DROP COLUMN
Function
The ALTER TABLE ... DROP COLUMN command is used to delete a column.
Syntax
ALTER TABLE tableName DROP COLUMN|COLUMNS cols
Parameter Description
| Parameter | Description |
| tableName | Table name. |
| cols | Columns to be deleted. You can specify multiple columns. |
Required Permissions
- SQL permissions
| Permission Description |
| ALTER permission on a table |
- Fine-grained permission: dli:table:alter
- Metadata services provided by LakeFormation. Refer to the LakeFormation documentation for details on permission configuration.
Example
ALTER TABLE table1 DROP COLUMN a.b.c ALTER TABLE table1 DROP COLUMNS a.b.c, x, y
a.b.c indicates the full path of a nested column. For details about the nested column rules, see ADD COLUMNS.
Response
You can run the DESCRIBE command to check which column is deleted.
