radians
This function is used to return the radian corresponding to an angle.
Syntax
radians(DOUBLE a)
Parameters
Parameter |
Mandatory |
Type |
Description |
a |
Yes |
DOUBLE, BIGINT, DECIMAL, or STRING |
The value can be a float, integer, or string. If the value is not of the DOUBLE type, the system will implicitly convert it to the DOUBLE type for calculation. |
Return Values
The return value is of the DOUBLE type.
![](https://support.huaweicloud.com/intl/en-us/sqlref-spark-dli/public_sys-resources/note_3.0-en-us.png)
If the value of a is NULL, NULL is returned.
Example Code
The value 1.0471975511965976 is returned.
select radians(60);
The value 0 is returned.
select radians(0);
The value NULL is returned.
select radians(null);
