Example Code
The value 3 is returned.
SELECT positive(3);
The value -3 is returned.
SELECT positive(-3);
The value 123 is returned.
SELECT positive('123'); Feedback
