Help Center/ Data Lake Insight/ Delta SQL Syntax Reference/ Delta SQL Syntax Reference/ Schema Evolution Syntax
Updated on 2025-01-09 GMT+08:00
Function
This capability supports column alterations on Hudi tables with SparkSQL. Schema evolution must be enabled before using this capability.
Scope of Schema Evolution
The scope of schema evolution includes:
- Column operations: Supports adding, deleting, modifying, and adjusting the position of columns (including nested columns).
- Partition columns: Does not support schema evolution on partition columns.
- Array type columns: Does not support adding, deleting, or altering nested columns of Array type.
0
3
4
5
6
7
8
9
10
Very dissatisfiedVery satisfied
