pmod
This function is used to return the positive value of the remainder after division of x by y.
Syntax
pmod(INT a, INT b)
Parameters
Parameter |
Mandatory |
Type |
Description |
a |
Yes |
DOUBLE, BIGINT, DECIMAL, or STRING |
The value can be a float, integer, or string. |
b |
Yes |
Return Values
The return value is of the DECIMAL or INT type.
- If the value of a or b is NULL, NULL is returned.
- If the value of b is 0, NULL is returned.
Example Code
The value 2 is returned.
select pmod(2,5);
The value 3 is returned.
select pmod (-2,5) (parse: -2=5* (-1)...3);
The value NULL is returned.
select pmod(5,0);
The value 1 is returned.
select pmod(5,2);
The value 0.877 is returned.
select pmod(5.123,2.123);
